https://vlab.su/
Взаимозаменяемость ШИМов питания
https://vlab.su/viewtopic.php?f=178&t=3734
Страница 2 из 24
Slavikus [ 05 окт 2012, 00:10 ]
Заголовок сообщения:  Re: Взаимозаменяемость ШИМов питания
Mobimas писал(а):
В поисках Richtek RT8202 обнаружилось сходство с UP6111AQDD . Последняя стоит в Acer Aspire One (ZG8).
Такая же распиновка UP6128A
Описание функций
1. Wide Input Voltage Range 2V ~ 26V
2. Wide Output Voltage Range 0.75V ~ 5.5V, 1.0% Initial Accuracy
3. Constant On Time PWM : Quasi Constant Switching Frequency; Adjustable Frequency from 200kHz to500kHz; Ultra Fast Transient Response
4. Integrated Bootstrap Diode
5. Integrated MOSFET Drivers with Shoot-Through Protection
6. Configurable Forced Continuous Current Mode or Power Saving Mode
7. Lossless, Programmable Overcurrent Protection Use Low-Side MOSFET RDS(ON)
8. Internal Soft Start
9. Over Voltage and Under Voltage Protection
10. Power OK Indication
11. WQFN4x4 - 16L, WQFN3x3 - 16L, VQFN3.5X3.5 - 14L, or TSSOP - 14L Packages
12. RoHS Compliant and 100% Lead Free
產品特性 1. The uP6128A/B is a high performance synchronous-rectified buck controller specifically designed for POL voltage
regulation in notebook PC application. The controller operates with 5V bias voltage and converts 2V~26V input
voltage to 0.75V~5.5V output voltage.
2. The uP6128A/B adopts constant-on-time PWM scheme that features easy-to-use, low external component count,
fast transient response and quasi constant frequency operation over the operation range. Selectable Forced
Continuous Conduction Mode (FCCM) or Power Saving Mode (PSM) enables the flexibility for low noise operation
or high efficiency conversion over wide output current range.
3. Lossless current sensing by RDS(ON) of lower switch achieves programmable over current protection. Other
features include internal soft start, integrated bootstrap diode and thermal shutdown. The uP6128A is available in
WQFN3x3 -16L and WQFN4x4-16L packages.
4. The uP6128B is available in VQFN3.5x3.5- 14L and TSSOP- 14L packages.
產品應用 1. Power Supplies for Microprocessors or Subsystem Power Supplies
2. Cable Modems, Set Top Boxes, and DSL Modems
3. Industrial Power Supplies; General Purpose Supplies
4. 2V to 26V Input DC-DC Regulators
5. Low-Voltage Distributed Power Supplies
Еще аналог G5602R41U применяемый в схеме от Quanta HK5
G5602R41U.7z
Slavikus [ 10 окт 2012, 10:14 ]
Ciber SLasH писал(а):
MAX8778=MAX17020, ISL6236, ISL6236A, PM6686, RT8206A, SN0608098 - взаимозаменяемы между собой.
HP DV6940er - Quanta AT3 Rev. F - стоит ISL6236 (по схеме MAX8778).
Еще аналог SN0806081 RHBR QFN32 5x5 применяется в Compal LA-5911P
SN0806081RHBR_QFN32_5x5.rar
тагансити [ 10 окт 2012, 13:50 ]
Еще аналог SN0806081 RHBR QFN32 5x5 применяется в Compal LA-5911P...
Ну, вот и свалили всё в одну кучу...
Надо всё-таки внести какую-то ясность.
Во-первых, о терминологии.
Понятия "аналог" и "взаимозаменяемо" не есть одно и то же.
Аналог подразумевает полное функциональное и выводное совпадение (так сказать, но-га-вно-гу). Например, разные фирмы могут выпускать один и тот же прибор, но под разными названиями.
Взаимозаменяемость - более широкое понятие. Например, некоторые приборы почти совпадают по цоколёвке (скажем, отличаются одним из выводов функционально), но могут использоваться для взаимной замены там, где этот вывод не используется.
Хотелось бы точности - чтобы было ясно, о чём идёт речь в каждом посте этой темы: где о взаимозаменяемости, а где приводятся аналоги. И там, где приборы не являются полными аналогами, нужно указывать: "взаимозаменяемо там-то и там-то".
Отсутствие подобной точности вносит некоторую путаницу.
Это, так сказать, умные рассуждения. Теперь конкретно по вышеприведённому списку.
Не претендую на абсолютную точность, но хочу разграничить список на аналоги, и упомянуть о взаимозаменяемости внутри него.
