Текущее время: 27 апр 2024, 06:33
MelnykVlad25
Заголовок сообщения: Tenda AC10U Постоянный ребут [РЕШЕНО] Добавлено: 05 окт 2020, 22:42 |
Зарегистрирован: 05 окт 2020, 22:36 Наличности на руках: 20.05
Сообщения: 11 Откуда: Украина
Подскажите пожалуйста что может быть
log Дамп из интернета
Booting... init_ram 00000102 W init ddr ok
DRAM Type: DDR2 DRAM frequency: 533MHz DRAM Size: 64MB JEDEC id EF4017, EXT id 0x0000 found w25q64 flash vendor: Winbond w25q64, size=8MB, erasesize=64KB, max_speed_hz=29000000Hz auto_mode=0 addr_width=3 erase_opcode=0x000000d8 =>CPU Wake-up interrupt happen! GISR=89000004
---Realtek RTL8197F boot code at 2017.07.27-09:11+0800 v3.4.11B.9 (999MHz) Mac addr:cc-2d-21-20-39-70 lan_wan_isolation Initing... config: lan port mask is 0x000000f7 config: wan port mask is 0x000000e8 lan_wan_isolation Initing has been completed. lan_wan_isolation Initing... config: lan port mask is 0x000000f7 config: wan port mask is 0x000000e8 lan_wan_isolation Initing has been completed. wait for upgrage port[0] link:down port[1] link:down port[2] link:down port[3] link:down port[4] link:down irq:0x00008480 Jump to image start=0x80a00000... decompressing kernel: Uncompressing Linux... done, booting the kernel. done decompressing kernel. start address: 0x804792d0 Linux version 3.10.90 (root@linux-bkb8) (gcc version 4.4.7 (Realtek MSDK-4.4.7 Build 2001) ) #4 Mon Feb 5 15:38:02 CST 2018 bootconsole [early0] enabled CPU revision is: 00019385 (MIPS 24Kc) Determined physical RAM map: memory: 04000000 @ 00000000 (usable) Zone ranges: Normal [mem 0x00000000-0x03ffffff] Movable zone start for each node Early memory node ranges node 0: [mem 0x00000000-0x03ffffff] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttyS0,115200 root=/dev/mtdblock4 PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Writing ErrCtl register=0000e8df Readback ErrCtl register=0000e8df Memory: 41284k/65536k available (4601k kernel code, 24252k reserved, 2243k data, 192k init, 0k highmem) SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:192 Realtek GPIO IRQ init Calibrating delay loop... 666.41 BogoMIPS (lpj=3332096) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 NET: Registered protocol family 16 <<<<<Register PCI Controller>>>>> Do MDIO_RESET 40MHz Find PCIE Port, Device:Vender ID=b82210ec INFO: initializing USB devices ... enable port 0 two port enable port 0 org 0xe0=e2 port 0 org 0xe1=31 port 0 org 0xe2=39 port 0 org 0xe4=98 port 0 org 0xe6=c0 port 1 org 0xe0=e2 port 1 org 0xe1=31 port 1 org 0xe2=39 port 1 org 0xe4=98 port 1 org 0xe6=c0 patch new usb phy para for 40M OSC system reg b8000010=0x80047000 system reg b8000014=0x118 system reg b8000160=0x1 system reg b8000164=0x0 system reg b8000168=0x0 system reg b800016c=0x280500 system reg b8000180=0x60000 system reg b8021094=0x200020 system reg b8140200=0xf002cc11 system reg b8140204=0x0 system reg b8140208=0x2010000 system reg b814020c=0x9b00 system reg b8140210=0xca00ca
EHCI reg b8021050=0x0 EHCI reg b8021054=0x2000 EHCI reg b8021058=0x2000 OHCI reg b8020000=0x110 OHCI reg b8020004=0x0 port 0 reg e0=e2 port 0 reg e1=31 port 0 reg e2=33 port 0 reg e3=8d port 0 reg e4=c9 port 0 reg e5=19 port 0 reg e6=c1 port 0 reg e7=91 port 0 reg f0=fc port 0 reg f1=8c port 0 reg f2=0 port 0 reg f3=11 port 0 reg f4=9b port 0 reg f5=4 port 0 reg f6=0 port 1 reg e0=e2 port 1 reg e1=31 port 1 reg e2=33 port 1 reg e3=8d port 1 reg e4=c9 port 1 reg e5=19 port 1 reg e6=c1 port 1 reg e7=91 port 1 reg f0=fc port 1 reg f1=8c port 1 reg f2=0 port 1 reg f3=11 port 1 reg f4=9b port 1 reg f5=4 port 1 reg f6=0 Realtek GPIO controller driver init INFO: registering sheipa spi device bio: create slab <bio-0> at 0 SCSI subsystem initialized INFO: sheipa spi driver register INFO: sheipa spi probe usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Switching to clocksource MIPS NET: Registered protocol family 2 TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP: reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 squashfs: version 4.0 (2009/01/31) Phillip Lougher fuse init (API version 7.22) msgmni has been set to 80 io scheduler noop registered (default) Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled serial8250: ttyS0 at MMIO 0x18147000 (irq = 17) is a 16550A console [ttyS0] enabled, bootconsole disabled console [ttyS0] enabled, bootconsole disabled Realtek GPIO to I2C Driver Init... mfi_ioctl_init:565,dev=254,MINOR=0 rtl819x_btn_probe: reset btn:54 rtl819x_btn_probe: wps_btn:54 rtl819x_btn_probe: wifi btn:56 rtl819x_btn_probe: wps_btn:54 rtl819x_led_probe: sys led:57 rtl819x_led_probe: wps_led:33 loop: module loaded m25p80 spi0.0: change speed to 15000000Hz, div 7 JEDEC id EF4017 m25p80 spi0.0: found w25q64, expected m25p80 flash vendor: Winbond m25p80 spi0.0: w25q64 (8192 Kbytes) (29000000 Hz) m25p80 spi0.0: change speed to 29000000Hz, div 4 Kernel code size:0x206812 7 rtkxxpart partitions found on MTD device m25p80 Creating 7 MTD partitions on "m25p80": 0x000000000000-0x000000800000 : "ALL" 0x000000000000-0x000000020000 : "Bootloader" 0x000000020000-0x000000030000 : "CFG" 0x000000030000-0x0000007e0000 : "KernelFS" 0x000000236812-0x0000007e0000 : "RootFS" 0x0000007e0000-0x0000007f0000 : "CFM" 0x0000007f0000-0x000000800000 : "CFM_BACKUP" PPP generic driver version 2.4.2 PPP MPPE Compression module registered NET: Registered protocol family 24 PPTP driver version 0.8.5 Realtek WLAN driver - version 1.7 (2015-10-30)(SVN:exported) Adaptivity function - version 9.3.4 Do MDIO_RESET 40MHz Find PCIE Port, Device:Vender ID=b82210ec
found 8822B !!! halmac_check_platform_api ==========> 12089M HALMAC_MAJOR_VER = 0 HALMAC_PROTOTYPE_VER = 0 HALMAC_MINOR_VER = 0 halmac_init_adapter_88xx ==========> halmac_init_adapter Succss IS_RTL8822B_SERIES value8 = a MACHAL_version_init
####################################################### SKB_BUF_SIZE=4440 MAX_SKB_NUM=1024 #######################################################
MACHAL_version_init RFE TYPE =5
####################################################### SKB_BUF_SIZE=3040 MAX_SKB_NUM=400 #######################################################
RFE TYPE =5 RFE TYPE =5 RFE TYPE =5 RFE TYPE =5 RFE TYPE =5 u32 classifier nf_conntrack version 0.5.0 (645 buckets, 2580 max) [BM CORE ] INFO: online ip data hash table created, size = 199 [BM CORE ] INFO: online_ip proc file created ipip: IPv4 over IPv4 tunneling driver gre: GRE over IPv4 demultiplexor driver ip_gre: GRE over IPv4 tunneling driver ip_tables: (C) 2000-2006 Netfilter Core Team TCP: cubic registered NET: Registered protocol family 17 l2tp_core: L2TP core driver, V2.0 l2tp_ppp: PPPoL2TP kernel driver, V2.0 8021q: 802.1Q VLAN Support v1.8 Realtek FastPath:v1.03
Probing RTL819X NIC-kenel stack size order[1]... eth0 added. vid=1 Member port 0x107... eth1 added. vid=2 Member port 0x108... [peth0] added, mapping to [eth1]... Realtek GPIO Driver for Flash Reload Default VFS: Mounted root (squashfs filesystem) readonly on device 31:4. Freeing unused kernel memory: 192K (806b0000 - 806e0000) umount: can't forcibly umount /tmp: Invalid argument mkdir: can't create directory '/var/run': File exists insmod: can't insert '/lib/modules/fastnat.ko': No such file or directory [BM CORE ] INFO: bm_init success [U2K MODULE ] INFO: bm_u2k_info_init success [MAC FILTER ] INFO: bm_mac_filter init success [PRIVILEGE IP] INFO: privilege ip init success qos qos_init 1736: qos module init success OS TYPE INIT FINISHED [URL FILTER ] INFO: url filter init success insmod: can't insert '/lib/modules/loadbalance.ko': No such file or directory Give root password for system maintenance (or type Control-D for normal startup):udevd (922): /proc/922/oom_adj is deprecated, please use /proc/922/oom_score_adj instead. no auto_discover argv[0] = cfmd cfmd argv[0] = netctrl netctrl cfmd: '/lib/libpthread.so.0' is not an ELF file cfmd: can't load library 'libpthread.so.0' [monitor debug] monitor recv SIGCHLD Reaped pid = 934 argv[0] = cfmd cfmd can't run '/usr/sbin/wl': No such file or direc[monitor debug] monitor recv 15 the monitor exit, kill all process Sent SIGKILL to all processes Requesting system reboot Restarting system. Shutdown network interface
