Текущее время: 19 май 2024, 18:26
crocodile70
Заголовок сообщения: Re: Boardview Saphire r9 390 Добавлено: 05 ноя 2021, 13:07 |
Зарегистрирован: 31 май 2020, 23:55 Наличности на руках: 422.62
Сообщения: 627 Откуда: Украина Днепр
Pandemonium6 писал(а): I haven't seen them on the forum, I also would like to find them. Have you seen them and can't download? MSI - available for R9 390 Sapphire - nothing freely available
Pandemonium6
Заголовок сообщения: Re: Boardview Saphire r9 390 Добавлено: 08 ноя 2021, 10:19 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,140.72
Сообщения: 762 Откуда: Holand
I also got Sapphire R9 390 and the fuse on PCIe slot was blown along with drmos for memory controller. Drmos was partially bad, it had 80 ohms instead of a short. I replaced both but I don't have memory, memory controller and vcore voltages. I found that on the input 1 of the AND gate there is no high state, please see attached image. How is it formed, where does it come from? Anybody has experience with this board? This is exactly this PCB and exact the same dmoses but there is something more.. https://www.youtube.com/watch?v=KBcMgNY5C80
pEEp
Заголовок сообщения: Re: Boardview Saphire r9 390 Добавлено: 28 дек 2021, 03:12 |
Зарегистрирован: 25 сен 2018, 20:41 Наличности на руках: 709.36
Сообщения: 1114 Откуда: Севастополь
Pandemonium6 писал(а): I found that on the input 1 of the AND gate there is no high state, please see attached image. How is it formed, where does it come from? Anybody has experience with this board? From IR3567B (11) VDDC_PG (O) on two ways: 1) To U1000 (1) VDDC_PG (I) -> from U1000 (4) VDDC_POK (O) -> to IR3567B (12) VDDC_POK (I) = VDDC. 2) Through Q355 + Q356 -> to NCP5230 (14) EN (I) = MVDD. Now this is my current repair - I'm trying to figure it out myself...
RandomR
Заголовок сообщения: Re: Boardview Saphire r9 390 Добавлено: 28 дек 2021, 14:30 |
Зарегистрирован: 16 янв 2020, 13:11 Наличности на руках: 187.11
Сообщения: 198 Откуда: Sweden
Pandemonium6 писал(а): I had two of them from a local seller on Ebay. Is it possible they were fake? I have had bad experiences when buying IR3553 from Ebay - a couple of times 5-7 pieces out of 10 had short-circuit between WIN and PGND. Now I always check them before soldering.
pEEp
Заголовок сообщения: Re: Boardview Saphire r9 390 Добавлено: 28 дек 2021, 16:34 |
Pandemonium6 писал(а): I replaced IR3553 in memory controller Me too - now my card is working. Try to replace 3553M correctly and check thermoresistor near it (10k). Thats why, one of the conditions for the appearance of the singal VDDC_PG (11) is the presents VDDCI (not VDDCI, but correctly installed DrMOS). Unlike 400-500 series, for 300 series EN for MVDD is the same as VDDC_PG.
