TE69 (bios help) Z5WT3 Bios https://vlab.su/viewtopic.php?f=172&t=33092 |
tarum2003 [ 06 июн 2015, 21:36 ] | |
Заголовок сообщения: | TE69 (bios help) Z5WT3 Bios |
i need a bios for this brand and model packard bell te69-bm model:z5wt3 hdd is damaged and does not work. i can not install win 7 to new hdd. i faced such error message "CHECKING MEDIA" i can't make disabled "secure boot" and can't bios update. how can i solve this issue? can i update bios by a usb disk or is there any bios file which one is already disabled secure boot? I tried one of bios files here but there was no screen on notebook. thnx in advance and have a successful days to everyone. matherbord: Z5WE3 La-A621P rev:1.0 bios : 25q64fe |
andromedax [ 07 июн 2015, 20:23 ] | |
Заголовок сообщения: | Re: TE69 (bios help) Z5WT3 Bios |
tarum2003 писал(а): how can i solve this issue? can i update bios by a usb disk or is there any bios file which one is already disabled secure boot? You must use an external programmer. |
tarum2003 [ 10 июн 2015, 15:23 ] | |
hi, i already have ext programmer (Mini Pro TL866) I just didn't find comparible bios and i found some bios but there is no screen when i use program that bios. i need exact bios file thnx in advance |
ortakatro [ 03 июл 2015, 16:49 ] | |
Only you can with an external programmer |
andromedax [ 04 июл 2015, 23:34 ] | |
tarum2003 писал(а): how can i solve this issue? can i update bios by a usb disk or is there any bios file which one is already disabled secure boot? have you tried to boot from a win-8 64 bits install dvd? If you manage to boot from it, perhaps you could update bios from the command prompt within win-8 install enviroment. It has to be 64 bits version. |
yarikqqq [ 03 сен 2015, 21:11 ] | |
please give me your BIOS dump |
