Текущее время: 18 апр 2024, 20:44
 Заголовок сообщения: pipo u1 pro диагностика и ремонт
СообщениеДобавлено: 08 ноя 2019, 22:40
не включается
терминал показал останов при инициализации контроллера питания
пропайка контроллера питания
планшет заработал
лог терминала
In
DDR3
freq
300MHz
config state
pctl
phy
mem
DX0DQSTR:3DB04001
DX1DQSTR:3DB05001
DX2DQSTR:3DB04001
DX3DQSTR:3DB04001
acc
ok
bus width=32 col=10 bank=8 row=15 CS=1
size=1024MB
ok OUT
BUILD=====4
GetRemapTbl flag = 0
OK! 72625
unsigned!
SecureBootEn = 0
Boot ver: 2012-08-08#1.14
start_linux=====77597
2381106 Starting kernel...@0x60408000
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.8+ (root@lzj-desktop) (gcc version 4.4.0 (GCC) ) #201 SMP PREEMPT Sat Dec 29 16:00:10 CST 2012
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: RK30board
[ 0.000000] memory reserve: Memory(base:0x91800000 size:80M) reserved for <ion>
[ 0.000000] memory reserve: Memory(base:0x90c00000 size:12M) reserved for <fb0 buf>
[ 0.000000] memory reserve: Memory(base:0x90000000 size:12M) reserved for <fb2 buf>
[ 0.000000] memory reserve: Memory(base:0x8fa00000 size:6M) reserved for <camera_ipp_mem_0>
[ 0.000000] memory reserve: Memory(base:0x8fa00000 size:0M) reserved for <camera_ipp_mem_1>
[ 0.000000] memory reserve: Total reserved 110M
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] CPU SRAM: copied sram code from c0b31000 to fef00100 - fef01df0
[ 0.000000] CPU SRAM: copied sram data from c0b32cf0 to fef03000 - fef03a34
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[ 0.000000] DDR DEBUG: version 1.00 20121016
[ 0.000000] DDR DEBUG: DDR3 Device
[ 0.000000] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB
[ 0.000000] DDR DEBUG: init success!!! freq=324MHz
[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x5, DGSL=1 extra clock, DGPS=180
[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.000000] rk30_iomux_init
[ 0.000000] Boot mode: 0 flag: 0xc3524200
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1dc0000 s7072 r8192 d13408 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 231936
[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00210000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00008000@0x00010000(recovery),0x00100000@0x00018000(backup),0x0003a000@0x00118000(cache),0x00200000@0x00152000(userdata),0x00002000@0x00352000(kpanic),0x00200000@0x00354000(system),-@0x00554000(user) bootver=2012-08-08#1.14 firmware_ver=4.0.4
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 762MB 152MB = 914MB total
[ 0.000000] Memory: 906600k/906600k available, 141976k reserved, 155648K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xf7000000 - 0xfe800000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf6800000 ( 872 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0408000 - 0xc0529000 (1156 kB)
[ 0.000000] .text : 0xc0529000 - 0xc0adbf6c (5836 kB)
[ 0.000000] .data : 0xc0adc000 - 0xc0b30720 ( 338 kB)
[ 0.000000] .bss : 0xc0b34024 - 0xc15b73f8 (10765 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:416
[ 0.000000] rk30_gpio_init: 176 gpio irqs in 6 banks
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.004910] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
[ 0.013830] pid_max: default: 32768 minimum: 301
[ 0.019061] Mount-cache hash table entries: 512
[ 0.024640] Initializing cgroup subsys debug
[ 0.029255] Initializing cgroup subsys cpuacct
[ 0.034177] Initializing cgroup subsys freezer
[ 0.039008] CPU: Testing write buffer coherency: ok
[ 0.145022] CPU1: Booted secondary processor
[ 0.145068] Brought up 2 CPUs
[ 0.152925] SMP: Total of 2 processors activated (3262.93 BogoMIPS).
