Текущее время: 14 июн 2024, 00:21
Страница 1 из 1 [ 1 сообщение ] |
InjutkinAG
Заголовок сообщения: PlayStation 4 FAT SAA-001 [РЕШЕНО] Добавлено: 11 апр 2023, 17:57 |
Сообщения: 61 Откуда: Москва
Сонька в вечной синьке, инициализации соответственно нет, ранее делали реболл на ней, кто не знаю. Считал дамп, активировал UART и немного прифигел от лога.
msk0: PHY FIFO underrun/overflow.
secure loader build: Jun 8 2021 05:20:42 (r10426:release_branches/release_08.520) [711MHz]AGESA: ThebePBDK W5C21 963 msec[BOOT TIME] SAMU: 1378 msec: enter[BOOT TIME] SAMU: 2348 msec: leaveAGESA: ThebePBDK_3.1.0.70908 SAMU: W5C21 SIE CONFIDENTIAL Copyright (C) 2021 Sony Interactive Entertainment Inc. All Rights Reserved. Copyright (c) 1992-2012 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. r174732/release_branches/release_08.520 Jun 8 2021 05:27:23 amd64 mDBG: Kernel Build ID = 8886cd5b8b34a937 CPU: DG1000FGF84HT (1594.00-MHz K8-class CPU) Origin = "AuthenticAMD" Id = 0x710f13 Family = 16 Model = 11 Stepping = 3 Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT> Features2=0x36d8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,AVX,F16C> AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM> AMD Features2=0x154837fb<LAHF,CMP,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,NodeId,Topology,PerfCtrExtNB,<b26>,<b28>> TSC: P-state invariant, performance statistics Event timer "LAPIC" quality 400 ACPI APIC Table: <SIE ORBIS > FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs FreeBSD/SMP: 1 package(s) x 8 core(s) cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 cpu2 (AP): APIC ID: 2 cpu3 (AP): APIC ID: 3 cpu4 (AP): APIC ID: 4 cpu5 (AP): APIC ID: 5 cpu6 (AP): APIC ID: 6 cpu7 (AP): APIC ID: 7 MADT: Could not find APIC for SCI IRQ 9 Memory mode: 4: BC8 release BigApp memory : 0x0000000148000000 bytes (5248MiB) FMEM (max) : 0x0000000020000000 bytes ( 512MiB) MiniApp DMEM : 0x0000000030000000 bytes ( 768MiB) VSH DMEM : 0x000000001a800000 bytes ( 424MiB) Trace memory & Trace DMEM : 0x0000000000000000 bytes ( 0MiB) Vision memory : 0x0000000001000000 bytes ( 16MiB) Reserved memory : 0x0000000011a00000 bytes ( 282MiB) Flexible memory(SYSTEM) : 0x000000004caac000 bytes (1227MiB) BIOS memory size : 0x00000000011b8000 bytes ( 18MiB) Kernel static size : 0x000000000d19c000 bytes ( 210MiB) [REGMGR] 000001 ... acpi0: <SIE ORBIS> on motherboard cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 cpu4: <ACPI CPU> on acpi0 cpu5: <ACPI CPU> on acpi0 cpu6: <ACPI CPU> on acpi0 cpu7: <ACPI CPU> on acpi0 pcib0: <ACPI Host-PCI bridge> on acpi0 pci0: <ACPI PCI bus> on pcib0 pci0: found pcie_glue iommu0: <AMD IOMMU> on pci0 gc0: <Starsha> on pci0 LVP B2.1 # use 0x00000000 as mmGB_ADDR_CONFIG value GC SE0 Redundant CU: 0x200 GC SE1 Redundant CU: 0x200 GC SE2 Redundant CU: 0x0 GC SE3 Redundant CU: 0x0 SClkVid:0x3c SClkDpmVid:3 Dpm:3 Vid:0x3c hdac0: <GPU/DEHT Audio Controller> on pci0 apcie0: <Aeolia PCI Express glue> on pci0 apcie0: Chip revision: 00000300 apcie0: Chip ID0: 33c30130 apcie0: Chip ID1: 531310fe icc0: <Aeolia ICC> on pci0 hpet_pci0: <Aeolia High Precision Event Timer> on pci0 Timecounter "HPET" frequency 10000000 Hz quality 950 Event timer "HPET" frequency 10000000 Hz quality 450 Event timer "HPET1" frequency 10000000 Hz quality 450 Event timer "HPET2" frequency 10000000 Hz quality 450 Event timer "HPET3" frequency 10000000 Hz quality 450 sflash0: <Aeolia Serial Flash I/F> on pci0 sflash0: Macronix(c2) rtc0: <Aeolia RTC> on pci0 timer_mvl0: <Aeolia Timer/WDT> on pci0 uart0: <Non-standard ns8250 class UART with FIFOs> on pci0 uart0: uart_bus_attach uart0: console (115200,n,8,1) twsi0: <Aeolia TWSI> on pci0 ahci0: <Orbis Aeolia AHCI SATA controller> on pci0 ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahci0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f ahci0: AHCI v1.30 with 1 3Gbps ports, Port Multiplier supported with FBS ahcich0: <AHCI channel> at channel 0 on ahci0 iommu_add_device_table_entry: device_id:00a2 dev:1 func:1 ahcich xhci0: <Aeolia XHCI USB 3.0 controller> on