Текущее время: 27 апр 2024, 13:36
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 11 сен 2019, 18:22 |
Зарегистрирован: 24 май 2012, 15:34 Наличности на руках: 731.60
Сообщения: 279 Откуда: Екатеринбург
Cinkскрин из оболочки или лог пришлите на почту Скрытие отключено:Что бы увидеть скрытое сообщение Вам необходимо зарегистрироваться и войти на форум официально
_________________ Программатор SUCCESSOR/JIG V2/3. Пост карты DDR234/NGFF_GoWin/KFCT_BIG
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 12 сен 2019, 13:06 |
It has not been written that Tetris supports 8987. It supports 8580/8585/8586/8587. 8987 has some differences. ZQK_8587 power lines 3v3 differences Вложение: ZQK_8587_3V.JPG ZAA_8987 power lines 3v3 differences Вложение: ZAA_8987_3v.JPG GND 8987 (left) VS 8587 (right) Вложение: 8587 vs 8987 gnd.JPG I had everything as you described. I began to understand and the solution is this. I used a SPIDER. 1 I cut the tracks to the contacts of the EC 3/113/122 near the spider connector. 2 I soldered jumper 106-121 on the spider connector (3v) 3 I soldered jumper 91-104 (EC) on the spider connector Do not forget about the ITE mechanism that I wrote about earlier (power-on self-programming. Options). *HERE*My Log
================================ Soft version --> 7.9.7163.63 Mode selected --> External board Vertyanov JIG FW_v43 2F2F7991732DBDF165C3C665 [AL040I60][414C303430493630] [W74594] [573734353934FF0C1F06] ## JIG registered ## ITE EC external board. Settings for external board sent successfully! 12.09.2019 13:20:46 Vertyanov JIG FW_v43 2F2F79917B2DBDF165C3C665 [AL040I60][414C303430493630] [W74594] [573734353934FF0C1F06] ## JIG registered ## Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! Save the file: C:\Users\SS_BIG\Desktop\8987\MY_OLD.bin 12.09.2019 13:20:59 Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! Init ITE ... complete. Reading, please wait ... complete. 12.09.2019 13:21:09 12.09.2019 13:21:15 Write to ITE file: C:\Users\SS_BIG\Desktop\8987\QUANTA ZAA.bin Loaded from file to buffer 20000h bytes. Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! INIT complete. ERASE ... ERASE complete. The number of bytes value of FFh -> 62610 Writing, please wait ... complete. Verify ... complete. The data is the same! 12.09.2019 13:22:30 12.09.2019 13:22:34 Vertyanov JIG FW_v43 2F2F79917B2DBDF165C3C665 [AL040I60][414C303430493630] [W74594] [573734353934FF0C1F06] ## JIG registered ## Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! Save the file: C:\Users\SS_BIG\Desktop\8987\READ_AFTER_WRITE.bin 12.09.2019 13:22:54 Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! Init ITE ... complete. Reading, please wait ... complete. 12.09.2019 13:23:04 12.09.2019 13:25:22 Vertyanov JIG FW_v43 2F2F7991712DBDF165C3C665 [AL040I60][414C303430493630] [W74594] [573734353934FF0C1F06] ## JIG registered ## Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! 12.09.2019 13:25:27 Vertyanov JIG FW_v43 2F2F7991712DBDF165C3C665 [AL040I60][414C303430493630] [W74594] [573734353934FF0C1F06] ## JIG registered ## Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! 12.09.2019 13:25:32 Vertyanov JIG FW_v43 2F2F79917B2DBDF165C3C665 [AL040I60][414C303430493630] [W74594] [573734353934FF0C1F06] ## JIG registered ## Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! 12.09.2019 13:25:39 Write to ITE file: C:\Users\SS_BIG\Desktop\8987\QUANTA ZAA.bin Loaded from file to buffer 20000h bytes. Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! INIT complete. ERASE ... ERASE complete. The number of bytes value of FFh -> 62610 Writing, please wait ... complete. Verify ... complete. The data is the same! 12.09.2019 13:26:53 12.09.2019 13:27:01 Vertyanov JIG FW_v43 2F2F79917B2DBDF165C3C665 [AL040I60][414C303430493630] [W74594] [573734353934FF0C1F06] ## JIG registered ## Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! Save the file: C:\Users\SS_BIG\Desktop\8987\READ_AFTER_WRITE2.bin 12.09.2019 13:27:23 Check connection ... Received ITE ID -> 8987 rev -> 01 INFO. Size embedded FLASH EC 128KB! Init ITE ... complete. Reading, please wait ... complete. 12.09.2019 13:27:32
gelang
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 12 сен 2019, 18:06 |
Сообщения: 0 Откуда: France
Yes, happy to know his name. Is it BIG_KB_TEST we see here? useless in this case i believe cause gl553vd has 17 pins connector. Thanks a lot sir Vertyanov, i'll contact you for purchase.