[ 0.160119] devtmpfs: initialized
[ 0.171076] NET: Registered protocol family 16
[ 0.175957] last_log: 0xef500000 0xc0b38268
[ 0.283180] rk29sdk_wifi_bt_gpio_control_init: init finished
<hit enter to activate fiq debugger>
[ 0.293634] console [ttyFIQ0] enabled, bootconsole disabled
[ 0.305281] Registered FIQ tty driver ef48fc00
[ 0.321789] bio: create slab <bio-0> at 0
[ 0.326171] wm831x_dcdc_init
[ 0.329308] wm831x_ldo_init
[ 0.332513] SCSI subsystem initialized
[ 0.336457] usbcore: registered new interface driver usbfs
[ 0.342006] usbcore: registered new interface driver hub
[ 0.347408] usbcore: registered new device driver usb
[ 0.352875] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[ 0.358400] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[ 0.363914] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[ 0.369331] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[ 0.374744] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[ 0.380147] rk30-adc rk30-adc: rk30 adc: driver initialized
[ 0.385992] timed_gpio_probe
[ 0.388954] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.395704] Bluetooth: Core ver 2.16
[ 0.399313] NET: Registered protocol family 31
[ 0.403752] Bluetooth: HCI device and connection manager initialized
[ 0.410115] Bluetooth: HCI socket layer initialized
[ 0.414997] Bluetooth: L2CAP socket layer initialized
[ 0.420055] Bluetooth: SCO socket layer initialized
[ 0.425202] cfg80211: Calling CRDA to update world regulatory domain
[ 0.432375] rk fb probe ok!
[ 0.435223] wm831x_i2c_init
[ 0.438703] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 2...
[ 0.448212] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 1...
[ 0.457715] i2c i2c-1: No ack, Maybe slave(addr: 0x34) not exist or abnormal power-on, retry 0...
[ 0.466589] wm831x 1-0034: Failed to read parent ID: -11
[ 0.471904] wm831x: probe of 1-0034 failed with error -11
[ 0.477363] rk29_tps65910_config: tps65910 init config.
[ 0.485466] TPS65910 Set default voltage.
[ 0.489630] rk29_tps65910_config.......is 0x003d
[ 0.494487] rk29_tps65910_config.......is 0x0033
[ 0.499344] rk29_tps65910_config.......is 0x0000
[ 0.504200] rk29_tps65910_config.......is 0x0025
[ 0.509065] rk29_tps65910_config.......is 0x0033
[ 0.513921] rk29_tps65910_config.......is 0x0000
[ 0.519900] rk29_tps65910_config.......is 0x 3d
[ 0.524766] rk29_tps65910_config.......is 0x 33
[ 0.529621] rk29_tps65910_config.......is 0x 0
[ 0.534478] rk29_tps65910_config.......is 0x 25
[ 0.539333] rk29_tps65910_config.......is 0x 33
[ 0.544188] rk29_tps65910_config.......is 0x 0
[ 0.549811] +++++++++++++++++++++++++++++liqing.
[ 0.554534] w++++++goodix_ts_probe gt28x gt82x---0000000000000000
[ 0.560633] sizeof(*ts) = 192
[ 0.563750] input: Goodix TouchScreen of Guitar as /devices/virtual/input/input0
[ 0.571237] <--GT msg-->Register input device successfully!
[ 0.576810] <--GT msg-->Request int port successfully!
[ 0.581962] <--GT msg-->Request reset port successfully!
[ 0.587279] Goodix-TS-82X 2-005d: Start Goodix TouchScreen of Guitar in interrupt mode
[ 0.664447] GT82X++++++ Testing I2C connection...
[ 0.669669] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
[ 0.678877] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
[ 0.688084] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
[ 0.697292] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
[ 0.706498] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
[ 0.715704] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
[ 0.724912] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 2...
[ 0.734109] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 1...
[ 0.743316] i2c i2c-2: No ack, Maybe slave(addr: 0x5d) not exist or abnormal power-on, retry 0...
[ 0.752187] Goodix-TS-82X 2-005d: Warnning: I2C communication might be ERROR!
[ 0.759320] I2C test failed. I2C addr:5d
[ 0.763238] ############################ goodix_ts_remove #########################
[ 0.770891] Goodix-TS-82X 2-005d: The driver is removing...
[ 0.776622] Switching to clocksource timer1
[ 0.781010] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf701c000
[ 0.785059] Switched to NOHz mode on CPU #1
[ 0.791453] Switched to NOHz mode on CPU #0
[ 0.795680] rk_fb_io_init: set RK30_PIN4_PD4 GPIO_LOW
[ 0.830962] lcdc0: dclk:66500000>>fps:59 rk30_load_screen for lcdc0 ok!
