Текущее время: 29 мар 2024, 11:36
mastermakc
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 02 авг 2019, 09:59 |
Сообщения: 112 Откуда: Симферополь
Vertyanov_SSВсе сделал, выкладываю ALTERA SPI TEST SPI data to pins from 1 to 32 all OK Data from ALTERA (32bit): FFFFFFFFh Search ALTERA faulty lines Problems with ALTERA not detected. Soft version --> 7.8.6979.141 Mode selected --> ITE (IT8XXX) Vertyanov JIG FW_v43 2F2F7B91632DBDF165C3C665 [A506CIC3][4135303643494333] [U79”32] [553739943332FF021E10] ## JIG registered ## ********* P C B I N F O D A T A ********** PD0=7 PD1=11 PD2=13 PD3=18 PD4=14 PD5=10 PD6=17 PD7=15 BUSY=4 STB=12 AFD=1 INIT=8 SLIN=9 KSI4=5 KSI5=6 [30][DOWN][v31] User select FFC [30]pin 1to1=[OFF] Chance FFC from first pin on MB -> GOOD Chance FFC from end pin on MB -> GOOD Formula number [2] is chosen PD0=24 PD1=20 PD2=18 PD3=13 PD4=17 PD5=21 PD6=14 PD7=16 BUSY=27 STB=19 AFD=30 INIT=23 SLIN=22 KSI4=26 KSI5=25 Size embedded FLASH EC 128KB ********************************************** Settings sent successfully! Check GND. Connect the motherboard power adapter. We are ready for reading or writing. 02.08.2019 8:55:13 Vertyanov JIG FW_v43 2F2F7B91692DBDF165C3C665 [A506CIC3][4135303643494333] [U79132] [553739313332FF021E10] ## JIG registered ## Now, as soon as possible, connect the adapter (5 sec)! Check connection ... Received ITE ID -> 8586 rev -> 06 Save the file: C:\Users\MAX\Documents\ITE_.bin 02.08.2019 8:55:22 Check connection ... Received ITE ID -> 8586 rev -> 06 Init ITE ... complete. Reading, please wait ... ERROR reading block -> 1 02.08.2019 8:55:24 02.08.2019 8:55:33 Write to ITE file: C:\Users\MAX\Documents\ENE_9012.bin Loaded from file to buffer 20000h bytes. Check connection ... Received ITE ID -> 8586 rev -> 06 INIT complete. ERASE ... There may be a problem with the block: From ADR: 01800h to 01C00h [FE (FCh)] From ADR: 03400h to 03800h [FE (FCh)] From ADR: 07000h to 07400h [FF (FCh)] From ADR: 08000h to 08400h [FE (FCh)] Error erase flash or lost contact with ITE Вложение: 2019-08-02_08-58-37.png Вложение: 2019-08-02_09-00-26.png Не читает и не пишет
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 02 авг 2019, 11:08 |
Зарегистрирован: 24 май 2012, 15:34 Наличности на руках: 726.60
Сообщения: 279 Откуда: Екатеринбург
mastermakcID верный - это хорошо. Земляной кабель сделайте короче ... или перемычку от USB сделайте EC родной стоит или менялся? и что за название такое ... ENE )) Цитата: Write to ITE file: C:\Users\MAX\Documents\ENE_9012.bin
_________________ Программатор SUCCESSOR/JIG V2/3. Пост карты DDR234/NGFF_GoWin/KFCT_BIG
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 02 авг 2019, 14:53 |
mastermakcПокажите счетчики и сделайте проверку выходов. Вложение: 2367T.JPG
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 02 авг 2019, 15:27 |
mastermakc Да пины увидел - все хорошо с выходами. Счетчики по 0, Вы же недавно только новую оболочку запустили.
По вашей беде с NM-A361 могу только утверждать, что не в программаторе дело. Или в процессе работы снимается питание/часть питаний EC, кто-то "дергает" EC и выводит его из состояния ISP, дохлый/ые EC, плохая пайка ... Да и случаи дохлых 8586 были, даже 10 из 10, как это ни печально.
По поводу других MB - надо больше подробностей и разбираем каждый случай отдельно. Если есть желание разобраться - можете выслать MB или EC, только возврат (почта) за ваш счет.
