It's loading now, but not like it should do. The loading Led is flickering and it loads very slow. In the past, i always connected my bluetooth speaker to the bank to load both (powerbank and speaker) at the same time. That always wasn't a problem, but now the powerbank gets empty faster as it can be load with the ac. I hope you know what i mean.
The AC has 20v 2A. But if i connect it to load the Powerbank, it breaks in to 11,5V this isn't normal is it?
Is it cause of the SK34 instead of a SS34 or what else could it be? In the Area of D4 it gets very hot...
