Текущее время: 23 апр 2024, 23:00
 Заголовок сообщения: SmartAX MT880 V200R001C01B020-20040803
СообщениеДобавлено: 02 ноя 2010, 16:01
MT880 ADSL2+ firmware upgrade manual
1 New firmware version describtion
This part will be updated each time the MT880’s firmware is upgraded.
Current newest MT880’s firmware version is C87.2.7 and HUAWEI software version is MT880V200R001C01B020. They’ll be find on the main WEB page of MT880.
This version can cooperate with Conexant ADSL2+ CO version after C87.1.11, better with C87.1.13.
First of all, the PC netcard must be connected to MT880’s LAN interface and the IP of PC is set to the same subnet with MT880’s LAN interface, such as 192.168.1.10/255.255.255.0 . Then login MT880’s WEB page to do the upgrade, such as “http://192.168.1.1”.
2 Upgrade from MT880V100 version
MT880V100 version (including firmware A4.19.4, C87.2.*, C12.2.*, C84.2.*) uses the tar compression. So the upgrade file must be the .tar compression. Normally “http-upload.tar” file is provided for upgrade.
1, From MT880 WEB page, choose “System-->Firmware Upgrade”, browse the upgrade file “http-upload.tar” and click the upgrade button.
2, Click the “restart “ button after upgraded to restart MT880.
3 Upgrade from MT880V200 version
MT880V200 version (including firmware C87.2.*) uses the xdsl compression. So the upgrade file must be the .xdsl compression. Normally “*.xdsl” file is provided for upgrade.
1, From MT880 WEB page, choose “Tools-->Firmware Upgrade”, browser the upgrade file “*.xdsl” and click the upgrade button.
2, The MT880 will automaticly restart after upgraded.
4 Extra work to do
1, Please input “arp –d 192.168.1.1” on the DOS mode of PC to clear the arp table. Because upgrading from some very old version, the MT880’s mac will be modified. PC must clear its arp table to connect to MT880 again.
2, From MT880 WEB page, choose “Tools-->System Setting-->Restore” to restore MT880 to factory default configuration.
5 Firmware version confirmation
If the firmware version is not displayed on the MT880 main WEB page(some very old version), telnet to MT880 and login MT880’s command line mode.
Input command ”port a1 show”, then the firmware version will be found on the top line of the information displayed.
Huawei Technologies Co., Ltd.
Han Xuesong
2004-7-20
Нету лучше самолёта чем любимая toyota
