P5WS0 (la-6901p) no cpu core voltage https://vlab.su/viewtopic.php?f=172&t=63137 |
scobay [ 01 июл 2017, 04:05 ] | |
Заголовок сообщения: | P5WS0 (la-6901p) no cpu core voltage |
Hi Laptop has black screen initially found +5vs to be 2.3v (bad cap), replaced now fan spins still black screen but still no +CPU_CORE voltage. PU12 vin is 19v Vdd is 5v VR_ON is 3.3v Any help appreciated |
morik59 [ 01 июл 2017, 10:05 ] | |
Заголовок сообщения: | Re: P5WS0 (la-6901p) no cpu core voltage |
scobay писал(а): found +5vs to be 2.3v (bad cap) Look to R372, must be 19V. |
scobay [ 01 июл 2017, 15:24 ] | |
Hi +5vs is ok, the problem is there is no +CPU_Core voltage. I changed PU12 ISL95831CRZ-T also but still no out put from it. What else does it need in order to output +CPU_CORE?. |
morik59 [ 01 июл 2017, 15:31 ] | |
Read this http://notebook1.ru/forma1/viewtopic.php?f=231&t=81673 ---------- Добавлено спустя 7 минут 45 секунд: ---------- scobay писал(а): What else does it need in order to output +CPU_CORE?. 1. 1.5VS, 3VS, 5VS - p.43 2. U20 3. U33. |
scobay [ 01 июл 2017, 17:01 ] | |
HI thanks for the info. +5vs,+3vs, 1.5vs, +3ALW_PCH,+5ALW_PCH all are present. The SIO U20 was very hot so I changed the KB930QF to a KB3930qf. |