log Родной дамп
---Realtek RTL8197F boot code at 2017.07.27-09:11+0800 v3.4.11B.9 (999MHz) Mac addr:04-95-e6-1d-d9-d0 lan_wan_isolation Initing... config: lan port mask is 0x000000f7 config: wan port mask is 0x000000e8 lan_wan_isolation Initing has been completed. lan_wan_isolation Initing... config: lan port mask is 0x000000f7 config: wan port mask is 0x000000e8 lan_wan_isolation Initing has been completed. wait for upgrage port[0] link:down port[1] link:down port[2] link:down port[3] link:down port[4] link:down irq:0x00008480 Jump to image start=0x80a00000... decompressing kernel: Uncompressing Linux... done, booting the kernel. done decompressing kernel. start address: 0x80480860 Linux version 3.10.90 (root@linux-tkja) (gcc version 4.4.7 (Realtek MSDK-4.4.7 Build 2001) ) #4 Tue Feb 26 17:46:32 CST 2019 bootconsole [early0] enabled CPU revision is: 00019385 (MIPS 24Kc) Determined physical RAM map: memory: 04000000 @ 00000000 (usable) Zone ranges: Normal [mem 0x00000000-0x03ffffff] Movable zone start for each node Early memory node ranges node 0: [mem 0x00000000-0x03ffffff] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttyS0,115200 root=/dev/mtdblock4 PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Writing ErrCtl register=0002eacf Readback ErrCtl register=0002eacf Memory: 41220k/65536k available (4631k kernel code, 24316k reserved, 2270k data, 200k init, 0k highmem) SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:192 Realtek GPIO IRQ init Calibrating delay loop... 666.41 BogoMIPS (lpj=3332096) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 devtmpfs: initialized NET: Registered protocol family 16 CPU 0 Unable to handle kernel paging request at virtual address 00000028, epc == 80049e88, ra == 8004bc28 Oops[#1]: CPU: 0 PID: 11 Comm: kworker/u2:0 Not tainted 3.10.90 #4 task: 83c3dd88 ti: 83c5c000 task.ti: 83c5c000 $ 0 : 00000000 00000001 83c20b80 8048cbf0 $ 4 : 80597568 83c3cca8 00000000 00000000 $ 8 : 00000001 00000001 fffffffc 00000022 $12 : ffffffff 00000000 00000000 0000001f $16 : 83c3cca8 00000000 83c41dec 00000003 $20 : 00000000 00000000 00000001 83c40008 $24 : 00000000 8004d86c $28 : 83c5c000 83c5de10 8048cbf0 8004bc28 Hi : 00000000 Lo : 042c1d80 epc : 80049e88 check_preempt_curr+0x14/0xd0 Not tainted ra : 8004bc28 try_to_wake_up+0x6c/0xb4 Status: 10008402 KERNEL EXL Cause : 00800008 BadVA : 00000028 PrId : 00019385 (MIPS 24Kc) Modules linked in: Process kworker/u2:0 (pid: 11, threadinfo=83c5c000, task=83c3dd88, tls=00000000) Stack : 00000041 00000000 00000000 83801440 83c3cca8 8004bc28 805a0491 00000000 83c110b0 83801088 83800130 83c41de0 00000001 800498b0 00000000 00000000 00000000 00000000 00000001 83c3dd88 00000000 80590000 ffffffff 80597548 83c40000 800499d0 83c23db8 83c0a000 00000001 800a1ee4 00000000 80047468 83c3dd88 8001e604 00000000 83c3dd88 fffffffe 80590000 ffffffff 80597548 ... Call Trace: [<80049e88>] check_preempt_curr+0x14/0xd0 [<8004bc28>] try_to_wake_up+0x6c/0xb4 [<800498b0>] __wake_up_common+0x68/0xbc [<800499d0>] complete+0x40/0x60 [<8001e604>] mm_release+0xa8/0xdc [<80026590>] do_exit+0x104/0x7f8 [<80037d08>] ____call_usermodehelper+0x10c/0x11c [<800037f0>] ret_from_kernel_thread+0x10/0x18
Code: afb00010 8c8703cc 8ca30028 <8ce20028> 10620026 00808021 3c058049 24a5cc80 1045000c c0_compare_interrupt 64
MelnykVlad25
Заголовок сообщения: Re: Tenda AC10U Постоянный ребут Добавлено: 30 май 2022, 21:09 |
AlexCreating писал(а): Прошивать пробовали? Да, заменил cpu заработал
