Privet.i can't speak russian verry well,but i know moldavian language verry well,so please respond in any language you want.
i have a problem with an Asus vw192S lcd.the autoadjust function moves the viewe area half way to left.if i set the freqency from pc to one higher than 75Hz the monitor shows normal screen position,without any problem,but the "out of range" square keeps floating around screen,so it's not an option.i've replaced all the capacitors,and on the "logic" board nothing seems defective.on the power board there are some areas browned from heat,but it works just fine.have someone found any similar problems in other monitors?
i will attach photos soon with the screen.
Posted after 1 hour 52 minutes 54 seconds:here are some photos.please help