Аналогами согласно даташитов (а, где они не доступны - согласно анализу схем включения на конкретных платформах) являются:
1. TPS51427(A) = SN0806081
2. MAX8778=MAX17101=MAX17020=PM6686=SN608098=ISL6236(A)
Замечу, что "из-за наличия отсутствия" даташитов на SN608098, SN0806081 анализ их включения проводился по схемам MBX-215 и LA-5911P, а для MAX8778 (из даташита на MAX17020) - «The MAX17020 is a pin-for-pin replacement of the MAX8778».
Теперь о мелочах.
Главное отличие между 1, 2 строчками - вывод 20. Для первой - он "NC" (не используется), для второй - это вывод SECFB (CP_FB), который мониторит 14-вольтовый выход "Charge Pump", и не даёт там упасть напряжению ниже порога. Соответственно, в схемах, где данная м\с не формирует выходные 14 вольт , обе строчки взаимозаменяемы.
ISL6237 взаимозаменяема с первой строчкой там, где выход LDO 3.3V (вывод 5) в схеме не используется (в данной м\с он "NC").
RT8206А,B не являются аналогами для обеих строк, но могут использоваться для взаимозаменяемости с ними в конкретных случаях.
RT8206А функционально ближе ко второй строке, но в ней, в отличие от всей линейки, не используются выводы 5, 8 (оба "NC").
RT8206B функционально самая кастрированная – в ней не используются все три вывода 5, 8, 20.
Для удобства данные о различающихся выводах сведены в Таблицу:
Можно предполагать, что с соответствующей доработкой все эти м\с могут быть использованы для взаимной замены (причём, в тех схемах, где выв.7 LDO фиксированный 5 вольт, а выв. 5 (LDO 3.3в) не используется, могут работать и RT8206A,B).
Slavikus [ 10 окт 2012, 15:01 ]
Ну конечно проведеный ШИМ нельзя без даташита от производителя назвать полным аналогом той или иной микросхемы, и все конечно зависит в какой схеме эти микросхемы применяются и какие выводы используются, а в кучу свалены, так сказать для дальнейшей отбраковки зЁрен от плевел, методом подробного сравнения схем и даташитов, что с помощью, вами же приведенной, таблицы и продемонстрировано. За взаимозаменяемость ШИМов питания всех рас и народов :-)
Ciber SLasH [ 09 ноя 2012, 19:00 ]
P2806, G5934 - аналоги (спасибо siberian)
Ciber SLasH [ 15 ноя 2012, 18:09 ]
OZ8111, OZ8116, OZ8118 - аналоги
В схеме Quanta NE7 показана OZ8111LN, но выводы подписаны от OZ8116.
В схеме Quanta ZR6 показана OZ8111, но страница озаглавлена, как OZ8118
Slavikus [ 15 ноя 2012, 19:24 ]
Взаимозаменяемы только отличаются мощностью в разы,то есть не для каждой схемы замена корректна, хотя для ноутов прокатит.
OZ8116
тагансити [ 17 ноя 2012, 06:09 ]
Несколько слов о взаимозаменяемости SC475A и НЕвзаимозаменяемости SC471 и SC471A.
Указанные м\с имеют идентичную распиновку, и выходные полевые ключи с открытым истоком D0 (D1), управляемые входами G0 (G1).
В схемах включения эти ключи используются для регулирования номинала выходного напряжения:
Причём,
для SC471 входы G0,G1 - прямые, а для SC471A - инверсные (в SC471 ключи D0,D1 открываются "единицей", а в SC471A - нулём),
SC475A имеет только один канал - G0,D0 с инверсным управлением.
Соответственно, SC475A может быть с успехом заменена на SC471A в любой схеме (нужно только следить, чтобы на плате неиспользуемый вывод 7 SC475A не был бы случайно подключён куда-либо , ибо для SC471A это - выход D1).
Совершенно понятно, что SC471 и SC471A - не взаимозаменяемы без инверсии входных сигналов G0,G1.
Впрочем, для мьсе, знающих толк в извращениях, это не помеха - при желании, можно впихнуть по входам G0,G1 два N-полевика с пуллапами на стоках...
тагансити [ 30 ноя 2012, 08:58 ]
jak_root писал(а):
BP1IG <==> BP9ZA <==> BP0QA
SY8033BDBC_DFN10_3X3
Список можно расширить:
BP0QA
BP1BE
BP1GG
BP1IG
BP9ZA
Не думаю, что этим список исчерпывается...
Дополнение взято со страниц этого же и соседнего форумов.
SashaZmei [ 18 дек 2012, 14:36 ]
TPS51216 есть ли ему замена ?