Последний раз редактировалось Vertyanov_SS 28 янв 2020, 17:05, всего редактировалось 1 раз.
Uomo
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 24 сен 2019, 12:34 |
Зарегистрирован: 17 апр 2015, 13:31 Наличности на руках: 161.30
Сообщения: 3455 Откуда: Україна, Івано-Франківськ
basta777 писал(а): как заказать? У Максима в Одессе есть в наличии.
Uomo
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 24 сен 2019, 21:15 |
Vertyanov_SS писал(а): Міша Смич Не все так просто. У Макса может и есть, но скорее всего для 3.2 прошитые, а топология 3.1 и 3.2 отличается. Втупую заменять нельзя. Таким образом, или новую впаивать или спецом под 3.1 прошитую. Контакты Макса на этом сайте - баннер второй слева висит .... В Украине это проще через Максима сделать, я это имел в виду, у вас же поставки налажены
serginio
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 26 сен 2019, 19:42 |
Зарегистрирован: 29 янв 2011, 15:23 Наличности на руках: -2.20
Сообщения: 171 Откуда: Прага
Барзанукаев Ислам писал(а): Нажмите на это поле, чтобы приблизить изображение. если нажать да то ================================ Soft version --> 7.9.7163.63 Mode selected --> Check ALTERA pin Vertyanov JIG FW_v43 85858591692DBDF165C3C665 [A506CIGL][413530364349474C] [U79132] [553739313332FF032427] ## JIG registered ## ALTERA SPI TEST SPI data to pins from 1 to 32 error, pin 1 error, pin 2 error, pin 3 error, pin 4 error, pin 5 error, pin 6 error, pin 7 error, pin 8 error, pin 9 error, pin 10 error, pin 11 error, pin 12 error, pin 13 error, pin 14 error, pin 15 error, pin 16 error, pin 17 error, pin 18 error, pin 19 error, pin 20 error, pin 21 error, pin 22 error, pin 23 error, pin 24 error, pin 25 error, pin 26 error, pin 27 error, pin 28 error, pin 29 error, pin 30 error, pin 31 error, pin 32 Detected problems with the chip. ALTERA is damaged and needs to be replaced or fw update. My email: VertyanovSS@gmail.comДобрый день! Аналогичная проблема , сбросите инструкцию ?
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 30 сен 2019, 09:35 |
plotyWrite me the serial number of the programmer or the log from the shell More or less like this Цитата: [A506CIGL][413530364349474С] [U79132] [553739313332FF932427]
Vertyanov_SS
Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG) Добавлено: 30 сен 2019, 13:00 |
ploty писал(а): [AH05RK8X][41483035524B3858] [U81389] [553831333839FF0B0619] 30-09-2019 09:40:43 FTDI driver version 21228 Version FW JIG M328_EPM240_v34 2F2F7B91632DBDF165C3C665
Why are you showing edited texts? I answered already in the mail that you bought a fake. Why should I provide technical support? You were offered a way out of the situation. PS Интуиция мне подсказала и я не ошибся. Клон и без регистрации )) Еще и текст корректировался. ---------- Добавлено спустя 19 минут 25 секунд: ---------- this is what the uncorrected text looks like Цитата: Soft version -->> 7.9.7163.63 Mode selected -->> ITE (IT8XXX) Vertyanov JIG FW_v43 2F2F7B91632DBDF165C3C665 [AH05RK8X][41483035524B3858] [U81389] [553831333839FF0B0619] ## JIG not registered! ## on/off counter=14
and this part from the old version is added Цитата: Version FW JIG M328_EPM240_v34 2F2F7B91632DBDF165C3C665