PS и еще важный момент! В кадре видел проводки для питания MB.... а с пульсациями БП там как обстоят дела ?
mastermakc
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 02 авг 2019, 16:37 |
Vertyanov_SS писал(а): PS и еще важный момент! В кадре видел проводки для питания MB.... а с пульсациями БП там как обстоят дела ? С питанием все норм. я тоже подумал что плата скидывает и по проводочку 3.3в прямо на мульт подавал
merkulss
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 02 авг 2019, 19:17 |
Зарегистрирован: 05 апр 2014, 11:56 Наличности на руках: 27.10
Сообщения: 158 Откуда: Ахтубинск
Vertyanov_SS писал(а): ID он получает красивый ... шина одна На этом этапе все сигналы используются? Может ID красивый, это совпадение? Ну во всяком случае можно все IO проверить по схеме для исключения:) Я бы так поступил.
mastermakc
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 03 авг 2019, 12:10 |
merkulss писал(а): Может ID красивый, это совпадение? Когда пробовал на других платах попадались с другими ревизиями и определялся верно. E писал 5 ревизия. И 9012 шьет без проблем.
Rimas
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 05 авг 2019, 20:15 |
Зарегистрирован: 19 авг 2011, 12:17 Наличности на руках: 6,364.08
Сообщения: 1282 Откуда: Klaipeda
Здравствуйте. Для платы ASUS X302LA/LJ REV:2.0 подошла строка от: ASUS X756UA KB_pins=24 1MM KSO3=17 KSI4=16 KSI7=21 KSI6=19 KSI5=18 Первый контакт низ, с лева. Фото прибудет на форум, по позже, как накопится на несколько плат. Вложение: kbd.png
_________________ Внутри электроники находится маленький дымок. Когда он выходит в наружу - электроника неработает.
BARBOSA75
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 06 авг 2019, 13:02 |
Зарегистрирован: 15 дек 2011, 14:44 Наличности на руках: 115.93
Сообщения: 1506 Откуда: Poltava
Cuctemko писал(а): IT8665E так он на десктопах стоит?
Cuctemko
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 06 авг 2019, 13:24 |
Сообщения: 2 Откуда: 172.0.0.1
BARBOSA75 писал(а): десктопах Да. В данном случает - Asus B450 TUF Pro Gaming. Инфы по нему в интернетах никакой почти, в прошивке с сайта смущает лишних 66,0 КБ (67 584 байт) кода. -> Скорее всего прошивка мульта.
Последний раз редактировалось Cuctemko 06 авг 2019, 13:36, всего редактировалось 1 раз.
BARBOSA75
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 06 авг 2019, 13:47 |
Cuctemko писал(а): Скорее всего прошивка мульта. нет
Cuctemko
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 06 авг 2019, 14:36 |
BARBOSA75 писал(а): нет То есть шить флешку не взирая на размер файла? Верно я Вас понял? И что это может быть если не секрет?
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 06 авг 2019, 15:10 |
maxlabtможно исправить так Вложение: гуглим.JPG
GanibalVictor
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 13 авг 2019, 11:20 |
Зарегистрирован: 13 апр 2012, 11:47 Наличности на руках: 52.56
Сообщения: 456 Откуда: Благовещенск
Имеется бук gl502vm, не работает клавиатура (но иногда работает с тысячного раза включения)... был заказан ITE8171.... Впаян новый на место, имеем перепутанные буквы цифры. Заливаю в него считаную прошивку с родного, клава не работает вообще, перечитываю то что залито и то что должно быть, разные контрольные суммы... Заливаю прошивку с перепутанными буквами, итог не перешивается, хоть весь процесс на программаторе проходит успешно без каких либо жалоб... Проверено на двух ITE, история ровно повторяется как и в первом случае
Настройки программатора
GL502VM KB_pins=30 PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24
Кто нить перешивал эти ITE или я что то напутал с настройками программатора?
mastermakc
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 20 авг 2019, 10:09 |
mastermakc писал(а): merkulss писал(а): Может ID красивый, это совпадение?
Когда пробовал на других платах попадались с другими ревизиями и определялся верно. E писал 5 ревизия. И 9012 шьет без проблем. Не знаю что случилось с ноутом на котором шил все это время но на нем более не работает(систему переставлял), попробовал на другом - все ок
