https://vlab.su/
Gigabyte GA-G41MT-S2
https://vlab.su/viewtopic.php?f=223&t=83256
Страница 1 из 1
Slave82 [ 22 ноя 2018, 15:35 ]
Заголовок сообщения:  Gigabyte GA-G41MT-S2
Gigabyte GA-G41MT-S2- Rev:1.3
There is an error when I connect pci tester RESET on and off 2 seconds
I changed 3 processors, and update the new BIOS
What could be a malfunction?
mia [ 22 ноя 2018, 15:46 ]
Заголовок сообщения:  Re: Gigabyte GA-G41MT-S2
Check Power Supply Unit
Radiolubitel [ 22 ноя 2018, 16:57 ]
Write BIOS F3 version for 1.3 revision into two 8Mbit ROM (M_BIOS and B_BIOS)
Slave82 [ 22 ноя 2018, 18:24 ]
Power Supply Unit is good
I'll try it with bios, so I'm reporting
Posted after 29 minutes 49 seconds:
I returned to the f3 version
But the same case, even it happens without a bios chip removed from the board
mia [ 22 ноя 2018, 20:38 ]
Check Power On Button and Reset Button
Slave82 [ 23 ноя 2018, 00:29 ]
The Motheboard stands at my service desk.
Nothing is connected except power and processors
I have a lot of experience with the service, this is one of the hardest things.
I do not have an oscilloscope not schematics motheboard
Posted after 6 minutes 32 seconds:
My opinion is that there is a defective nort bridge or ite8718f-s chip ?
Radiolubitel [ 23 ноя 2018, 05:08 ]
Good. I correctly understood that the motherboard turns off after 2 seconds after power on?
Slave82 [ 23 ноя 2018, 12:11 ]
Motheboard turns On and remains on,but as I listed on the Pci tester, the LED diode reset turn on and turn off each 2 seconds
Posted after 5 minutes 1 second:
mia [ 23 ноя 2018, 17:12 ]
RAM not connected ?
Slave82 [ 23 ноя 2018, 22:15 ]
not connected
mia [ 24 ноя 2018, 00:54 ]
It is normal ? Without RAM - abnormal state of the PC...
Radiolubitel [ 24 ноя 2018, 00:56 ]
What voltage on cpu cores VCC_CORE
(on chokes or capasitors)?
Slave82 [ 24 ноя 2018, 17:48 ]
VCC_CORE-1.10v
Slave82 [ 25 ноя 2018, 02:12 ]
I changed the other north bridge, ITE chip
I'm not smart anymore what it might be
I had such a case with bios, but I both removed both the chip and reprogrammed the bios dam from the official site
Did any of you have this case?
Posted after 7 minutes 10 seconds:
Is there any schematic for this motheboard?
Radiolubitel [ 25 ноя 2018, 16:05 ]
Check signals on 61-65 pins ITE.
Unstable or change of the logical level within 2 seconds?
Slave82 [ 28 ноя 2018, 03:15 ]
I replaced the ITE chip, the result remained the same.
I do not have an oscilloscope, as I wrote in a previous post
I think the socket is defective, if there is another idea, I had a pair of plates with this kind of malfunction, but I did not manage to fix a single one
Posted after 1 minute 58 seconds:
Another question for the experienced, should the ITE chip be from the same board and version?
Radiolubitel [ 28 ноя 2018, 22:58 ]
Check with a multimeter in DC voltmeter mode
aleksros [ 28 ноя 2018, 23:58 ]
remove the radiators from the bridges and take a photo in good quality near them. I'll show you what capacitors you need to check for leakage. maybe a problem in them.
Slave82 [ 29 ноя 2018, 14:38 ]
here's the picture
Mihoho [ 29 ноя 2018, 15:27 ]
Не совсем понял, но он походу без памяти ее запустить пытается...
И не факт что у него тестер рабочий
Radiolubitel [ 30 ноя 2018, 01:07 ]
What is the voltage on the VCC F_USB1 or F_USB2?
Capacitor EC9 where?
Slave82 [ 30 ноя 2018, 03:52 ]
4.97v
the capacitor was damaged during the transport of the board
But it's not up to the capacitors I found a malfunction
The bond is as if it was cut, so hard it can be seen with a magnifier,
here are the pictures attached
http://www.phpbb.com/
