p8b75-m rev 2.00 bios help https://vlab.su/viewtopic.php?f=224&t=82991 |
bokin021 [ 16 ноя 2018, 18:07 ] | |
Заголовок сообщения: | p8b75-m rev 2.00 bios help |
Hi, Can someone hellp me I need bios rom for two bios chip on the board,but i cant find for rev 2.00..Maybe some one can help me.Thanks |
aleksros [ 16 ноя 2018, 18:51 ] | |
Заголовок сообщения: | Re: p8b75-m rev 2.00 bios help |
check email )) |
bokin021 [ 16 ноя 2018, 20:59 ] | |
i have to bios, one is main and other one is ME bios..It s mean i need two |
aleksros [ 17 ноя 2018, 01:11 ] | |
take this |
vova_w810i [ 17 ноя 2018, 01:13 ] | |
viewtopic.php?f=224&t=19519&p=183515&hilit=%2Ap8b75+m%2A#p183515 |
bokin021 [ 17 ноя 2018, 10:09 ] | |
My motherboard is rev 2.00 ,those bios will be ok ? |
Rimlen [ 17 ноя 2018, 10:33 ] | |
No difference in this case, programming easy. |
bokin021 [ 17 ноя 2018, 11:32 ] | |
ok ,thanks I will do.. Posted after 45 minutes 51 second: I did but cooler spining every three sec,maybe is wrong bios ? |
aleksros [ 17 ноя 2018, 13:39 ] | |
BIOS and ME chips in some places are not confused? |
bokin021 [ 17 ноя 2018, 13:45 ] | |
bios chip are same i change places but same happening.. |
aleksros [ 17 ноя 2018, 15:04 ] | |
the reason is not in bios. The board does not have voltage on the CPU. check this. |
bokin021 [ 17 ноя 2018, 15:15 ] | |
there is voltage on cpu i alredy everthing mesure ,also on ddr slot .. |
bokin021 [ 17 ноя 2018, 20:23 ] | |
I doubt in bios,because when I switch all voltage is ok |
bokin021 [ 18 дек 2018, 21:15 ] | |
i try everthing and i m sure it is problem with south bridge..Thanks |
