Текущее время: 19 апр 2024, 17:24
 Заголовок сообщения: Asus Rampage IV Extreme dead
СообщениеДобавлено: 03 июн 2016, 09:39
Asus Rampage IV Extreme dead.
At first this motherboard didn't respond to power button t,hen I reprogrammed the bios chips with external programmer, but nothing better.
then I followed the steps to recover bios using Asus USB BIOS Flashback utility:
1. Download the latest BIOS program file from the ASUS website.
2. Extract and rename the BIOS image file to R4E.ROM. ( R4E.cab also)
3. Copy R4E.ROM to the root directory of the USB flash disk drive.
4. Turn off the system and connect the USB flash drive to the ROG Connect port (the
white USB 2.0 port) at the rear panel of the motherboard.
5. Hold the ROG Connect button until the
BIOS LED begins to blink, then release.
6. Wait until the LED stops to blink.
After that, motherboard seems to came to live. (some leds light up, 7 segment display shows 00, and also Ethernet led on router ligts, but no beeps)
Cpu gets temperature but seems to get stuck without initialing POST.
I repeated USB BIOS Flashback, but motherboard does'n beep.
Any comment will be appreciated.
Regards.
 Заголовок сообщения: Re: Asus Rampage IV Extreme dead
СообщениеДобавлено: 03 июн 2016, 12:01
What a dump BIOS firmware you used when flashing with the programmer?
СообщениеДобавлено: 03 июн 2016, 13:54
I have found one file "Rampage-IV-Extreme-ASUS-4901.bin" from an Asiatic website, and compared with the one from motherboard, it is very similar.
Anybody knows if the embedded controller is also programmable?
Edit post in order to clarify the poin 2 of the user manual "USB BIOS Flashback":
"2. Extract and rename the BIOS image file to R4E.ROM"
R4E.ROM didn't work for me, but R4E.cap, did works, as you can see in the hexedit of dump file:
Вложение:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS Rampage 4 extreme rev/1.02
в форуме Asus
nv86rus
07 июн 2014, 07:12
nv86rus Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. нужен dump Asus Rampage IV Extreme
в форуме Asus
govorun
5061
24 окт 2014, 20:28
govorun Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS Rampage IV Extreme потеряла часть ОЗУ
в форуме Asus
Argentum
11
10961
08 сен 2016, 18:09
Argentum Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Мат. плата Asus Rampage IV Extreme + проц + память
nipp
04 авг 2019, 12:22
nipp Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS RAMPAGE IV EXTREME прошивка шми контролера ASP1000C-I08T
в форуме Asus
SergeiVldRemV
15
4782
02 апр 2020, 17:34
den2 Перейти к последнему сообщению
Сейчас этот форум просматривают: zhur36 и гости: 10