[ 0.858303] fb0:phy:90c00000>>vir:f8000000>>len:0xc00000
[ 0.863790] rk_fb_register>>>>>fb0
[ 0.867330] rk_fb_register>>>>>fb1
[ 0.870730] lcdc0 wakeup from stanby
[ 0.874319] lcdc0 win1 open
[ 0.928157] rk30 lcdc0 probe ok!
[ 0.931455] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xf7028000
[ 0.937778] lcdc1: dclk:74250000>>fps:60 rk30_load_screen for lcdc1 ok!
[ 0.967384] fb2:phy:90000000>>vir:f9000000>>len:0xc00000
[ 0.972900] rk_fb_register>>>>>fb2
[ 0.976454] rk_fb_register>>>>>fb3
[ 0.979856] rk30 lcdc1 probe ok!
[ 0.989382] ==========================================
[ 0.994541] ======= rk30_adc_battery_probe =======
[ 0.999679] ==========================================
[ 1.005256] POWER_SUPPLY_TYPE_MAINS
[ 1.008783] POWER_SUPPLY_TYPE_MAINS
[ 1.012361] rk30_adc_battery_lowpower_check--1214:
[ 1.318447] hjc-lower_power_check...bat->bat_voltage=4003, bat->bat_capacity=96
[ 1.325761] power on battery capacity :4003
[ 1.329940] rk30_adc_battery: driver initialized
[ 1.334802] NET: Registered protocol family 2
[ 1.339268] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 1.346739] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.355966] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 1.363640] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.370247] TCP reno registered
[ 1.373400] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.379339] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.386046] NET: Registered protocol family 1
[ 1.390449] ~~~~~~~~~~~~~~~~bl_en ~~~~~~~~~~~~~~~~
[ 1.395358] RK29 Backlight Driver Initialized.
[ 1.400005] Unpacking initramfs...
[ 1.516741] Freeing initrd memory: 2112K
[ 1.520874] rk30-tsadc rk30-tsadc: initialized
[ 1.529223] Loaded driver for PL330 DMAC-1 rk29-pl330
[ 1.534302] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.540556] Loaded driver for PL330 DMAC-2 rk29-pl330
[ 1.545650] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[ 1.558750] highmem bounce pool size: 64 pages
[ 1.563464] ashmem: initialized
[ 1.571087] DVFS ERR: dvfs_reset_volt (clk:vd_cpu), try to reload arm_volt! arm_volt_correct = 1200000
[ 1.571690] fuse init (API version 7.16)
[ 1.585229] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.592656] io scheduler noop registered
[ 1.596579] io scheduler deadline registered
[ 1.600937] io scheduler cfq registered (default)
[ 1.611030] rga: Driver loaded succesfully
[ 1.615685] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[ 1.650838] rk_serial rk_serial.0: membase 0xf704c000
[ 1.655911] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[ 1.700940] rk_serial rk_serial.3: membase 0xf7050000
[ 1.706794] Rockchip ion module(version: 1.0) is successfully loaded
[ 1.721795] loop: module loaded
[ 1.725227] Android kernel panic handler initialized (bind=kpanic)
[ 1.732395] PPP generic driver version 2.4.2
[ 1.736834] PPP Deflate Compression module registered
[ 1.742020] PPP BSD Compression module registered
[ 1.747415] PPP MPPE Compression module registered
[ 1.752217] NET: Registered protocol family 24
[ 1.756710] usbcore: registered new interface driver asix
[ 1.762267] usbcore: registered new interface driver cdc_ether
[ 1.768122] usbcore: registered new interface driver dm9620
[ 1.773723] usbcore: registered new interface driver SR9700_android
[ 1.780007] usbcore: registered new interface driver net1080
[ 1.785717] usbcore: registered new interface driver cdc_subset
[ 1.791672] usbcore: registered new interface driver zaurus
[ 1.797247] cdc_ncm: 04-Aug-2011
[ 1.800495] usbcore: registered new interface driver cdc_ncm
[ 1.806157] Rockchip WiFi SYS interface (V1.00) ...
[ 1.811161] Initializing USB Mass Storage driver...
[ 1.816060] usbcore: registered new interface driver usb-storage
[ 1.822062] USB Mass Storage support registered.