pci0 xhci1: <Aeolia XHCI USB 3.0 controller> on pci0 iommu_add_device_table_entry: device_id:00a7 dev:20 func:7 xhci Initial IO PTB alloc. device:0xa7 io:0xa000000 usbus1 on xhci1 xhci2: <Aeolia XHCI USB 3.0 controller> on pci0 acpi_ssb0: <Aeolia acpi> on pci0 mskc0: <Aeolia GBE controller> on pci0 iommu_add_device_table_entry: device_id:00a1 dev:20 func:1 mskc msk0: <Aeolia GBE Id:0xbd Rev:0x01> on mskc0 eth0: Ethernet address: 70:9e:29:c3:5e:71 sdhci0: <Aeolia SDHCI> on pci0 iommu_add_device_table_entry: device_id:00a3 dev:20 func:3 sdhci sdhci0: 1 slot(s) allocated dmac0: <Aeolia DMA1 controller> on pci0 iommu_add_device_table_entry: device_id:00a5 dev:20 func:5 dmac dmac1: <Aeolia DMA2 controller> on pci0 spm0: <Aeolia Scratch Pad Memory> on pci0 sbram0: <Aeolia DDR3 memory> on pci0 dct0: <SCE DCT driver> on hostb4 sbi0: <SCE SBI driver> on hostb5 gbase_register_interrupt_handler(52) gbase_register_interrupt_handler(53) dce: 23 hwpstate0: <Cool`n'Quiet 2.0> on cpu0 _sdma_hw_init(0): microcode loaded _sdma_hw_init(1): microcode loaded acpDecFlac: <Codec DecFlac built on Jun 8 2021 05:26:35> acpDecOpus: <Codec DecOpus built on Jun 8 2021 05:26:35> ajm: <Audio CoProcessor Job Manager built on Jun 8 2021 05:26:33> acpDecMp3: <Codec DecMp3 built on Jun 8 2021 05:26:31> acpDecAt9: <Codec DecAt9 built on Jun 8 2021 05:26:35> acpDecM4aac: <Codec DecM4aac built on Jun 8 2021 05:26:35> acpEncM4Aac: <Codec EncM4Aac built on Jun 8 2021 05:26:35> acpDecCelp8: <Codec DecCelp8 built on Jun 8 2021 05:26:35> acpEncCelp8: <Codec EncCelp8 built on Jun 8 2021 05:26:35> acpDecAc3: <Codec DecAc3 built on Jun 8 2021 05:26:35> acpEncAc3: <Codec EncAc3 built on Jun 8 2021 05:26:35> acpDecTrhd: <Codec DecTrhd built on Jun 8 2021 05:26:35> acpDecM2bc: <Codec DecM2bc built on Jun 8 2021 05:26:35> acpEncDts: <Codec EncDts built on Jun 8 2021 05:26:35> acpDecM4aacfng: <Codec DecM4aacfng built on Jun 8 2021 05:26:35> acpDecCelp: <Codec DecCelp built on Jun 8 2021 05:26:35> acpEncCelp: <Codec EncCelp built on Jun 8 2021 05:26:31> acpDecVorbis: <Codec DecVorbis built on Jun 8 2021 05:26:35> acpEncOpusCelt: <Codec EncOpusCelt built on Jun 8 2021 05:26:35> acpDecOpusCelt: <Codec DecOpusCelt built on Jun 8 2021 05:26:35> acpEncOpusSilk: <Codec EncOpusSilk built on Jun 8 2021 05:26:35> acpDecOpusSilk: <Codec DecOpusSilk built on Jun 8 2021 05:26:35> acpUtlSrc: <Codec UtlSrc built on Jun 8 2021 05:26:35> UVFAT_Initialize: exit Timecounters tick every 1.000 msec Session ID: ebe3a871634f3c303ba8942b7f649141 g_lvusbus1: 5.0Gbps Super Speed USB v3.0 msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow. msk0: PHY FIFO underrun/overflow.
Причем данная ошибка идет бесконечно msk0: PHY FIFO underrun/overflow. очень похоже на неисправность процессора или ПО Хотя по ПО чек лист Final Count: OK: 604 Warning: 0 Danger: 0 Unlisted: 0 ---- Быстрое дополнение, PHY FIFO хз как это связано, упоминание данного значения есть протоколе LAN, снял Internet контроллер. Ситуация изменилась. Теперь консоль переходит в белый
secure loader build: Jun 8 2021 05:20:42 БЕЛЫЙ ОГОНЬ
secure loader build: Jun 8 2021 05:20:42 (r10426:release_branches/release_08.520) [711MHz]AGESA: ThebePBDK W5C21 983 msec[BOOT TIME] SAMU: 1369 msec: enter[BOOT TIME] SAMU: 2360 msec: leaveAGESA: ThebePBDK_3.1.0.70908 SAMU: W5C21 SIE CONFIDENTIAL Copyright (C) 2021 Sony Interactive Entertainment Inc. All Rights Reserved. Copyright (c) 1992-2012 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundatio800000 bytes ( 424MiB) Trace memory & Trace DMEM : 0x0000000000000000 bytes ( 0MiB) Vision memory : 0x0000000001000000 bytes ( 16MiB) Reserved memory : 0x0000000011a00000 bytes ( 282MiB) Flexible memory(SYSTEM) : 0x000000004cb84000 bytes (1228MiB) BIOS memory size : 0x00000000011b8000 bytes ( 18MiB) Kernel static size : 0x000000000d0c4000 bytes ( 209MiB) [REGMGR] 000001 ... acpi0: <SIE ORBIS> on motherboard cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 cpu4: <ACPI CPU> on acpi0 cpu5: <ACPI CPU> on acpi0 cpu6: <ACPI CPU> on acpi0 cpu7: <ACPI CPU> on acpi0 