здравствуйте подскажите пожалуйста аналог fdms 7692 , стоит в верхнем ? плече max17811gtl , на питание процессора ( hp4535) , в паралель стоят 2 пары ( fdms 7692 и FDMS0310AS) . VDS 30 V VGS Gate to Source Voltage ±20 V ID Drain Current -Continuous (Package limited) TC = 25 °C 28A Continuous (Silicon limited) TC = 25 °C 47 -Continuous TA = 25 °C (Note 1a) 14 -Pulsed 50 PD Power Dissipation TC = 25 °C 27W Power Dissipation TA = 25 °C (Note 1a) 2.5 rDS(on) Static Drain to Source On Resistance VGS = 10 V, ID = 13 A 6.5- 7.5 VGS = 4.5 V, ID = 10 A 9.5-13 mΩ VGS = 10 V, ID = 13 A, TJ = 125 °C 9.0 11 в чип и дип есть IRFH5304TR2PBF и много IRF . отличия в Qg Total Gate Charge , и еще много где . голова идет кругом . ---------- Добавлено спустя 1 час 16 минут 9 секунд: ---------- IRFH8334TR2PBF я вот к этому варианту склоняюсь . Скажите пойдет ? VDS Drain-to-Source Voltage 30 VGS Gate-to-Source Voltage ± 20 ID @ TA = 25°C Continuous Drain Current, VGS @ 10V 14 ID @ TA = 70°C Continuous Drain Current, VGS @ 10V 12 ID @ TC(Bottom) = 25°C Continuous Drain Current, VGS @ 10V 44 ID @ TC(Bottom) = 100°C Continuous Drain Current, VGS @ 10V 28 ID @ TC = 25°C Continuous Drain Current, VGS @ 10V (Source Bonding Technology Limited) 25 IDM Pulsed Drain Current � 100 PD @TA = 25°C Power Dissipation 3.2 PD @TC(Bottom) = 25°C Power Dissipation Linear Derating Factor W/°C 30 TJ Operating Junction and TSTG Storage Temperature Range -55 to + 150 gfs Forward Transconductance 44 ––– ––– S Qg Total Gate Charge ––– 15 ––– nC Qg Total Gate Charge ––– 7.1 –––nC Qgs1 Pre-Vth Gate-to-Source Charge ––– 2.5 –––nC Qgs2 Post-Vth Gate-to-Source Charge ––– 1.0 –––nC Qgd Gate-to-Drain Charge ––– 2.3 –––nC Qgodr Gate Charge Overdrive ––– 1.3 –––nC Qsw Switch Charge (Qgs2 + Qgd) ––– 3.3 –––nC Qoss Output Charge ––– 5.7 ––– nC RG Gate Resistance ––– 1.2 ––– Ω td(on) Turn-On Delay Time ––– 8.3 ––– tr Rise Time ––– 14 ––– td(off) Turn-Off Delay Time ––– 7.0 ––– tf Fall Time ––– 4.6 ––– Ciss Input Capacitance ––– 1180 ––– Coss Output Capacitance ––– 260 ––– Crss Reverse Transfer Capacitance ––– 110 Diode Characteristics IS Continuous Source Current 25А (Body Diode) ISM Pulsed Source Current 100А (Body Diode) VSD Diode Forward Voltage ––– ––– 1.0 V trr Reverse Recovery Time ––– 13-20 ns Qrr Reverse Recovery Charge ––– 19-29 nC ton Forward Turn-On Time Time is dominated by parasiti
а проблема была такая , ноут залили , или потекла встроенная в мать батарея , было найдено обрыв дороги от аккамулятора через 100кОм на max17811( заменил и резюк 100кОм , и max ) пробой одного из мосфетов fdms7692 питание+VAPU_VDD ( заменил на IRFH5304TR2PBF, заменил только один , их 2 пары , возможно в этом ошибка ) , не было питания 1.1 А ( пробой мосфета , и замена TPS551218 ) , также заменил мост ,не было питания биоса ( 2В вместо 3В) обрыв дороги . Ноут запустился , но без изображения , нашел обрыв дороги по питанию дисплея . Ура он запустился ! прошел все встроенные тесты , но винда не грузиться , постоянно висит надпись виндос и потом ошибка драйвера питания , прошил биос , то же самое . Уже думал отдать так , но решил померить питание +VAPU_VDD на проце ( где был заменен один транзистор и оно прыгало на 0.2 - 0.3 В ) , пропаял заменненую max и питание проца пропало ( . Поставил вторую max , питания по прежнему не было , дотронулся рукой до корпуса max ? диод стал постоянно моргать ( видать чего то замкнул ) , или статика , короче случилось к.з . сгорело проц , 2 fdms7692 , 2 кондера и опять max . куплено все кроме транзисторов . нужна помощь в подборе . идеально магазин чип и дип или вноутбуке ( метро Дубровка )
