Текущее время: 28 апр 2024, 11:54
 Заголовок сообщения: Asus X370 prime pro chip identification
СообщениеДобавлено: 15 окт 2022, 13:14
Hello everyone,
I hope you guys are doing well. I have this board that I bought recently as defective, I have found a few problems so far, and I'm at the stage where everything is powering up normally, but I'm missing this chip, I think this chip was replaced with a different one at some point, as I'm not the first one to try to repair it, the chip currently in question is an MP9141 I dont know if that is the chip that should be setting there, if anyone has a similar board with that chip installed, it would be great to get what it is. or a closer photo would also help.
i obviously could not find any boardviews or datasheets for this one.
All my best,
Posted after 2 hours 34 minutes 44 seconds:
ok obviously that chip does not seem to belong to the board, I have no idea what it was doing there..
The chip that should be there is the one in this picture https://www.hwlegend.tech/wp-content/up ... eader2.jpg
 Заголовок сообщения: Re: Asus X370 prime pro chip identification
СообщениеДобавлено: 17 окт 2022, 07:38
If foto is true, chip is https://docs.yandex.ru/docs/view?tm=166 ... 6keyno%3D0
Foto of your plate is not visible(scotch not take view)
СообщениеДобавлено: 17 окт 2022, 10:57
This is flash ic of USB microcontroller ASM1143. You can install one of this: MX25L512EMI-10G, W25X05CLSNIG or PM25LQ512B. But you need program whis chip- you can use any dum from MB with this same USB controller.
Regards.
СообщениеДобавлено: 01 ноя 2022, 00:04
Thanks a lot guys, yes that is correct, when I found that picture I was able to tell which chip is that, but your feedback is much appreciated.
All my best,
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus prime x370 pro нужен bios
в форуме Asus
Михаил_noob
06 дек 2018, 10:26
Михаил_noob Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus Prime X370-PRO опознать номинал резюка
в форуме Asus
HeXakep
02 авг 2019, 10:41
HeXakep Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus Prime X370-A Post code 00
в форуме Asus
Mara975
1373
22 фев 2022, 16:19
Radiolubitel Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gl552jx (asus) ite chip identification?
myth77
09 июл 2017, 14:31
myth77 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A1278 (820-2936-A) chip identification needed
в форуме Apple
notemaster
02 май 2015, 12:56
notemaster Перейти к последнему сообщению
Сейчас этот форум просматривают: Nickim, Vyacheslav007 и гости: 17
