Текущее время: 25 апр 2024, 11:32
 Заголовок сообщения: NDBT140x (Bay Trail) SoC replacement trouble (Txe Clean Done)
СообщениеДобавлено: 02 авг 2017, 05:17
The mainboard schematics is not available, but the mainboard is very similar to H14BT4 , even KBC signals matches (many of them at least)
https://www.4shared.com/get/liMOBr2vei/ ... _H14B.html
I replaced a SR1YW by SR1SH CPU, the motherboard start Windows perfectly but the USB 2.0 ports , Lan and WLAN are dead.
I tried to edit Txe Region in so many ways.
NDBT140X Original Txe Version : 1.1.2.1120
Txe version used in the SR1SH donor mainboard : 1.0.2.1060
flashing the original BIOS - doesn't work - Boot OK
Using Txe 1.1.2.1120 clean without touch any parameter - doesn't work - No hdd detect
Using Txe 1.1.2.1120 clean editing parameters to match original Txe - doesn't work - No video
Using Txe 1.0.2.1060 clean without touch any parameter - doesn't work - Boot OK
I try few other combinations and nothing works. Even with all the PCIe lines enabled and all the GPIOs enabled.
As long i can see booth are from the same system family and the CPU is perfectly recognized in the OS.
I know that the best thing to do is to replace it with another CPU but i have LOTS of SR1SH CPU in Scrap boards (many of that boards are working but they are here just to serve as donor boards)
Besides that, buy those CPUs is considerably expensive in my country, and my customers usually cancel the repair when a new CPU is needed.
I really appreciate any help.
 Заголовок сообщения: Re: NDBT140x (Bay Trail) SoC replacement trouble (Txe Clean Done)
СообщениеДобавлено: 29 авг 2018, 10:34
SR1YW Core stepping C0
SR1SH Core stepping B3
replacement is not possible
В этой теме нет новых непрочитанных сообщений. Elitebook folio 9470m Clean bios dump (Elitebook folio 9470m Clean bios dump) Elitebook folio 9470m Clean bios
zenelli
03 сен 2014, 23:07
zenelli Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus x551ma-sx023h (Intel Bay Trail-M) гаснет встроенный монитор
tarabukinivan
2994
24 янв 2016, 21:21
Boria01 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron 15-3531 (Intel Bay Trail-M) Пищит 7 раз и нету изображения
в форуме Dell
kashirin91s
14 мар 2017, 07:32
kashirin91s Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus X200MA (Intel Bay Trail-M) Не запускается
AndreyZagr
09 янв 2018, 13:39
smetankin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Отжиг USB в процах Bay-Trail
Dag_ZhiEst'
12
2888
18 окт 2018, 23:29
