Текущее время: 19 апр 2024, 12:59
 Заголовок сообщения: ASUS Z170-AR 1.03 Over Current Problem
СообщениеДобавлено: 12 ноя 2020, 17:02
Hi,
I am new to the motherboard repairing and BIOS modding/debugging world.
I started my Desktop System after a couple of weeks and found that the ASUS Z170-AR 1.03 motherboard was failing to boot with the following error message:
Цитата:
USB Device Over Current Status Detected !!
System Will Shut Down After 15 Seconds.
After downloading the "BoardView file" for a *similar* motherboard, I learned about the various OC (over current) detection sub-circuits present on the motherboard. I systematically checked the reference voltages present at all (4) of those voltage dividers and found them to be 3.26+ volts. Note: These voltage dividers ("sensors") are directly connected to the PCH.
I also carried out the following debugging steps:
- All of the USB ports are providing +5v and are able to detect the keyboard during BIOS POST (Caps Lock responds). They all *seem* to be OK.
- The single USB-C port on this mobo is also providing power to charge things just fine.
- I connected the USB keyboard to the PS2 port but the BIOS seems to be disabling all inputs when this 'USB OC' problem is detected.
- All of the USB devices have been subsequently disconnected.
- The cables for the front-panel USB connectors have been disconnected as well.
However, the BIOS error about 'USB OC' persists . I then dumped the BIOS from the W25Q128FV BIOS chip (thankfully present in DIP-8 form factor) using "flashrom" on Linux.
Цитата:
$ sudo ./flashrom --programmer ch341a_spi -r bios_dump_another.rom
flashrom v1.2-136-ged341cf on Linux 5.8.0-26-lowlatency (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Found Winbond flash chip "W25Q128.V" (16384 kB, SPI) on ch341a_spi.
Reading flash... done.
This dumping process took around 2.5 minutes. The dump seems to match the "BIOS ROM file" which I extracted from the Z170-AR-ASUS-3801.CAP (downloaded from ASUS' website) using UEFITool.
Note: This board uses the ASM1142 USB 3.0 chip which has its own over current (OC) detection. I couldn't find the BoardView for my Z170-AR 1.03 motherboard and hence I had to stop the hardware debugging process.
Next -> I was able to patch the ASUS BIOS using UEFITool, GHIDRA, Cutter (radar2) and WinHex tools! After patching the BIOS, I was able to boot into the system! After logging in, I was able to confirm that ASM1142 chip is generating those OC (Over Current) signals. This controller can be disabled with the following command.
Цитата:
$ echo -n "0000:02:00.0" | sudo tee /sys/bus/pci/drivers/xhci_hcd/unbind
Now, I would like to fix this problem at the hardware level. I suspect that one of the capacitors has gone bad and is providing a low-resistance path to GND.
This is a test system and I don't use it much. However, I would like to use this opportunity to learn and improve my debugging skills with your help. Thank you for your time and attention.
What can I do next?
 Заголовок сообщения: Re: ASUS Z170-AR 1.03 Over Current Problem
СообщениеДобавлено: 12 ноя 2020, 18:43
The direction of repair is correct. For beginners quite a good level))
Thrown out an email for help. Describe in detail which element has no signal and which capacitor you suspect.
Let's do everything else together.
СообщениеДобавлено: 17 ноя 2020, 07:03
I was able to locate one problem with the RU31R40 (8.2k) and RU31R41 (4.7k) voltage divider.
RU31R41 is getting 5 volts. No problem. The capacitor (UC26), which is next to this resistor is also fine and maintaining 5 volts just fine.
The next observations are puzzling:
When measuring the voltage at the RU31R40 resistor, the initial voltage is 3.26 volts (which is correct) but it becomes 1.6 (or 1.5) volts very quickly! I am unable to explain this observation. Is the resistor failing somehow? Why is the voltage dipping here?
Should I try changing these resistors? The SMD package size of these resistors is 0402 which might prove challenging for me.
RU31R40 should be around 3.2+ volts and it is connected to the U31_OCI2 (Over Current Indicator) pin of the ASM1142 USB controller chip. But the (final) voltage here is 1.5v and that triggers the OC mode.
Please note that when I connect a keyboard to the ASM1142 USB port, it works just fine, which seems to imply that the ASM1142 chip is probably fine. The temperature of the ASM1142 chip is a bit warm around 42 degrees which may be OK (room temperature is in the mid-20s today).
Thanks for the help.
СообщениеДобавлено: 04 янв 2021, 11:31
UPDATE (Jan 2021):
This motherboard was lying flat on the table for the "operation" for a long time.
Before starting the repair job, I blew hard on the motherboard with an air pump.
After turning on this motherboard, the "USB Device Over Current" message simply disappeared!
Crazy, right?
I suspect that some dirt deposit(s) near the ASM1142 pins must have been causing short(s). These deposits must have gone away during the simple cleaning operation.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS Z170 PRO Gaming "usb device over current status detected"
в форуме Asus
SJan
14
5282
05 май 2020, 01:27
arneol Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS Z170-A Rev. 1.03 "Usb device over current status detected"
в форуме Asus
Slowbydancer
14
3112
25 апр 2020, 06:56
Slowbydancer Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. usb over current status detected asus p5kpl-am
в форуме Asus
gaydan
07 дек 2014, 20:27
ivan1394 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus m2n USB device over current status detected
в форуме Asus
jjoloka
04 дек 2015, 13:47
jjoloka Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus p8h61-ml lx3plus r2.0 USB Device Over Current Status Detected
в форуме Asus
SevenPC
05 авг 2016, 11:53
SevenPC Перейти к последнему сообщению
Сейчас этот форум просматривают: roswerk и гости: 18
