How to resolve HP Printer Driver is Unavailable issue https://vlab.su/viewtopic.php?f=235&t=94076 |
jamesenderson [ 07 сен 2019, 11:18 ] | |
Заголовок сообщения: | How to resolve HP Printer Driver is Unavailable issue |
If you are also dealing with the HP Printer Driver is Unavailable issue, then here is the solution for you. You can perform the suggested steps to eradicate this issue. •Hit Windows + R. •In the dialog box of run, write dvgmt.msc and hit OK. •Search for your printer driver, when you got it, right-click on it and choose uninstall device. •From the prompt message, hit the “uninstall” option. •Now, visit the official site of the HP printer driver and download the genuine driver for your printer that supports in your device properly. •After that, Install the driver on your PC. •Check if the problem is resolved or not. If these steps won’t work for you, contact HP Support team for help. Experts will give you a proper solution. |