KotLove [ 20 дек 2012, 15:29 ]
G5603 успешно поменяна на TPS51117 на LA-6552P (Формировала +1.1VALWP).
SashaZmei [ 26 дек 2012, 13:15 ]
PM6686 успешно заменен на TPS51427
тагансити [ 26 дек 2012, 16:35 ]
Сначала внимательно читаем то, что уже написано, потом думаем, будет ли полезна информация, и нужно ли писАть...
Doc [ 19 янв 2013, 20:36 ]
TPS51117RGY (корпус QFN) = APW7141QAITRG
по схемe Samsung R525 Bremen-D стоит APW7141QAITRG, физически - TPS51117RGY; была снесена (отверткой?) вокруг него обвязка, успешно восстановлена по схеме
galexey [ 20 янв 2013, 14:49 ]
tps51620 и tps51621 аналоги? На схеме LA-5082P нарисован tps51620, на плате стоит tps51621.
тагансити [ 20 янв 2013, 16:17 ]
Что-то непонятно, где Вы смотрите... К Вам плата не из пионерсервиса пришла? :-):
Даже из простого сравнения схем включения - цоколёвка ну, ни разу не совпадает!
galexey [ 21 янв 2013, 10:03 ]
Говорят, что была в двух московских сервисах. Удивительно, что проц остался жив после таких экспериментов.
Zet [ 26 янв 2013, 00:05 ]
Я вот хочу спросить:
-а имеет-ли смысл городить такую базу маркировки ШИМов,
или все и так все знают ?
RsM [ 26 янв 2013, 11:08 ]
Оч удобно, но мне лень рисовать :-):
Zet [ 28 янв 2013, 18:17 ]
RsM писал(а):
......... но мне лень рисовать :-):
Мне тоже , я что делать.
Подумалось - может сообща.
pipkata [ 30 янв 2013, 11:59 ]
MAX17415 меняется на MAX17015 (информация от VolosKR)
Asus G60JX
MAX17415 меняется на MAX17015 тоже проверил. Работает нормально.
тагансити [ 31 янв 2013, 01:33 ]
Во многих китайских планшетах и нетбуках попадается простейший ШИМ преобразователь - восьминогая планарка в самом простом корпусе SOP-8 с маркировкой 2952 или 2952a.
Это чудо - AP2952A:
AP2952A.RAR
имеет аналог - FT484:
FT484.RAR
Есть и второй - MP1410, но нужно учитывать, что он - без софтстарта (выв. 8 не используется), и имеет немного другие номиналы в обвязке (см. даташит).
MP1410.RAR
Yuriy_M [ 07 мар 2013, 05:00 ]
RT9045 <= APL5336 ( VTT DDR )
Замена была на Asus N53T
Serrj [ 10 мар 2013, 00:34 ]
MB39A126 => MB39A129
На (Clevo 6-71-m57r0-d05 gp) от (Lenovo ideapad s10-2 DAOFL1MB6FO REV:F_ )
Стартовал только от зарядки.
Теперь стартует и с батареей.
НО !!! За всю ночь, батарею зарядил только на 3% в (Win) !!!!
Разобраться не успел, бук забрали.
siberian [ 10 мар 2013, 09:24 ]
Serrj писал(а):
MB39A126 => MB39A129...
Разве это можно считать удачной заменой?
Dwit [ 27 апр 2013, 16:49 ]
На что можно поменять ISL6265C и TPS51123A
тагансити [ 27 апр 2013, 17:16 ]
Осмелюсь спросить - Вы эту тему-то читали?
Простите, но это - неуважение к тем, кто делится (в т. ч. с Вами) своими знаниями, и тратит время на написание информативных постов - Вы же, даже их не читая, задаёте вопрос, на который ответ давным-давно дан...
Конкретно - о заменяемости TPS51123A есть инфа как минимум в двух постах этой темы.
Лень читать или воспользоваться поиском???
Zet [ 05 июн 2013, 21:32 ]
HPA00835RTER === tps54418
вывод сделан на основании сравнения матери и схемы
ZH9 схеме одно , а на плате другое
RsM [ 19 июн 2013, 10:11 ]
На Samsung NP350V5C, платформы LA-8861P, LA-8862P
взаимозаменяемы между собой: APW8812, RT8205L, TPS51125
Первые две идут штатно.
siberian [ 19 июн 2013, 11:44 ]
RsM писал(а):
RT8205L=TPS51125
Ни разу не равно! Может в какой-то конкретной схеме...
Страница 2 из 24 Часовой пояс: UTC + 4 часа
http://www.phpbb.com/
