Заголовок сообщения: Gigabyte GA-J1800N-H - No video
Добавлено: 28 янв 2022, 07:38
Зарегистрирован: 23 янв 2022, 19:30 Наличности на руках: 14.01 Сообщения: 9 Откуда: Porto Alegre / Brasil
I'm working in a motherboard from PCWARE (IPX1800G2), but is the same project from Gigabyte GA-J1800N-H.
The board accept start button, hold up ATX Power, but without any video.
All voltages are OK - include 1.35 from SODIMM. I dont have any hot component, but the COM1 controller (GD75232) has a little bit hotter than any other in the board. All voltages at COM connector are OK.
Steps I has made:
- Changed power source - no changes - Changed memory card - no changes - unplugged 12V CPU connector - no start - Reset BIOS - no changes
TODO: - Reflash BIOS - ??
Do you have any other idea?
Thanks
_________________ __________________ Estudier Porto Alegre / Brazil
Заголовок сообщения: Re: Gigabyte GA-J1800N-H - No video
Сейчас этот форум просматривают: darik711 и гости: 10