[ 1.826743] usbcore: registered new interface driver usbserial
[ 1.832616] USB Serial support registered for generic
[ 1.837681] usbcore: registered new interface driver usbserial_generic
[ 1.844205] usbserial: USB Serial Driver core
[ 1.848573] USB Serial support registered for GSM modem (1-port)
[ 1.854601] usbcore: registered new interface driver option
[ 1.860162] option: v0.7.2:USB Driver for GSM modems
[ 2.075411] DWC_OTG: ^^^^^^^^^^^^^^^^^Device Mode
[ 2.080114] usb20_otg usb20_otg: DWC OTG Controller
[ 2.085001] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[ 2.092234] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[ 2.097710] DWC_OTG: dwc_otg_hcd_start controller in device mode,everest
[ 2.104442] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.111228] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.118439] usb usb1: Product: DWC OTG Controller
[ 2.123140] usb usb1: Manufacturer: Linux 3.0.8+ dwc_otg_hcd
[ 2.128789] usb usb1: SerialNumber: usb20_otg
[ 2.133405] hub 1-0:1.0: USB hub found
[ 2.137154] hub 1-0:1.0: 1 port detected
[ 2.142130] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.148995] android_usb gadget: Number of LUNs=2
[ 2.153620] lun0: LUN: removable file: (no medium)
[ 2.158489] lun1: LUN: removable file: (no medium)
[ 2.163489] android_usb gadget: android_usb ready
[ 2.168351] input: rk29-keypad as /devices/platform/rk29-keypad/input/input1
[ 2.175548] VTL ct36x TouchScreen driver, <george.chen@vtl.com>.
[ 2.432245] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 2...
[ 2.441245] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 1...
[ 2.450234] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 0...
[ 2.469158] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 2...
[ 2.478087] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 1...
[ 2.486996] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 0...
[ 2.505160] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 2...
[ 2.514081] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 1...
[ 2.522993] i2c i2c-2: No ack, Maybe slave(addr: 0x1) not exist or abnormal power-on, retry 0...
[ 2.541968] ct36x_ts 2-0001: FW Version read: 0xff
[ 2.546837] ct36x_ts 2-0001: FW Version write: 0x4
[ 2.551726] ct36x_ts 2-0001: Running bootloader ...
[ 2.556681] ct36x_ts_bootloader() Set mcu to idle
[ 2.561652] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 2...
[ 2.570683] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 1...
[ 2.579720] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 0...
[ 2.598741] ct36x_ts_bootloader() Reset i2c offset address
[ 2.604618] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 2...
[ 2.613639] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 1...
[ 2.622658] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 0...
[ 2.641550] ct36x_ts_bootloader() Read i2c bus status
[ 2.646806] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 2...
[ 2.655796] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 1...
[ 2.664808] i2c i2c-2: No ack, Maybe slave(addr: 0x7f) not exist or abnormal power-on, retry 0...
[ 2.683679] ct36x_ts_bootloader() i2c bus status: 0xff
[ 2.688895] ct36x_ts 2-0001: Bootloader done, Failed
[ 2.944272] input: ct36x_ts as /devices/virtual/input/input2
[ 2.950030] i2c-core: driver [ct36x_ts] using legacy suspend method
[ 2.956301] i2c-core: driver [ct36x_ts] using legacy resume method
[ 2.962884] lis3dh devid:33
[ 2.968688] input: gsensor as /devices/platform/rk30_i2c.0/i2c-0/0-0019/input/input3
[ 2.976570] lis3dh probe ok
[ 2.979381] sensor_register_slave:lis3dh
[ 2.983313] gsensor_init
[ 2.985840] sensor_register_slave:akm8975
[ 2.989908] compass_init
[ 2.992484] sensor_register_slave:l3g4200d
[ 2.996575] gyro_init
[ 2.998863] sensor_register_slave:cm3217
[ 3.002806] light_init
[ 3.010013] using rtc device, tps65910_rtc, for alarms
[ 3.015001] tps65910_rtc tps65910_rtc: rtc core: registered tps65910_rtc as rtc0
[ 3.022602] TPS65910 RTC device successfully registered
[ 3.028336] tps65910_rtc tps65910_rtc: Power up reset detected.
[ 3.034252] TPS65910 RTC set to default time
[ 3.041797] tps65910_rtc tps65910_rtc: RTC stop run.
[ 3.047599] tps65910_rtc tps65910_rtc: Enabling TPS65910-RTC.
