Текущее время: 27 апр 2024, 08:45
Страница 1 из 1 [ 1 сообщение ] |
draganzile
Заголовок сообщения: Remont Blaupunkt Power Supply Board ( Surge strike ) MP022-N Добавлено: 13 май 2020, 00:01 |
Зарегистрирован: 23 май 2016, 11:48 Наличности на руках: 63.07
Сообщения: 52 Откуда: Croatia
Hi, i have this TV Blaupunkt 32'' LED on service
Surge strike and burned many components. Replaced D3 and D5 diode , replaced R65 R66 R67 R68 resistors ( couldnt see what markings were on them - i replaced with 1R5 and 3x 1R0 resistors ) Replaced mdf7n60b mosfet with K3673 mosfet , replaced R52 and R58 resistors - also burned.
U2 is not shorted anywhere but i suspect it is also burned since massive surge came over R52 resistor.
On U2 i 4.5V AC current on ALL THE PINS , need help.
Cant read model on U2 chip, also, not sure if the R65, R66, R67, R68 are correct value.
Thanks comrades!
