Asus X42F https://vlab.su/viewtopic.php?f=177&t=13454 |
ayad [ 26 май 2013, 15:11 ] | |
Заголовок сообщения: | Asus X42F |
Hi all, I have Asus X42F , A resistance is damaged , I do not know its value please any one could help me to find that laptop's schematics and thanks very much..... |
SashaZmei [ 26 май 2013, 15:14 ] | |
Заголовок сообщения: | Re: Asus X42F |
Can you take the large photo of problem region ? |
ayad [ 26 май 2013, 15:30 ] | |
that resistance is located at the right upper corner of IC RTS1520.... |
SashaZmei [ 26 май 2013, 16:32 ] | |
If you will attach the large photo of this region may be it will be possible to help you |
ayad [ 26 май 2013, 16:34 ] | |
I shall try... |
ayad [ 26 май 2013, 17:10 ] | |
I think there is another problem , its bios chip may be damaged , so I have to find its bios too...... |
SashaZmei [ 26 май 2013, 17:31 ] | |
What is the motherboard platform ? What exact is wrote on board ? |
SashaZmei [ 26 май 2013, 18:33 ] | |
The BIOS can download HERE |
ayad [ 27 май 2013, 09:05 ] | |
I have downloaded the BIOS and the laptop now is working properly, but no charging.... |
SashaZmei [ 27 май 2013, 10:00 ] | |
First of all check the battery's adge contacts, they may have at least 8V If the battery is completelly dead it will not be charging |
ayad [ 27 май 2013, 14:37 ] | |
Заголовок сообщения: | Re: Asus X42F [РЕШЕНО] |
I shall do that test soon..... |
