Текущее время: 16 апр 2024, 12:48
 Заголовок сообщения: Asus P7p55d stuck at bios splash screen
СообщениеДобавлено: 09 июн 2017, 11:22
Hi i have a Asus P7p55d 1156 motherboard which turns on but no image on the screen...
I reprogramed the bios and motherboard starts but it is stuck at first asus logo splash screen...Although it needs at least 20 seconds before screen shows up...
I have tried every combination of components...replaced cpu,ram,gpu same problem...
I have even replaced pch with new one and same problem...
This board has a led diods for cpu,ram ,pciex and stnby activity...I have noticed that cpu and memory led switches back (cpu-mem-cpu-mem-cpu-mem) to many times
before pci_ex and screen initialization...All vital voltages are present...Post codes are usually different always...
I was thinking about replacing sio but any help would be appreciated...
 Заголовок сообщения: Re: Asus P7p55d stuck at bios splash screen
СообщениеДобавлено: 09 июн 2017, 12:13
if you have a logo but no loading, it's a problem of the periphery, see post code the stop and compare it with the latest code of the manufacturer of the BIOS. Problem with SIO , I don't think.
Пиши по делу, ибо внемлющие слововоблудию впадают в рукоблудие
СообщениеДобавлено: 09 июн 2017, 12:34
No no i removed all peripherals,just basic stuff...cpu,memory and gpu...it is stuck...i can not enter the bios...if i am fast enough with f2 button for bios setup, it goes to the screen before bios where the hardware info is written but it is stuck there also and nothing is shown after cpu speed ...
СообщениеДобавлено: 09 июн 2017, 12:53
lan codec, audio codec, usb3.0 it's periphery, delete?
СообщениеДобавлено: 28 июн 2017, 01:08
Заблокирован
If you tried all that at this point you may have some dead-short smd component.
See if your mobo is getting hot, use some 97% alcohol!
СообщениеДобавлено: 12 июл 2017, 17:23
I resolved this board ...I replaced ic in picture and board works fine now...
СообщениеДобавлено: 14 июл 2017, 21:41
Заблокирован
Congrats man, its always some stupid thing like that IC!
СообщениеДобавлено: 09 окт 2020, 08:58
@Djosla what exactly ic was you delete? I can't see you picture. my rating not enouugh yet
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. smartbuy splash 120 gb, не определяется, шьется с ошибкой
в форуме Ремонт SSD | SSD repair and data recovery
Yakor2011
19 июл 2023, 14:24
Yakor2011 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 14:23
anarasgarli Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Xfx RX5700 - wohnt detect from System, stuck in BIOS POSTUP
Assassin
29 мар 2021, 05:18
EYES Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus M5A97 Stuck un cpu led
в форуме Asus
sshana
16 дек 2020, 16:16
vova_w810i Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Проблемы с Bios ASUS P7P55D
в форуме Asus
Ruzal
2685
16 мар 2017, 15:33
Ruzal Перейти к последнему сообщению
Сейчас этот форум просматривают: elektronikas.remonts, Google [Bot], Sereginsmpas и гости: 11