pcib0: <ACPI Host-PCI bridge> on acpi0 pci0: <ACPI PCI bus> on pcib0 pci0: found pcie_glue iommu0: <AMD IOMMU> on pci0 gc0: <Starsha> on pci0 LVP B2.1 # use 0x00000000 as mmGB_ADDR_CONFIG value GC SE0 Redundant CU: 0x200 GC SE1 Redundant CU: 0x200 GC SE2 Redundant CU: 0x0 GC SE3 Redundant CU: 0x0 SClkVid:0x3c SClkDpmVid:3 Dpm:3 Vid:0x3c hdac0: <GPU/DEHT Audio Controller> on pci0 apcie0: <Aeolia PCI Express glue> on pci0 apcie0: Chip revision: 00000300 apcie0: Chip ID0: 33c30130 apcie0: Chip ID1: 531310fe icc0: <Aeolia ICC> on pci0 hpet_pci0: <Aeolia High Precision Event Timer> on pci0 Timecounter "HPET" frequency 10000000 Hz quality 950 Event timer "HPET" frequency 10000000 Hz quality 450 Event timer "HPET1" frequency 10000000 Hz quality 450 Event timer "HPET2" frequency 10000000 Hz quality 450 Event timer "HPET3" frequency 10000000 Hz quality 450 sflash0: <Aeolia Serial Flash I/F> on pci0 sflash0: Macronix(c2) rtc0: <Aeolia RTC> on pci0 timer_mvl0: <Aeolia Timer/WDT> on pci0 uart0: <Non-standard ns8250 class UART with FIFOs> on pci0 uart0: uart_bus_attach uart0: console (115200,n,8,1) twsi0: <Aeolia TWSI> on pci0 ahci0: <Orbis Aeolia AHCI SATA controller> on pci0 ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahci0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f ahci0: AHCI v1.30 with 1 3Gbps ports, Port Multiplier supported with FBS ahcich0: <AHCI channel> at channel 0 on ahci0 iommu_add_device_table_entry: device_id:00a2 dev:1 func:1 ahcich xhci0: <Aeolia XHCI USB 3.0 controller> on pci0 xhci1: <Aeolia XHCI USB 3.0 controller> on pci0 iommu_add_device_table_entry: device_id:00a7 dev:20 func:7 xhci Initial IO PTB alloc. device:0xa7 io:0xa000000 usbus1 on xhci1 xhci2: <Aeolia XHCI USB 3.0 controller> on pci0 acpi_ssb0: <Aeolia acpi> on pci0 mskc0: <Aeolia GBE controller> on pci0 iommu_add_device_table_entry: device_id:00a1 dev:20 func:1 mskc msk0: <Aeolia GBE Id:0xbd Rev:0x01> on mskc0 eth0: Ethernet address: 70:9e:29:c3:5e:71 sdhci0: <Aeolia SDHCI> on pci0 iommu_add_device_table_entry: device_id:00a3 dev:20 func:3 sdhci sdhci0: 1 slot(s) allocated dmac0: <Aeolia DMA1 controller> on pci0 iommu_add_device_table_entry: device_id:00a5 dev:20 func:5 dmac dmac1: <Aeolia DMA2 controller> on pci0 spm0: <Aeolia Scratch Pad Memory> on pci0 sbram0: <Aeolia DDR3 memory> on pci0 dct0: <SCE DCT driver> on hostb4 sbi0: <SCE SBI driver> on hostb5 gbase_register_interrupt_handler(52) gbase_register_interrupt_handler(53) dce: 23 hwpstate0: <Cool`n'Quiet 2.0> on cpu0 _sdma_hw_init(0): microcode loaded _sdma_hw_init(1): microcode loaded acpDecFlac: <Codec DecFlac built on Jun 8 2021 05:26:35> acpDecOpus: <Codec DecOpus built on Jun 8 2021 05:26:35> ajm: <Audio CoProcessor Job Manager built on Jun 8 2021 05:26:33> acpDecMp3: <Codec DecMp3 built on Jun 8 2021 05:26:31> acpDecAt9: <Codec DecAt9 built on Jun 8 2021 05:26:35> acpDecM4aac: <Codec DecM4aac built on Jun 8 2021 05:26:35> acpEncM4Aac: <Codec EncM4Aac built on Jun 8 2021 05:26:35> acpDecCelp8: <Codec DecCelp8 built on Jun 8 2021 05:26:35> acpEncCelp8: <Codec EncCelp8 built on Jun 8 2021 05:26:35> acpDecAc3: <Codec DecAc3 built on Jun 8 2021 05:26:35> acpEncAc3: <Codec EncAc3 built on Jun 8 2021 05:26:35> acpDecTrhd: <Codec DecTrhd built on Jun 8 2021 05:26:35> acpDecM2bc: <Codec DecM2bc built on Jun 8 2021 05:26:35> acpEncDts: <Codec EncDts built on Jun 8 2021 05:26:35> acpDecM4aacfng: <Codec DecM4aacfng built on Jun 8 2021 05:26:35> acpDecCelp: <Codec DecCelp built on Jun 8 2021 05:26:35> acpEncCelp: <Codec EncCelp built on Jun 8 2021 05:26:31> acpDecVorbis: <Codec DecVorbis built on Jun 8 2021 05:26:35> acpEncOpusCelt: <Codec EncOpusCelt built on Jun 8 2021 05:26:35> acpDecOpusCelt: <Codec DecOpusCelt built on Jun 8 2021 05:26:35> acpEncOpusSilk: <Codec EncOpusSilk built on Jun 8 2021 05:26:35> acpDecOpusSilk: <Codec DecOpusSilk built on Jun 8 2021 05:26:35> acpUtlSrc: <Codec UtlSrc built on Jun 8 2021 05:26:35> UVFAT_Initialize: exit Timecounters tick every 1.000 msec Session ID: 4b7b9703dcd124e242a2f3b74702a67e g_lvusbus1: 5.0Gbps Super Speed USB v3.0 eth0: link state changed to UP ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahciugen1.