https://vlab.su/
LG M1710AB
https://vlab.su/viewtopic.php?f=100&t=93356
Страница 1 из 1
abs [ 17 авг 2019, 18:41 ]
Заголовок сообщения:  LG M1710AB
Hi
The power board monitor LG M1710AB had a problem that was repaired.voltages power board ok. The monitor turns on but the display is blue and hangs.
when i connect to a computer, no display just empty blue display.
thanks
vova_w810i [ 17 авг 2019, 18:54 ]
Заголовок сообщения:  Re: LG M1710AB
flash AT49FOO2
here is the firmware: viewtopic.php?f=100&t=5575&p=695069#p695069
abs [ 21 авг 2019, 11:53 ]
Заголовок сообщения:  Re: LG M1710AB  [РЕШЕНО]
hi
tested ok
very thanks
http://www.phpbb.com/