[ 3.053358] TPS65910 RTC set to default time
[ 3.062324] lirc_dev: IR Remote Control driver registered, major 250
[ 3.068755] IR NEC protocol handler initialized
[ 3.073295] IR RC5(x) protocol handler initialized
[ 3.078077] IR RC6 protocol handler initialized
[ 3.082612] IR JVC protocol handler initialized
[ 3.087137] IR Sony protocol handler initialized
[ 3.091756] IR RC5 (streamzap) protocol handler initialized
[ 3.097320] IR LIRC bridge handler initialized
[ 3.101804] Linux video capture interface: v2.00
[ 3.106878] device-mapper: uevent: version 1.0.3
[ 3.111695] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 3.120267] Bluetooth: HCI UART driver ver 2.2
[ 3.124728] Bluetooth: HCI H4 protocol initialized
[ 3.129509] Bluetooth: HCILL protocol initialized
[ 3.134319] cpuidle: using governor ladder
[ 3.138410] cpuidle: using governor menu
[ 3.207814]
[ 3.207816] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc0]
[ 3.207831] .Line3796..The End of SDMMC-probe Ver.4.06 The last modify date is 2012-09-26. [sd_mmc]
[ 3.207945] .Line3796..The End of SDMMC-probe Ver.4.06 The last modify date is 2012-09-26. [sdio]
[ 3.209067] usbcore: registered new interface driver usbhid
[ 3.209072] usbhid: USB HID core driver
[ 3.211076] logger: created 256K log 'log_main'
[ 3.211128] logger: created 256K log 'log_events'
[ 3.211180] logger: created 256K log 'log_radio'
[ 3.211233] logger: created 256K log 'log_system'
[ 3.211653] rt5633_i2c_probe
[ 3.265366]
[ 3.265368] =================
[ 3.265370] mmc_rescan..1834.. ====find no SDMMC host. [mmc0]
[ 3.275644]
[ 3.275645] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc1]
[ 3.284343]
[ 3.284345] =================
[ 3.284347] mmc_rescan..1834.. ====find no SDMMC host. [mmc1]
[ 3.416274] asoc: RT5633 HiFi <-> rk29_i2s.0 mapping ok
[ 3.422018] ALSA device list:
[ 3.424980] #0: RK29_RT5633
[ 3.428018] GACT probability NOT on
[ 3.431516] Mirror/redirect action on
[ 3.435172] u32 classifier
[ 3.437871] Actions configured
[ 3.441284] Netfilter messages via NETLINK v0.30.
[ 3.446016] nf_conntrack version 0.5.0 (14198 buckets, 56792 max)
[ 3.452523] ctnetlink v0.93: registering with nfnetlink.
[ 3.457874] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.464838] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.470879] xt_time: kernel timezone is -0000
[ 3.475348] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.480755] arp_tables: (C) 2002 David S. Miller
[ 3.485413] TCP cubic registered
[ 3.488979] NET: Registered protocol family 10
[ 3.493913] Mobile IPv6
[ 3.496372] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.501879] IPv6 over IPv4 tunneling driver
[ 3.506572] NET: Registered protocol family 17
[ 3.511045] NET: Registered protocol family 15
[ 3.515544] Bridge firewalling registered
[ 3.519656] Bluetooth: RFCOMM TTY layer initialized
[ 3.524550] Bluetooth: RFCOMM socket layer initialized
[ 3.529678] Bluetooth: RFCOMM ver 1.11
[ 3.533428] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.538733] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.544745] NET: Registered protocol family 35
[ 3.549376] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.553844] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.559081] [BT_RFKILL]: ** disable irq
[ 3.590843] [BT_RFKILL]: bt shut off power
[ 3.620907] [BT_RFKILL]: rk903_26M device registered.
[ 3.626634] VFP support v0.3:
[ 3.627032]
[ 3.627043] rk_camera_probe Memory(start:0x8fa00000 size:0x600000) for IPP obtain
[ 3.638948] implementor 41 architecture 3 part 30 variant 9 rev 4
[ 3.639241] camera 33-0-ov2659_back: RK Camera driver attached to camera0(ov2659_back)
[ 3.639298] rk_camera_add_device..1002..
[ 3.659248] i2c i2c-0: sensor_probe: ak8975,0xef4a7c00
[ 3.664649] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[ 3.664915] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
[ 3.665303] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
[ 3.665685] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
[ 3.666071] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
[ 3.666451] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
[ 3.666831] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
[ 3.667214] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 2...
[ 3.667592] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 1...
[ 3.667970] i2c i2c-0: No ack, Maybe slave(addr: 0xd) not exist or abnormal power-on, retry 0...
