What can I replace the rubber dissipating heat from chip sets? https://vlab.su/viewtopic.php?f=181&t=26332 |
eletmoraes [ 15 ноя 2014, 18:35 ] | |
Заголовок сообщения: | What can I replace the rubber dissipating heat from chip sets? |
Several times to remove the heatsink from the CPU or chip-set flexible rubber spends, what could I use to replace either technique to dissipate heat from the CPU and the north and south chip-set? |
odmindib [ 15 ноя 2014, 18:53 ] | |
Заголовок сообщения: | Re: What can I replace the rubber dissipating heat from chip sets? |
something like this http://ru.aliexpress.com/item/Free-ship ... 18363.html |
eletmoraes [ 15 ноя 2014, 20:27 ] | |
yes , friend , thanks |
