FM2A78M Pro4+ BIOS BIN FILE PLEASE https://vlab.su/viewtopic.php?f=244&t=104747 |
yoyaje9352 [ 11 июл 2020, 03:08 ] | |
Заголовок сообщения: | FM2A78M Pro4+ BIOS BIN FILE PLEASE |
igils [ 11 июл 2020, 10:35 ] | |
Заголовок сообщения: | Re: FM2A78M Pro4+ BIOS BIN FILE PLEASE |
https://www.asrock.com/mb/AMD/FM2A78M%2 ... u.asp#BIOS |
atzimpourdakas [ 11 июл 2020, 14:44 ] | |
Sorry but I want ".bin" bios file, not the ".exe" or ".40" that Asrock gives on website Thank you |
justsmile [ 11 июл 2020, 17:30 ] | |
atzimpourdakas писал(а): Sorry but I want ".bin" bios file, not the ".exe" or ".40" that Asrock gives on website rename "40" to "bin". |
atzimpourdakas [ 11 июл 2020, 17:52 ] | |
justsmile писал(а): rename "40" to "bin". I will try it. thank you very much Posted after 1 hour 12 seconds: justsmile писал(а): rename "40" to "bin". I tried with no luck! If this is corrent. My motherboard has more serious problem than bios chip reprogramming. The CH341A Mini Programmer app says that "file length, beyond range of will be ignored" when I open the "fixed" .bin file Thanks |
igils [ 11 июл 2020, 19:40 ] | |
Cut 4096 bytes (1000h) from the beginning of the file using any hex editor. |
atzimpourdakas [ 11 июл 2020, 21:07 ] | |
igils писал(а): Cut 4096 bytes (1000h) from the beginning of the file using any hex editor. You are the best.. Now motherboard post. Speaker beeps three times. something like memory problem. but I am sure one step near. Thanks |