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus1 uhub1: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1 0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahci0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahci0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f d_init 353 : Layered vnode device is initialized. g_lvd_init 355 : lvd is built at 05:26:37 Jun 8 2021 GEOM_CRYPT: eap key setup iommu_add_device_table_entry: device_id:00a4 dev:20 func:4 sflash icc08-4001 0802 icc:failed to enabled reset button notification: 0005 icc:enabled thermal notification [REGMGR] 000002 ... [REGMGR] C00027 @8716294@@1@@30@@432@@0@@0@ ... [REGMGR] 001001 $14684$@1@$13978948$# #$137771694779716$@387@############ ... [REGMGR] C00004 @559@@1024@ ... [REGMGR] C00005 @77@@1280@ ... [REGMGR] C00006 @124078@@204800@ ... [REGMGR] C00007 @1@ ... [REGMGR] C00008 @198@ ... [REGMGR] C00009 @458@@7280@ ... [REGMGR] 000101 @8716294@@8716294@ ... [REGMGR] ( 0.033325 sec) 010001 ... [REGMGR] ( 0.357 sec) 010001 ... uhub1: 2 ports with 2 removable, self powered [HDMI] Set CEC FeatureTable [Normal] mmc0: <MMC/SD bus> on sdhci0 [HDMI] HDMI kernel module has been available trsw0 on sdio0 bt0 on sdio0 trs0 on sdio0 sdio0: <SDIO Device> at mmc0 SMP: AP CPU #7 Launched! SMP: AP CPU #1 Launched! SMP: AP CPU #5 Launched! SMP: AP CPU #3 Launched! SMP: AP CPU #4 Launched! SMP: AP CPU #2 Launched! SMP: AP CPU #6 Launched! TSC clock: 1593818138 Hz Timecounter "TSC-low" frequency 12451704 Hz quality 1000 trsw0: FW version : 14.130.16.p55 wlan0: Ethernet address: e8:61:7e:52:6d:0b wlan1: Ethernet address: e8:61:7e:52:6d:0b Trying to mount root from exfatfs:md0 []... rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 RTC device error: Set Usertime 1970/01/01 rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 usbus0 on xhci0 usbus0: 5.0Gbps Super Speed USB v3.0 ugen0.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus0 uhub0: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0 [SceSysCore mini] launched *** start manu_cert *** Special Wake is invalid usbus2 on xhci2 usbus2: 5.0Gbps [SceSysAvControl] launched [ [AvSetting shm:54] server stat.st_size = 4096 av Scontrolu pk] : f=setuer Speed USp_dispclk_k l=332 ucPpll=EXT_PLL1 B v3.0 ugen2.1[av control] : HdmiCheckAvailability HDMI-TxType[0x1] HDMI-DevOut[0x1] [av control] : HdmiSetHdmiAvailability FLV1 : <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus2 uhub2: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus2 set CEC ON * [AvSetting core:1547] wait for hdmi event * [AvSetting core:1552] hdmi not connected ** cpv:e1 ** ** set_mode ** -1/-1 video: port:0 1080P_5994 RGB444 full CERGB 24bpp 1uhub0: 2 ports with 2 removable, self powered 6:9 nodata n-s audio: port:HDMI src:I2S 48k 2.0 24bit fmt:LPCM LPCM null [av control] : 1080P_5994 RGB444 CERGB 24bpp LT=Normal [av control] : LinkRate(2.7Gbps), HDMI(FLV1) [av control] : lt_req=1 hdmi_misc_up_req=1 vr_flg_up_req=0 vr_switch=0 csc_dir_req=0 hdr_dir_req=0 uhub2: 2 ports with 2 removable, self powered *** Hdmi Init(kern) : 0 *** rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 ERROR: _secure_read_raw(339) !CMDRSP_HDR_OSC_STOP ERROR: _rtc_read_pre(461) _secure_read_raw ret=0x800f0531 ERROR: _rtc_read(486) rtc_read_pre ret=0x800f0531 [av control] : f=HdmiSetup videoConfigType(NORMAL) *** Hdmi Setup(kern) : 0 *** ** set_mode done (9550883404:466) ** [avs] update -1:27 [avs] lock -1:0 trsw0 on sdio0 bt0 on sdio0 trs0 on sdio0 sdio0: <SDIO Device> at mmc0 SMP: AP CPU #7 Launched! SMP: AP CPU #1 Launched! SMP: AP CPU #5 Launched! SMP: AP CPU #3 Launched! SMP: AP CPU #4 Launched! SMP: AP CPU #2 Launched! SMP: AP CPU #6 Launched! TSC clock: 1593818138 Hz Timecounter "TSC-low" frequency 12451704 Hz quality 1000 trsw0: FW version : 14.130.16.p55 wlan0: Ethernet address: e8:61:7e:52:6d:0b wlan1: Ethernet address: e8:61:7e:52:6d:0b Trying to mount root from exfatfs:md0 []... rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 RTC device error: Set Usertime 1970/01/01 rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 usbus0 on xhci0 usbus0: 5.0Gbps Super Speed USB v3.0 ugen0.