Заголовок сообщения: monitor / lcd tv LG M227WD led flashing on the power button
Добавлено: 19 авг 2014, 18:01
Зарегистрирован: 18 фев 2012, 22:42 Наличности на руках: 118.34 Сообщения: 389 Откуда: Brasil
the source code of the card: PLLM-M702A.
The monitor arrived functioning normally always presenting the message of proper resolution in 1920 by 1200. After a few minutes running, the image disappears and the led on the power button flashes. The message of proper resolution 1920 by 1200 always appears independent of the resolution I choose. It seems that triggers the protection circuit of the circuit. It may also be the voltage that feeds the bulbs are above normal that triggers the protection circuit.
The exciter of output high is used integrated AOP605 (two integrated)
Tried replacing the bulbs, but the problem continues.
kotnatan
Заголовок сообщения: Re: monitor / lcd tv LG M227WD led flashing on the power button
Добавлено: 19 авг 2014, 18:21
Зарегистрирован: 08 мар 2013, 20:05 Наличности на руках: 179.71 Сообщения: 4292 Откуда: Украина г.Барановка Заблокирован
Try to clear data EEPROM IC105 - AT24C512 record in the data buffer FF or 00
_________________ «Кто владеет информацией - тот владеет миром»
eletmoraes
Добавлено: 19 авг 2014, 20:40
you mean, clear the eeprom and then rewrite
kotnatan
Добавлено: 19 авг 2014, 22:25
put clean eeprom
eletmoraes
Заголовок сообщения: Re: monitor / lcd tv LG M227WD led flashing on the power button ( решена )
Добавлено: 25 авг 2014, 20:41
I believe I have solved the fault with the monitor replacing the smd capacitor C306 which should be 10nF for another of equal value because after the exchange, the monitor was turned on for several hours without presenting the problem cited.
eletmoraes
Добавлено: 28 авг 2014, 15:48
unfortunately I will have to continue to examine this monitor, the problem remains
Сейчас этот форум просматривают: chulat и гости: 3
