Текущее время: 28 мар 2024, 20:19
myth77
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 08 окт 2017, 11:37 |
Зарегистрирован: 16 фев 2017, 18:48 Наличности на руках: 12.37
Сообщения: 130 Откуда: croatia
Hi to all, hope you can help me... I have asus gl552jx...the simptoms were no power, no nothing..i replaced it8585e chip with the new one and i reprogrammed bios using some bios dump i found here on forum. The laptop now starts but no picture, i get power led and airplane led mode, nothing else, also fan is not turning on...i checked voltage on it8585e chip and i believe its ok...so i figured its probably i need to reprogramm it8585e because i soldered new one. But when i connect this programmer and i check connection its allways error 00 no power to motherboard?, even the motherboard starts and i get arround 3.3v arround it8585e chip. , First i was thinking i am doing something wrong but then i tried to connect one similar working asus board and everything was fine, the programmer connected to motherboard with no error. So, do you have any suggestions why it is not working on this motherboard? Any help is appriciated...thank you.
myth77
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 09 окт 2017, 11:29 |
ValeriyKeks писал(а): This is ASUS, no necessary to programm KBC. Just remove old KBC and set new. Then programm a flas BIOS on programmer and solder to motherboard. Power on and KBC self get to inside from flash necessary programm. If not, probably broken KBC. Maybe i was not clear...first, laptop didnt show any signs of life, i removed KBC IT8585E and order a new one. I soldered the new one, and also removed the bios, then reprogrammed it, and solder it back on the board. Now laptop is turning on but only power led and airplane led are on, no screen, and the fan is not running. So i believe new IT8585E is ok, but the laptop will not show anything on the screen...when i plug the vertyanov programmer, choose check connection (when motherboard leds are on) it will report error 00, motherboard charger not plugged in? oh, one more thing, i am using ddr3 (1.5V) memory instead of dd3l (1.35V) specific for this motherboard, but i believe it is not the problem in memory for not posting? and not reading by vertyanov programmer? ! | MSF113 писал(а): | This topic ONLY about Vertyanov_JIG! Not for notebook repair. |
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 12 окт 2017, 08:57 |
Сообщения: 14984 Откуда: Екатеринбург
Ciber SLasH писал(а): не добавлялось автоматически расширение BIN А у меня такой привычки нет. И bin на автомате мне удобно.
Uomo
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 12 окт 2017, 13:08 |
Зарегистрирован: 17 апр 2015, 13:31 Наличности на руках: 171.30
LA-C142P разьем 30 пин 0,8мм используем шлейф 26 пин что в наборе на програматоре подгоняем к 1 пину, на разьеме клавиантуры к последнему выбираем шлейф 26 пин и вуаля)) ГАЛОЧКА СТОИТLA-C142P_26PIN KSO3=12 KSI4=23 KSI7=25 KSI6=24 KSI5=21 Цитата:
Soft version --> 5.4.6414.216 Mode selected --> ENE (KB90XX) FTDI driver version 21226 Version FW JIG M328_EPM240_v20 User select --> 1 to 1 (26 pin FFC) LA-C142P_26PIN KSO3=12 KSI4=23 KSI7=25 KSI6=24 KSI5=21 Settings sent successfully!
Check GND. Connect the motherboard power adapter. We are ready for reading or writing.
12.10.2017 12:09:30 FTDI driver version 21226 Version FW JIG M328_EPM240_v20 Communication with KB90XX installed. Embedded Debug Version ID = 7
Maxim Skridonenko
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 20 окт 2017, 00:34 |
Не участник АСЦ |
Сообщения: 946 Откуда: Odessa
gregor5 писал(а): Здравствуйте! Сколько стоит комплект и стоимость пересылки в Украину? со вторника они там должны опять быть уже в дороге !
Uomo
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 23 окт 2017, 12:09 |
SergAN2 писал(а): Приветствую. Подскажите, программатор V2 умеет шить 288 через клавиатурный разъем? Да Только поляну надо будет набирать как с 9012 видео