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus0 uhub0: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0 [SceSysCore mini] launched *** start manu_cert *** Special Wake is invalid usbus2 on xhci2 usbus2: 5.0Gbps [SceSysAvControl] launched [ [AvSetting shm:54] server stat.st_size = 4096 av Scontrolu pk] : f=setuer Speed USp_dispclk_k l=332 ucPpll=EXT_PLL1 B v3.0 ugen2.1[av control] : HdmiCheckAvailability HDMI-TxType[0x1] HDMI-DevOut[0x1] [av control] : HdmiSetHdmiAvailability FLV1 : <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus2 uhub2: <0x104d XHCI root HUB, class 9/0, rev 3filecheck: /dev/da0x8 FAILED 2 [ERR] mount hdd [failed REGMGR] (2549/6016072469926338939): E00042 @0@ ... [REGMGR] 000401 ... [REGMGR] ( 0.000439 sec) 010301 @0@ ... [REGMGR] ( 0.000003 sec) 010302 @0@ ... [REGMGR] 000103 @0@@8716294@ ... [REGMGR] 001001 $14684$@1@$13978948$# #$137771694779716$@387@############ ... [REGMGR] C00016 @0@@1@#OFF##OFF#@0@@0@ ... [REGMGR] 000104 ... [REGMGR] C00018 @1@ ... [REGMGR] C00023 @8716294@@1@@4359@@63@@100912@@47604@ ... [REGMGR] ( 0.168660 sec) 010003 ... [REGMGR] ( 12.987 sec) 010003 ... [SceSysCore mini] sceRegMgrCntlStart failed 800d0403 [SceSysCore mini] failed to mount system partitions [SceSysCore mini] Reboot and boot with rescue mode... [HDMI] Sink supports HDCP1.4 only [HDMI] Monitor Type [HDMI] [avs] hdmi event: connected(1), 0x9000000000100, 27995760000 [av control] : hdmi event connected(1) * [AvSetting registry:966] not found * [AvSetting registry:365] non-HDR TV: VIDEOOUT_hdr_off [avs] update 27:30 [avs] lock 0:45 set CEC ON ** cpv:e1 ** ** set_mode ** -1/-1 video: port:0 1080P_5994 RGB444 limited CERGB 24bpp 16:9 nodata n-s audio: port:HDMI src:I2S 48k 2.0 24bit fmt:LPCM LPCM once [av control] : 1080P_5994 RGB444 CERGB 24bpp LT=Normal [av control] : LinkRate(2.7Gbps), HDMI(FLV1) [av control] : lt_req=1 hdmi_misc_up_req=1 vr_flg_up_req=0 vr_switch=0 csc_dir_req=0 hdr_dir_req=0 [avs] update 30:15 [avs] lock 45:0 *** Hdmi Init(kern) : 0 *** [av control] : f=HdmiSetup videoConfigType(NORMAL) [avs] hdmi event: disconnected(0), 0x9000000000100, 28441988146 *** Hdmi Setup(kern) : 0 *** ** set_mode done (28724502368:447) ** [av control] : hdmi event disconnected(0) [avs] update 15:32 [HDMI] Sink supports HDCP1.4 only [HDMI] Monitor Type [HDMI] [avs] hdmi event: connected(1), 0x9000000000200, 28946379960 [av control] : hdmi event connected(1) ** cpv:e1 ** ** set_mode ** -1/-1 video: port:0 1080P_5994 RGB444 limited CERGB 24bpp 16:9 nodata n-s audio: port:HDMI src:I2S 48k 2.0 24bit fmt:LPCM LPCM once [av control] : 1080P_5994 RGB444 CERGB 24bpp LT=Normal [av control] : LinkRate(2.7Gbps), HDMI(FLV1) [av control] : lt_req=1 hdmi_misc_up_req=0 vr_flg_up_req=0 vr_switch=0 csc_dir_req=0 hdr_dir_req=0 *** Hdmi Init(kern) : 0 *** [av control] : f=HdmiSetup videoConfigType(NORMAL) [avs] update 32:15 *** Hdmi Setup(kern) : 0 *** ** set_mode done (30906444220:1229) ** [avs] update 15:32 filecheck: /dev/da0x6x2.crypt FAILED 2 [ERR] mount hdd failed [SceSysCore mini] find_hdd /dev/da0x6x2.crypt failed -1 [REGMGR] 000006 ... [REGMGR] ( 0.000000 sec) 010007 ... [REGMGR] 000107 ... Waiting (max 60 seconds) for system process `SceVnlru' to stop...done WHaIDit i:n Cgon t(romlalx e6r 0U SsB Coennceocntidosn )0 foHrI Ds y: sotpe:0m0 0pr0o0c0es0s0 `bSt:c1e uBsubf:0d arege:m1 on1' to stop...done Waiting (max 60 seconds) for system process `SceBufdaemon0' to stop...done Waiting (max 60 seconds) for system process `SceSyncer' to stop... Syncing disks, vnodes remaining...0 sched_sync: flush softdep (iter=2) sched_sync: flush softdep (iter=1) done Waiting (max 60 seconds) for system process `SceBufdaemon2' to stop...done All buffers synced. [REGMGR] (8719/137720138263933): E00604 @35@ ... Uptime: 29s icc post sync:Thermal alert LED off [REGMGR] 000007 @2@ ... icc08-4001 0802 