[ 3.668005] sensor_chip_init:fail to read devid:0xff
[ 3.668033] i2c i2c-0: sensor_probe failed -11
[ 3.668079] sensors: probe of 0-000d failed with error -11
[ 3.668153] i2c i2c-0: sensor_probe: l3g4200d_gryo,0xef4a7e00
[ 3.668575] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 2...
[ 3.668956] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 1...
[ 3.669334] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 0...
[ 3.669714] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 2...
[ 3.670091] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 1...
[ 3.670467] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 0...
[ 3.670931] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 2...
[ 3.671323] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 1...
[ 3.671712] i2c i2c-0: No ack, Maybe slave(addr: 0x69) not exist or abnormal power-on, retry 0...
[ 3.671746] sensor_chip_init:fail to read devid:0xff
[ 3.671774] i2c i2c-0: sensor_probe failed -11
[ 3.671816] sensors: probe of 0-0069 failed with error -11
[ 3.671902] i2c i2c-2: sensor_probe: lightsensor,0xef604600
[ 3.671934] sensor_chip_init:sensor->devid=0x0,ops=0xc0b17b54
[ 3.672227] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 2...
[ 3.672514] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 1...
[ 3.672809] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 0...
[ 3.673106] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 2...
[ 3.673399] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 1...
[ 3.673691] i2c i2c-2: No ack, Maybe slave(addr: 0x10) not exist or abnormal power-on, retry 0...
[ 3.673723] sensor_active:fail to active sensor
[ 3.673745] sensor_init:line=97,error
[ 3.673763] sensor_initial:fail to init sensor
[ 3.673781] sensor_chip_init:fail to init sensor
[ 3.673807] i2c i2c-2: sensor_probe failed -11
[ 3.673847] sensors: probe of 2-0010 failed with error -11
[ 3.673985] sensor_init: Probe name sensors
[ 3.963289] tps65910_rtc tps65910_rtc: setting system clock to 2011-01-01 12:00:00 UTC (1293883200)
[ 3.972383]
[ 3.972386] ov2659 write reg(0x103, val:0x1) failed, try to write again!
[ 3.980939] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[ 3.980955] Freeing init memory: 1156K
[ 3.986876] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 3.993303] POWER_SUPPLY_TYPE_MAINS
[ 4.005982] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[ 4.015233] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[ 4.024214]
[ 4.024217] ov2659 write reg(0x103, val:0x1) failed, try to write again!
[ 4.028383] keychord: using input dev rk29-keypad for fevent
[ 4.038185] init: cannot open '/initlogo.rle'
[ 4.042772] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[ 4.052039] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[ 4.061066] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[ 4.069925]
[ 4.069926] ov2659 write reg(0x103, val:0x1) failed, try to write again!
[ 4.078225] soft reset ov2659 failed
[ 4.081923] camera 33-0-ov2659_back: RK Camera driver detached from camera0(ov2659_back)
[ 4.205536] gp_rknand_info = : 0xee0ed100
[ 4.209669] request IRQ_NANDC irq , ret=0.........
[ 4.230873] FlashCopyProgBuf1=0xc145b000
[ 4.234805] ATime: 40 ns AHB: 148 timming: 1081
[ 4.239331] No.1 FLASH INFO:45 de 94 93 76
[ 4.250834] No.3 FLASH INFO:45 de 94 93 76
[ 4.271040] ATime: 32 ns AHB: 148 timming: 1061
[ 4.275790] ATime: 32 ns AHB: 148 timming: 1061
[ 4.280311] randomizer = 1 , EccBits = 28
[ 4.446507] GetRemapTbl...
[ 4.991921] camera 33-0-ov2659_back: Probe ov2659_back failed
[ 5.010856] camera 33-1-gc0308_front: RK Camera driver attached to camera1(gc0308_front)
[ 5.018942] rk_camera_add_device..1002..
[ 5.033308] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 2...
[ 5.051041] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 1...
[ 5.060085] i2c i2c-3: No ack, Maybe slave(addr: 0x21) not exist or abnormal power-on, retry 0...
[ 5.068964]
[ 5.068966] gc0308 read reg(0x0 val:0x0) failed, try to read again!
