Текущее время: 26 апр 2024, 14:12
 Заголовок сообщения: Dir-615 c1 нужен дамп
СообщениеДобавлено: 01 окт 2016, 23:10
вот лог загрузки
ее конец
Code: 8026f6e4 8026f6e4 8026f6ec <8026f6ec> 0000001d 81028e14 8102d314 00000080 00000000
[ 0.000000] ---[ end trace 139ce121c98e9714 ]---
[ 0.000000] Kernel panic - not syncing: Fatal exception in interrupt
[ 0.000000] Rebooting in 1 seconds..[ 0.000000] CPU 0 Unable to handle kernel paging request at virtual address fffff75e, epc == 800036f0, ra == 802098e8
[ 0.000000] Oops[#80]:
[ 0.000000] Cpu 0
[ 0.000000] $ 0 :[ 0.000000] 00000000 00000072 802a0000 00000000
[ 0.000000] $ 4 : 00000000 00000000 00000000 00000000
[ 0.000000] $ 8 : 0000002e 74696e67 20696e20 31207365
[ 0.000000] $12 : 30303038 bb4bd565 356ae426 30202030
[ 0.000000] $16 : 000003e8 00000001 000003e8 802a0000
[ 0.000000] $20 : 00000000 80260000 000003e8 00000000
[ 0.000000] $24 : 00000003 800036f0
[ 0.000000] $28 : 8023a000 8023a248 00030000 802098e8
Hi : 00000000
[ 0.000000] Lo : 00000000
[ 0.000000] epc : 800036f0 0x800036f0
[ 0.000000] Tainted: G D
[ 0.000000] ra : 802098e8 0x802098e8
[ 0.000000] Status: 10004003 KERNEL EXL IE
[ 0.000000] Cause : 40808008
[ 0.000000] BadVA : fffff75e
[ 0.000000] PrId : 00019374 (MIPS 24Kc)
[ 0.000000] Modules linked in:[ 0.000000]
[ 0.000000] Process (pid: 0, threadinfo=8023a000, task=80263d94, tls=00000028)
[ 0.000000] Stack :[ 0.000000] ae0200b8
00000001[ 0.000000] 802a0000
ffffffff[ 0.000000] 8023a284
00000000[ 0.000000] 8023a370
80224b30[ 0.000000]
0000000b[ 0.000000] 00000028
00000000[ 0.000000] 80260000
ae0200b8[ 0.000000] 80009618
8023a370[ 0.000000] 00000000
802a0000[ 0.000000] 00000000
00000002[ 0.000000] 0000000b
fffff75e[ 0.000000] 800db598
8023a370[ 0.000000] 8000df68
ffffffff[ 0.000000] 00000000
00000008[ 0.000000] fffff75e
00000008[ 0.000000] 800036f0
00000008[ 0.000000] 802098e8
80225b79[ 0.000000] 00030001
00000000[ 0.000000] 8001448c
00000001[ 0.000000] 0000000a
00000006[ 0.000000] ffffffff
[ 0.000000] Call Trace:[<80009618>] 0x80009618
[<800db598>] 0x800db598
[ 0.000000] [<8000df68>] 0x8000df68
[ 0.000000] [<800036f0>] 0x800036f0
[ 0.000000] [<802098e8>] 0x802098e8
[ 0.000000] [<8001448c>] 0x8001448c
[ 0.000000] [<800f42d4>] 0x800f42d4
[ 0.000000] [<800159a4>] 0x800159a4
[ 0.000000] [<80004ee0>] 0x80004ee0
[ 0.000000] [<80009618>] 0x80009618
[ 0.000000] [<800db598>] 0x800db598
[ 0.000000] [<8015a700>] 0x8015a700
[ 0.000000] [<8000dd4c>] 0x8000dd4c
[ 0.000000] [<8015a670>] 0x8015a670
[ 0.000000] [<8015a820>] 0x8015a820
[ 0.000000] [<801570ac>] 0x801570ac
[ 0.000000] [<8015a854>] 0x8015a854
[ 0.000000] [<80158408>] 0x80158408
[ 0.000000] [<8015ae7c>] 0x8015ae7c
[ 0.000000] [<801570b8>] 0x801570b8
[ 0.000000] [<8015dd38>] 0x8015dd38
[ 0.000000] [<8015a6b8>] 0x8015a6b8
[ 0.000000] [<80170030>] 0x80170030
[ 0.000000] [<80170524>] 0x80170524
[ 0.000000] [<8015ac6c>] 0x8015ac6c
[ 0.000000] [<80157510>] 0x80157510
[ 0.000000] [<80157838>] 0x80157838
[ 0.000000] [<8016ff30>] 0x8016ff30
[ 0.000000]
[ 0.000000]
Code:
[ 0.000000] 8026f6e4 [ 0.000000] 8026f6e4
8026f6ec [ 0.000000] <8026f6ec>
0000001d [ 0.000000] 81028e14
8102d314 [ 0.000000] 00000080
00000000
[ 0.000000] ---[ end trace 139ce121c98e9715 ]---
[ 0.000000] Fatal exception: panic in 5 seconds
[%5lu.%<6?<6>b▒"]<6?@▒▒Oops[#81]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#82]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#83]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#84]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#85]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#86]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#87]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#88]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#89]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#90]:
[%5lu.%<6?<6>b▒"]▒▒
[%5lu.%<6?<6>b▒"]<6?@▒▒Oops[#91]:
[%5lu.%<6?<6>b▒"]▒▒
[%5lu.%<6?<6>b▒"]<6?@▒▒Oops[#92]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#93]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#94]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#95]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#96]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#97]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#98]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#99]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#100]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#101]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#102]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#103]:
[%5lu.%<6?<6>b▒"]▒▒[%5lu.%<6?<6>b▒"]Unhandled kernel unaligned access[#104]:
[%5lu.%<6?<6>b▒"][%5lu.%<6?<6>b▒"]▒▒