icc:failed to disabled reset button notification: 0005 icc:disabled thermal notification icc02-4010 0203 ICC: howto:00000000 depth:2 cause:00 hand:01 ICC: Reboot. ICC 04-01 nowait secure loader build: Jun 8 2021 05:20:42 (r10426:release_branches/release_08.520) [711MHz]AGESA: ThebePBDK W5C21 973 msec[BOOT TIME] SAMU: 1261 msec: enter[BOOT TIME] SAMU: 2242 msec: leaveAGESA: ThebePBDK_3.1.0.70908 SAMU: W5C21 SIE CONFIDENTIAL Copyright (C) 2021 Sony Interactive Entertainment Inc. All Rights Reserved. Copyright (c) 1992-2012 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. r174732/release_branches/release_08.520 Jun 8 2021 05:27:23 amd64 mDBG: Kernel Build ID = 8886cd5b8b34a937 CPU: DG1000FGF84HT (1594.00-MHz K8-class CPU) Origin = "AuthenticAMD" Id = 0x710f13 Family = 16 Model = 11 Stepping = 3 Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT> Features2=0x36d8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,AVX,F16C> AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM> AMD Features2=0x154837fb<LAHF,CMP,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,NodeId,Topology,PerfCtrExtNB,<b26>,<b28>> TSC: P-state invariant, performance statistics Event timer "LAPIC" quality 400 ACPI APIC Table: <SIE ORBIS > FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs FreeBSD/SMP: 1 package(s) x 8 core(s) cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 cpu2 (AP): APIC ID: 2 cpu3 (AP): APIC ID: 3 cpu4 (AP): APIC ID: 4 cpu5 (AP): APIC ID: 5 cpu6 (AP): APIC ID: 6 cpu7 (AP): APIC ID: 7 MADT: Could not find APIC for SCI IRQ 9 Memory mode: 4: BC8 release BigApp memory : 0x0000000148000000 bytes (5248MiB) FMEM (max) : 0x0000000020000000 bytes ( 512MiB) MiniApp DMEM : 0x0000000030000000 bytes ( 768MiB) VSH DMEM : 0x000000001a800000 bytes ( 424MiB) Trace memory & Trace DMEM : 0x0000000000000000 bytes ( 0MiB) Vision memory : 0x0000000001000000 bytes ( 16MiB) Reserved memory : 0x0000000011a00000 bytes ( 282MiB) Flexible memory(SYSTEM) : 0x000000004ca74000 bytes (1227MiB) BIOS memory size : 0x00000000011b8000 bytes ( 18MiB) Kernel static size : 0x000000000d1d4000 bytes ( 210MiB) [REGMGR] 000001 ... acpi0: <SIE ORBIS> on motherboard cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 cpu4: <ACPI CPU> on acpi0 cpu5: <ACPI CPU> on acpi0 cpu6: <ACPI CPU> on acpi0 cpu7: <ACPI CPU> on acpi0 pcib0: <ACPI Host-PCI bridge> on acpi0 pci0: <ACPI PCI bus> on pcib0 pci0: found pcie_glue iommu0: <AMD IOMMU> on pci0 gc0: <Starsha> on pci0 LVP B2.1 # use 0x00000000 as mmGB_ADDR_CONFIG value GC SE0 Redundant CU: 0x200 GC SE1 Redundant CU: 0x200 GC SE2 Redundant CU: 0x0 GC SE3 Redundant CU: 0x0 SClkVid:0x3c SClkDpmVid:3 Dpm:3 Vid:0x3c hdac0: <GPU/DEHT Audio Controller> on pci0 apcie0: <Aeolia PCI Express glue> on pci0 apcie0: Chip revision: 00000300 apcie0: Chip ID0: 33c30130 apcie0: Chip ID1: 531310fe icc0: <Aeolia ICC> on pci0 hpet_pci0: <Aeolia High Precision Event Timer> on pci0 Timecounter "HPET" frequency 10000000 Hz quality 950 Event timer "HPET" frequency 10000000 Hz quality 450 Event timer "HPET1" frequency 10000000 Hz quality 450 Event timer "HPET2" frequency 10000000 Hz quality 450 Event timer "HPET3" frequency 10000000 Hz quality 450 sflash0: <Aeolia Serial Flash I/F> on pci0 sflash0: Macronix(c2) rtc0: <Aeolia RTC> on pci0 timer_mvl0: <Aeolia Timer/WDT> on pci0 uart0: <Non-standard ns8250 class UART with FIFOs> on pci0 uart0: uart_bus_attach uart0: console (115200,n,8,1) twsi0: <Aeolia TWSI> on pci0 ahci0: <Orbis Aeolia AHCI SATA controller> on pci0 ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahci0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f ahci0: AHCI v1.30 with 1 3Gbps ports, Port Multiplier supported with FBS ahcich0: <AHCI channel> at channel 0 on ahci0 iommu_add_device_table_entry: device_id:00a2 dev:1 func:1 ahcich xhci0: <Aeolia XHCI USB 3.0 controller> on pci0 xhci1: <Aeolia XHCI USB 3.0 controller> on pci0 iommu_add_device_table_entry: device_id:00a7 dev:20 func:7 xhci Initial IO PTB alloc. device:0xa7 io:0xa000000 usbus1 on xhci1 xhci2: <Aeolia XHCI USB 3.0 