Текущее время: 20 апр 2024, 17:58
 Заголовок сообщения: Help with dead b450 tomahawk
СообщениеДобавлено: 01 май 2020, 09:09
Hello. I have a msi b450 tomahawk dead. On stand-by the NCT6791D is so hot i cant touch it. On 3.3v line i had few ohms only. I took the nct down no change. There is a phase near chipset that also show 1ohm on it. I think is dead but i never repaired motherboards :) so any advice will be good. Thanks. Also noticed that there soma asm1480 chips that gets 3.3v but in pdf says maximum 2.5v vcc.
 Заголовок сообщения: Re: Help with dead b450 tomahawk
СообщениеДобавлено: 01 май 2020, 09:28
You can take 3.3V/1A from laboratory power supply on 3.3V rail and look what component will heating(remove heatsink from chipset before do it). :-):
Главный враг истины не отсутствие знания, а иллюзия знания.
СообщениеДобавлено: 01 май 2020, 12:19
I did that : i had 2 components that overheat : 1 usb driver and 1 asm1480 i took them down . It is normal to have 3.3v on it? In datasheet it says max 2.5. From 4 - 5 A on 3.3v I have 1A now but still low resistance 12-13ohms. On 5v rail i have 0.5A. Also that phase near chipset is 1ohm. It is that normal? I removed the coil the short is after coil unfortunately.
СообщениеДобавлено: 01 май 2020, 12:36
it is normal. may be you read another pdf? my pdf - 3.3volts.
СообщениеДобавлено: 01 май 2020, 13:53
And that phase to chipset?
СообщениеДобавлено: 01 май 2020, 16:19
what phase? place foto MB here and mark that.
СообщениеДобавлено: 01 май 2020, 17:46
Look here :
Вложение:
Question: did i made a mistake tooking down nct6797d?
СообщениеДобавлено: 01 май 2020, 19:28
that phase for FCH1, it is 1.05v. if 1 ohm - chipset is dead.
В этой теме нет новых непрочитанных сообщений. MSI B450 Tomahawk flash bios
в форуме MSI
AL._.EX
12 авг 2019, 12:01
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI B450 Tomahawk
в форуме MSI
pixelw
09 окт 2019, 18:29
pixelw Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Нужно наименование флешки биос MSI B450 Tomahawk MAX
в форуме MSI
AiNo07
12 ноя 2019, 15:49
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI B450 Tomahawk (MS-7C02v1.0)
в форуме MSI
Neech
22
3440
05 дек 2019, 19:03
Neech Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI B450 Tomahawk опознать номинал резистора
в форуме MSI
HeXakep
05 июл 2020, 09:00
HeXakep Перейти к последнему сообщению
