Текущее время: 28 апр 2024, 04:42
maplesyrup
Заголовок сообщения: Mix & Match Hot Tweezers with Station Добавлено: 30 авг 2022, 06:13 |
Зарегистрирован: 22 апр 2022, 06:51 Наличности на руках: 107.18
Сообщения: 36 Откуда: Canada
Hey guys; I have a cheap soldering station (Txinlei 8586) and was wondering if it was possible to use Aoyue hot tweezers on it.
Digikey has a couple options for Aoyue hot tweezers available, and although you're not really "supposed to" use them on anything other than intended Aoyue stations, I was wondering if any of you have experience/knowledge and can tell me if I can safely use any of the available options on my cheap station.
These are affordable, and the quick shipping speed (I'm about to do a digikey order anyway) makes them attractive over a Chinese option (a la Yihua 938d) *IF* it were to even work.
Below is the tweezer model numbers and the stations they are designed for.
AOT002 - 2702, 2702A+, 2703A+ AOT004 - 968A+, 701A++, N Series AOT005 - 738, 3210, N Series AOT007 - 866, 9378, N Series AOT008-P - 937+ Pro, 9378 Pro, N Series
Kindest regards!