controller> on pci0 acpi_ssb0: <Aeolia acpi> on pci0 mskc0: <Aeolia GBE controller> on pci0 iommu_add_device_table_entry: device_id:00a1 dev:20 func:1 mskc msk0: <Aeolia GBE Id:0xbd Rev:0x01> on mskc0 eth0: Ethernet address: 70:9e:29:c3:5e:71 sdhci0: <Aeolia SDHCI> on pci0 iommu_add_device_table_entry: device_id:00a3 dev:20 func:3 sdhci sdhci0: 1 slot(s) allocated dmac0: <Aeolia DMA1 controller> on pci0 iommu_add_device_table_entry: device_id:00a5 dev:20 func:5 dmac dmac1: <Aeolia DMA2 controller> on pci0 spm0: <Aeolia Scratch Pad Memory> on pci0 sbram0: <Aeolia DDR3 memory> on pci0 dct0: <SCE DCT driver> on hostb4 sbi0: <SCE SBI driver> on hostb5 gbase_register_interrupt_handler(52) gbase_register_interrupt_handler(53) dce: 23 hwpstate0: <Cool`n'Quiet 2.0> on cpu0 _sdma_hw_init(0): microcode loaded _sdma_hw_init(1): microcode loaded acpDecFlac: <Codec DecFlac built on Jun 8 2021 05:26:35> acpDecOpus: <Codec DecOpus built on Jun 8 2021 05:26:35> ajm: <Audio CoProcessor Job Manager built on Jun 8 2021 05:26:33> acpDecMp3: <Codec DecMp3 built on Jun 8 2021 05:26:31> acpDecAt9: <Codec DecAt9 built on Jun 8 2021 05:26:35> acpDecM4aac: <Codec DecM4aac built on Jun 8 2021 05:26:35> acpEncM4Aac: <Codec EncM4Aac built on Jun 8 2021 05:26:35> acpDecCelp8: <Codec DecCelp8 built on Jun 8 2021 05:26:35> acpEncCelp8: <Codec EncCelp8 built on Jun 8 2021 05:26:35> acpDecAc3: <Codec DecAc3 built on Jun 8 2021 05:26:35> acpEncAc3: <Codec EncAc3 built on Jun 8 2021 05:26:35> acpDecTrhd: <Codec DecTrhd built on Jun 8 2021 05:26:35> acpDecM2bc: <Codec DecM2bc built on Jun 8 2021 05:26:35> acpEncDts: <Codec EncDts built on Jun 8 2021 05:26:35> acpDecM4aacfng: <Codec DecM4aacfng built on Jun 8 2021 05:26:35> acpDecCelp: <Codec DecCelp built on Jun 8 2021 05:26:35> acpEncCelp: <Codec EncCelp built on Jun 8 2021 05:26:31> acpDecVorbis: <Codec DecVorbis built on Jun 8 2021 05:26:35> acpEncOpusCelt: <Codec EncOpusCelt built on Jun 8 2021 05:26:35> acpDecOpusCelt: <Codec DecOpusCelt built on Jun 8 2021 05:26:35> acpEncOpusSilk: <Codec EncOpusSilk built on Jun 8 2021 05:26:35> acpDecOpusSilk: <Codec DecOpusSilk built on Jun 8 2021 05:26:35> acpUtlSrc: <Codec UtlSrc built on Jun 8 2021 05:26:35> UVFAT_Initialize: exit Timecounters tick every 1.000 msec Session ID: c9fedb67870aa0d0895a626651921d37 g_lvusbus1: 5.0Gbps Super Speed USB v3.0 eth0: link state changed to UP ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahciugen1.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus1 uhub1: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1 0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahci0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f ahci0: Aeolia SATA PHY init [SATA] Apply ATE SRAM RTC Setting Version: 0x1 ahci0: Aeolia SATA PHY ID : 0x2100 ahci0: PHY calibration result[align90]: 0x5f d_init 353 : Layered vnode device is initialized. g_lvd_init 355 : lvd is built at 05:26:37 Jun 8 2021 GEOM_CRYPT: eap key setup iommu_add_device_table_entry: device_id:00a4 dev:20 func:4 sflash icc08-4001 0802 icc:failed to enabled reset button notification: 0005 icc:enabled thermal notification [REGMGR] 000002 ... [REGMGR] C00027 @8716294@@1@@30@@432@@0@@0@ ... [REGMGR] 001001 $14684$@1@$13978948$# #$137771694779716$@387@############ ... [REGMGR] C00004 @559@@1024@ ... [REGMGR] C00005 @77@@1280@ ... [REGMGR] C00006 @124078@@204800@ ... [REGMGR] C00007 @1@ ... [REGMGR] C00008 @199@ ... [REGMGR] C00009 @458@@7280@ ... [REGMGR] 000101 @8716294@@8716294@ ... [REGMGR] ( 0.033332 sec) 010001 ... [REGMGR] ( 0.337 sec) 010001 ... uhub1: 2 ports with 2 removable, self powered mmc0: <MMC/SD bus> on sdhci0 [HDMI] Set CEC FeatureTable [Normal] [HDMI] HDMI kernel module has been available trsw0 on sdio0 bt0 on sdio0 trs0 on sdio0 sdio0: <SDIO Device> at mmc0 SMP: AP CPU #7 Launched! SMP: AP CPU #1 Launched! SMP: AP CPU #4 Launched! SMP: AP CPU #3 Launched! SMP: AP CPU #5 Launched! SMP: AP CPU #2 Launched! SMP: AP CPU #6 Launched! TSC clock: 1593777612 Hz Timecounter "TSC-low" frequency 12451387 Hz quality 1000 trsw0: FW version : 14.130.16.p55 wlan0: Ethernet address: e8:61:7e:52:6d:0b wlan1: Ethernet address: e8:61:7e:52:6d:0b Trying to mount root from exfatfs:md0 []... rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 RTC device error: Set Usertime 1970/01/01 rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 usbus0 on xhci0 usbus0: 5.0Gbps Super Speed USB v3.0 ugen0.