[ 5.076913] gc0308 read chip id high byte failed
[ 5.081610] camera 33-1-gc0308_front: RK Camera driver detached from camera1(gc0308_front)
[ 5.590011] camera 33-1-gc0308_front: Probe gc0308_front failed
[ 5.972611] zyf ExchLostPwrRecovery: src blk = 539 , des blk = fb1
j•НН…ќ•Ѓsd-No-Media from VOLD.[sd_mmc]
[ 11.682272] .443.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
[ 11.692916] Current WiFi chip is RK903.
shell@android:/ $ ш [ 13.152544] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 13.310029] ANDROID-ERROR) wifi_get_mac_addr
[ 13.316083] Firmware up: op_mode=4, Broadcom Dongle Host Driver mac=00:22:f4:91:44:d3
[ 13.392567] Wifi driver initialize Country Code : EU
[ 13.399310] dhd_preinit_ioctls set keeplive failed -1
[ 13.407047] dhd_rx_frame: net device is NOT registered yet. drop packet
[ 13.413761] dhd_rx_frame: net device is NOT registered yet. drop packet
[ 13.420611] Firmware version = wl0: Jul 15 2012 12:54:29 version 5.90.195.26.3 FWID 01-5f56751e
[ 13.430795] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:22:f4:91:44:d3
[ 13.439153] dhd_module_init: Exit
[ 13.442837] =======================================================
[ 13.449103] == Dis-launching Wi-Fi driver! (Powered by Rockchip) ==
[ 1 %•НЌя №.1678.. ===== Initialize SDIO successfully. [mmc1]
[ 13.463114] =======================================================
[ 13.469417] dhd_module_cleanup: Enter
[ 13.473282] wl_iw_detach thr:f6 terminated OK
[ 13.477669] wl_iw_bt_release thr:f7 terminated OK
[ 13.482465] dhd_detach thr:fa terminated OK
[ 13.560923] dhd_detach thr:f8 terminated OK
[ 13.565172] dhd_detach thr:f9 terminated OK
[ 13.569819] CFG80211-ERROR) wl_event_handler : wl_event_handler was terminated
[ 13.577141] wl_destroy_event_handler thr:f5 terminated OK
[ 13.642362] ANDROID-ERROR) ## wifi_remove
[ 13.646419] ANDROID-ERROR) wifi_set_power = 0
[ 13.651287] rk29sdk_wifi_power: 0
[ 13.864371] wifi shut off power
[ 13.867511] ANDROID-ERROR) wifi_set_carddetect = 0
[ 13.872315] rk29sdk_wifi_set_carddetect:0
[ 13.876317] mmc1: slot status change detected(1-0)
[ 13.881398] mmc1: card 0001 removed
[ 13.881465] =========== WLAN placed in POWER OFF ========
[ 13.890467]
[ 13.890469] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc1]
[ 13.890994] [rknand_sys_storage_ioctl:84] rknand_sys_storage_ioctl in
[ 13.891000] [rknand_sys_storage_ioctl:95] RKNAND_GET_DRM_KEY
[ 13.891006] [rknand_sys_storage_ioctl:300] return ret = 0
[ 13.916712]
[ 13.916714] =================
[ 13.916717] mmc_rescan..1834.. ====find no SDMMC host. [mmc1]
Ђ ь Ђ ю я яюЂ яАю Ђ [ 33.584882] POWER_SUPPLY_TYPE_MAINS
[ 33.589412] ===1====rk30_battery_startget_store=====
[ 33.594440] rk30_battery_startget_store success write start to report battery
[ 33.602109] ====2===rk30_battery_startget_store=====
[ 33.830924] [BT_RFKILL]: bt turn on power
[ 33.992404] Current WiFi chip is RK903.
[ 34.016608] =======================================================
[ 34.022930] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 34.030163] =======================================================
[ 34.036477] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.23) init.