<6?@▒▒Oops[#105]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#106]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#107]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#108]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#109]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#110]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#111]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#112]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#113]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#114]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒[%5lu.%<6?<6>b▒"]Oops[#115]:
<6?@▒▒Oops[#116]:
[%5lu.%<6?<6>b▒"]▒▒[%5lu.%<6?<6>b▒"]Unhandled kernel unaligned access[#117]:
[%5lu.%<6?<6>b▒"][%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#118]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#119]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#120]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#121]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#122]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#123]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#124]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#125]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#126]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#127]:
[%5lu.%<6?<6>b▒"]▒▒
<6?@▒▒Oops[#128]:
[%5lu.%<6?<6>b▒"]▒▒
[%5lu.%<6?<6>b▒"]<6?@▒▒Oops[#129]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#130]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#131]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#132]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#133]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#134]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#135]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#136]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#137]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#138]:
[%5lu.%<6?<6>b▒"]▒▒
[%5lu.%<6?<6>b▒"]<6?@▒▒Oops[#139]:
[%5lu.%<6?<6>b▒"]▒▒
[%5lu.%<6?<6>b▒"]<6?@▒▒Oops[#140]:
[%5lu.%<6?<6>b▒"]▒▒[%5lu.%<6?<6>b▒"]Unhandled kernel unaligned access[#141]:
[%5lu.%<6?<6>b▒"][%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#142]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#143]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#144]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#145]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#146]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#147]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#148]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#149]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#150]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#151]:
[%5lu.%<6?<6>b▒"]▒▒
<6?@▒▒Oops[#152]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#153]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#154]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#155]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#156]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#157]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#158]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#159]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#160]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#161]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#162]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#163]:
[%5lu.%<6?<6>b▒"]▒▒[%5lu.%<6?<6>b▒"]Unhandled kernel unaligned access[#164]:
[%5lu.%<6?<6>b▒"][%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#165]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#166]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#167]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#168]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#169]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#170]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#171]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#172]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#173]:
[%5lu.%<6?<6>b▒"]▒▒<6?@▒▒Oops[#174]:
[%5lu.%<6?<6>b▒"]▒▒
<6?@▒▒Oops[#175]:
[%5lu.%<6?<6>b▒"]▒▒
 Заголовок сообщения: Re: Dir-615 c1 нужен дамп
СообщениеДобавлено: 26 окт 2016, 02:36
Смотрите здесь
viewtopic.php?f=146&t=276&start=0
В этой теме нет новых непрочитанных сообщений. D-Link Dir-615 C2 ищу дамп флешки
в форуме D-Link
apach71
6464
11 сен 2018, 23:32
snstak Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Ищу дамп на DIR-615 R1
в форуме D-Link
shamka
16
8984
09 янв 2019, 08:51
sorgrey Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Необходим дамп на DIR-615 HW:M1
в форуме D-Link
i99orr
28 апр 2016, 14:16
В этой теме нет новых непрочитанных сообщений. Дамп прошивки на D-Link Dir-615 K2a...K2e
в форуме D-Link
Master768
25 фев 2016, 00:12
tigran312312 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dir 615 rev.E4 альтернативные прошивки OpenWRT и DD-WRT
в форуме D-Link
Dreadypanda
04 сен 2022, 18:42
SaimonCSKA Перейти к последнему сообщению