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus0 uhub0: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0 [SceSysCore mini] launched *** start manu_cert *** Special Wake is invalid H[SceSysCore mini] Entering rescue mode(0xf0)... usbusID 2: oopn xhci2 :0u00sb0u0s0032 b:t[SceSysAvControl] launched [:a [AvSetting shm:54] server stat.st_size = 4096 05v. u0 Gcsonbbt:ps1 r roSegl:u p0 ekr] Sp:e fed =sUSeB tvu3.p0 _dispclk_k l=332 ucPpll=EXT_PLL1 ugen2.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0[av control] : HdmiCheckAvailability HDMI-TxType[0x1] HDMI-DevOut[0x1] [av control] : HdmiSetHdmiAvailability FLV1 x0000 depth=0 port=1 speed=4) at usbus2 uhub2: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus2 [REGMGR] (2549/4999134440476076389): E00042 @0@ ... [REGMGR] 000401 ... [REGMGR] ( 0.000442 sec) 010301 @0@ ... [REGMGR]** cpv:e1 ** ** set_mode ** -1/-1 video: port:0 480P_5994 RGB444 limited CERGB 24bpp 16:9 nodata n-s audio: port:HDMI src:I2S 48k 2.0 24bit fmt:LPCM LPCM null [av control] : 480P_5994 RGB444 CERGB 24bpp LT=Normal [av control] : LinkRate(2.7Gbps), HDMI(FLV1) [av control] : lt_req=1 hdmi_misc_up_req=1 vr_flg_up_req=0 vr_switch=0 csc_dir_req=0 hdr_dir_req=0 ( 0.000003 sec) 010302 @0@ ... [REGMGR] 000103 @0@@8716294@ ... [REGMGR] 001001 $14684$@1@$13978948$# #$137771694779716$@387@############ ... [REGMGR] C00016 @0@@1@#OFF##OFF#@0@@0@ ... [REGMGR] 000104 ... uhub0: 2 ports with 2 removable, self powered [REGMGR] C00018 @1@ ... [REGMGR] C00023 @8716294@@1@@4359@@63@@100912@@47604@ ... [REGMGR] ( 0.200710 sec) 010003 ... [REGMGR] ( 10.435 sec) 010003 ... uhub2: 2 ports with 2 removable, self powered * [mbus:929] [MBUS WARN] DISCONNECTED event from HDMI in DISCONNECTED state * [mbus:350] disconnected(0) from unknown device [ERROR]sceKernelWaitEventFlag(SCE_BOOT_STAT_DISPLAY, SCE_KERNEL_EVF_WAITMODE_AND) result 2000 : 8002003c
*** Hdmi Init(kern) : 0 *** [av control] : f=HdmiSetup videoConfigType(NORMAL) rtc0: WARNING: Battery failure indication rtc0: Status:E9, Time:A8 ERROR: _secure_read_raw(339) !CMDRSP_HDR_OSC_STOP ERROR: _rtc_read_pre(461) _secure_read_raw ret=0x800f0531 ERROR: _rtc_read(486) rtc_read_pre ret=0x800f0531 [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [HDMI] Sink supports HDCP1.4 only [HDMI] Monitor Type [HDMI] *** Hdmi Setup(kern) : 0 *** ** set_mode done (37654123364:9915) ** try GET_HDMI_STATE (0) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) try GET_HDMI_STATE (16) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) try GET_HDMI_STATE (32) [AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2) [AppFramework2][ERROR init:488]EjectButtonListener::Initialize error (result:0x80182b19) try GET_HDMI_STATE (48) GET_HDMI_STATE failed
** cpv:e1 ** ** set_mode ** -1/-1 video: port:0 480P_5994 RGB444 limited CERGB 24bpp 16:9 nodata n-s audio: port:HDMI src:I2S 48k 2.0 24bit fmt:LPCM LPCM null [av control] : 480P_5994 RGB444 CERGB 24bpp LT=Normal [av control] : LinkRate(2.7Gbps), HDMI(FLV1) [av control] : hdmi event connected(1) [av control] : lt_req=1 hdmi_misc_up_req=0 vr_flg_up_req=0 vr_switch=0 csc_dir_req=0 hdr_dir_req=0 [REGMGR] (8719/137720138263933): E00604 @35@ ... *** Hdmi Init(kern) : 0 *** [av control] : f=HdmiSetup videoConfigType(NORMAL) *** Hdmi Setup(kern) : 0 *** ** set_mode done (47680555266:1243) ** try GET_HDMI_STATE (0) try GET_HDMI_STATE (16) try GET_HDMI_STATE (32) try GET_HDMI_STATE (48) GET_HDMI_STATE failed
GET_HDMI_STATE failed видим что не определяет подключенный HDMI, бедем копать обвязку или сам контроллер. И еще дополнение: Мертвый контроллер оказался, зашибло его. Заменил, картинка появилась. Всем спасибо за помощь, расходимся :)))))