[ 34.044242] net_ratelimit: 1 callbacks suppressed
[ 34.048991] dhd_module_init: Enter
[ 34.049350] acc_open
[ 34.049363] acc_release
[ 34.057762] =========== WLAN placed in POWER ON ========
[ 34.063208] ANDROID-ERROR) ## wifi_probe
[ 34.067622] ANDROID-ERROR) wifi_set_power = 1
[ 34.072395] rk29sdk_wifi_power: 1
[ 34.349534] rk_serial rk_serial.0: baud:9600
[ 34.353827] serial.0 timeout:1000000
[ 34.357423] rk_serial rk_serial.0: baud:9600
[ 34.367571] serial.0 timeout:1000000
[ 34.371201] rk_serial rk_serial.0: baud:115200
[ 34.375639] serial.0 timeout:1000000
[ 34.395285] wifi turn on power
[ 34.398433] ANDROID-ERROR) wifi_set_carddetect = 1
[ 34.405657] rk29sdk_wifi_set_carddetect:1
[ 34.409848] mmc1: slot status change detected(0-1)
[ 34.414747] rk29_sdmmc_change_clk_div..1921.. newDiv=42, newCLK=294Khz [sdio]
[ 34.426696] Linux Kernel SDIO/MMC Driver
[ 34.437106]
[ 34.437109] Dongle Host Driver, version 5.90.195.26.1.6.1
[ 34.437112] Compiled in drivers/net/wireless/bcmdhd on Aug 24 2012 at 09:28:21
[ 34.623846]
[ 34.623849] drivers/mmc/core/core.c...1827.. ===== mmc_rescan Begin....[mmc1]
[ 34.676645]
[ 34.676647] mmc_attach_sdio..800.. ===== Begin to identify card as SDIO-card. [mmc1]
[ 34.777579] rk29_sdmmc_change_clk_div..1921.. newDiv=0, newCLK=24750Khz [sdio]
[ 34.787279] mmc1: new high speed SDIO card at address 0001
[ 34.798842] FW_PATH = /system/etc/firmware/fw_RK903.bin
[ 34.798847] NVRAM_PATH = /system/etc/firmware/nvram_RK903_26M.cal
[ 34.817271] F1 signature read @0x18000000=0x16044330
[ 34.850745] DHD: dongle ram size is set to 294912(orig 294912)
[ 34.859480] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK903b2.bin
[ 34.878792] wl_create_event_handler thr:1a3 started
[ 34.885476] wl_iw_attach thr:1a5 started
[ 34.889488] wl_iw_bt_init thr:1a6 started
[ 34.895453] dhd_attach thr:1a7 started
[ 34.901592] dhd_attach thr:1a8 started
[ 34.906902] dhd_attach thr:1aa started
[ 34.913460] ANDROID-ERROR) wifi_get_mac_addr
[ 34.917751] Fianl fw_path=/system/etc/firmware/fw_RK903b2.bin
[ 34.923852] Fianl nv_path=/system/etc/firmware/nvram_RK903_26M.cal
[ 34.988876] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 35.132288] ANDROID-ERROR) wifi_get_mac_addr
[ 35.143392] Firmware up: op_mode=4, Broadcom Dongle Host Driver mac=00:22:f4:91:44:d3
[ 35.229632] Wifi driver initialize Country Code : EU
[ 35.237167] dhd_preinit_ioctls set keeplive failed -1
[ 35.248301] dhd_rx_frame: net device is NOT registered yet. drop packet
[ 35.255291] dhd_rx_frame: net device is NOT registered yet. drop packet
[ 35.262285] Firmware version = wl0: Jul 15 2012 12:54:29 version 5.90.195.26.3 FWID 01-7f57771e
[ 35.275627] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:22:f4:91:44:d3
[ 35.290154] mmc_rescan_try_freq..1678.. ===== Initialize SDIO successfully. [mmc1]
[ 35.290267] dhd_module_init: Exit
[ 35.710122]
[ 35.710126] Dongle Host Driver, version 5.90.195.26.1.6.1
[ 35.710128] Compiled in drivers/net/wireless/bcmdhd on Aug 24 2012 at 09:28:21
[ 35.731001] wl_android_wifi_on in
[ 38.560867] hjc-first get into timer_work gBatteryData->bat_voltage=3896,gBatteryData->bat_capacity=86
[ 39.644696] rk_serial rk_serial.0: baud:1500000
[ 39.649422] serial.0 timeout:1000000
Качество пайки конечно отвратительное но ремонтировать очень просто.
В этой теме нет новых непрочитанных сообщений. Диагностика и ремонт компьютера. Ищу мастера
Dm_Kot
14 фев 2018, 02:11
Sergej Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. PIPO M6 PRO 3G 32Gb
ros3250
10
8183
07 авг 2017, 13:37
DenisGusarov Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Pipo M9 Pro - Замена процессора
gogoer
09 дек 2016, 18:07
pnh2all Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. PIPO Max M2
igortver
26 май 2014, 08:59
igortver Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Опознать элементы на плате PiPO P1
Kmair
05 янв 2016, 02:49
emblink Перейти к последнему сообщению
