iphone 4014 problem https://vlab.su/viewtopic.php?f=144&t=72159 |
serwanjaf7 [ 15 фев 2018, 11:47 ] | |
Заголовок сообщения: | iphone 4014 problem |
hello friends i hava a iphone 5s have a 4014 error . i removed the nand and i have a naviplus 3000 i fix it but it still show 4014 but i lost the serial no for the iphone . i dont know where is the problem is the serail no i required or i have a problem on the naviplus . and how i can get the serail no by imei thank you for your help |
recordsman [ 15 фев 2018, 12:47 ] | |
Заголовок сообщения: | Re: iphone 4014 problem |
serwanjaf7 писал(а): 4014 error hi? unforch no way refresh serial to nand, 4014 4013 CPU errors also |
serwanjaf7 [ 15 фев 2018, 13:35 ] | |
thank you for replay where i can get the serial no by imei ? i saw a website do that is that correct i mean i can trust it beast regards |
recordsman [ 15 фев 2018, 16:19 ] | |
will try but its illegal, you know...) |
serwanjaf7 [ 15 фев 2018, 19:02 ] | |
yes but the device is ded . all day have phone like that you know iphone nand erorr is to mach many erorr is nand like 9,21,40,4013,4014 all is the same and have some of them itunes can detect the sn but more cant see the sn and we dont use any thing illegal you know change i cload it must change many parts of the phone here only repire the thank you for your help |
console-master [ 16 фев 2018, 15:13 ] | |
try here https://sickw.com/ |
serwanjaf7 [ 17 фев 2018, 09:51 ] | |
thank you |
