Текущее время: 28 мар 2024, 13:24
Alexpastur
Заголовок сообщения: iIPC-HDW1220SP-0360B ремонт камеры Добавлено: 13 апр 2020, 11:06 |
Сообщения: 5 Откуда: Минск
после прошивки не работает System startup
U-Boot 2010.06-svn3105 (May 05 2016 - 07:25:42) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. data crc error, data crc:0x002c5566, crc:0x37a12b5a. Fail to read boot img. partition file version 2 rootfstype squashfs root /dev/mtdblock6 In: serial Out: serial Err: serial TEXT_BASE:81000000 fail to get updateflag partition info fail to get updateflag partition info Fail get partition from backup. get backup part info failedfail to get backup updateflag partition info fail to get updateflag offset and size Hisilicon ETH net controler MAC: 00-13-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'upgrade_info_7db780a713a4.txt'. Download to address: 0x84000000 Downloading: Retry count exceeded; starting again Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A UP_PORT : phy status change : LINK=DOWN : DUPLEX=FULL : SPEED=100M UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M *** ERROR: `serverip' not set Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'failed.txt'. Download to address: 0x82000000 Downloading: * Retry count exceeded; starting again ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1069120 Bytes = 1 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to parse HWID fail to parse bootargsParameters.text info get bootargs info failed cmdLine mem=47M console=ttyS0,115200 root=/dev/mtdblock6 rootfstype=squashfs crashflasg:1, logmagic:54410011.
Starting kernel ... Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518ev200 gLogRamRes: start=0x82eb7000;size=0x47000 mem_relimitAddr:0x82efe000 console [ttyS0] enabled mount: mounting none on /proc/bus/usb failed: No such file or directory mount: mounting tmpfs on /tmp failed: No such file or directory mknod: /dev/console: File exists mknod: /dev/ttyS0: File exists mknod: /dev/ttyS1: File exists mknod: /dev/null: File exists chmod: /dev/fd: Operation not permitted chmod: /dev/fd: Operation not permitted
keyboard = 0 mount: mounting devpts on /dev/pts failed: Device or resource busy [: 40: unknown operand [: 100: unknown operand Module himedia: init ok hi3518e_base: module license 'Proprietary' taints kernel. hi3518e_base: Unknown symbol hil_mmb_free (err 0) hi3518e_base: Unknown symbol hil_mmb_getby_phys (err 0) hi3518e_base: Unknown symbol hil_mmb_alloc (err 0) insmod: can't insert 'hi3518e_base.ko': unknown symbol in module, or unknown parameter hi3518e_sys: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_sys: Unknown symbol CMPI_StopModules (err 0) hi3518e_sys: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_sys: Unknown symbol CMPI_UserCopy (err 0) hi3518e_sys: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_sys: Unknown symbol CMPI_CreateProc (err 0) hi3518e_sys: Unknown symbol CMPI_GetModuleName (err 0) hi3518e_sys: Unknown symbol CMPI_ExitModules (err 0) hi3518e_sys: Unknown symbol CMPI_InitModules (err 0) hi3518e_sys: Unknown symbol CMPI_QueryModules (err 0) hi3518e_sys: Unknown symbol HI_LOG (err 0) hi3518e_sys: Unknown symbol CMPI_MmzFree (err 0) hi3518e_sys: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_sys: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_sys: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_sys.ko': unknown symbol in module, or unknown parameter hi3518e_tde: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_tde: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_tde: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_tde: Unknown symbol CMPI_CreateProc (err 0) hi3518e_tde: Unknown symbol HI_LOG (err 0) hi3518e_tde: Unknown symbol CMPI_MmzFree (err 0) hi3518e_tde: Unknown symbol hil_mmb_flush_dcache_byaddr (err 0) hi3518e_tde: Unknown symbol CMPI_RegisterModule (err 0) insmod: can't insert 'hi3518e_tde.ko': unknown symbol in module, or unknown parameter hi3518e_region: Unknown symbol TdeOsiCancelJob (err 0) hi3518e_region: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_region: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_region: Unknown symbol CMPI_UserCopy (err 0) hi3518e_region: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_region: Unknown symbol TdeOsiEndJob (err 0) hi3518e_region: Unknown symbol CMPI_CreateProc (err 0) hi3518e_region: Unknown symbol TdeOsiBeginJob (err 0) hi3518e_region: Unknown symbol TdeOsiWaitForDone (err 0) hi3518e_region: Unknown symbol HI_LOG (err 0) hi3518e_region: Unknown symbol CMPI_MmzFree (err 0) hi3518e_region: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_region: Unknown symbol TdeOsiQuickCopy (err 0) hi3518e_region: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_region: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_region: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_region.ko': unknown symbol in module, or unknown parameter hi3518e_vgs: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_vgs: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_vgs: Unknown symbol VB_UserAdd (err 0) hi3518e_vgs: Unknown symbol CMPI_UserCopy (err 0) hi3518e_vgs: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_vgs: Unknown symbol VB_UserSub (err 0) hi3518e_vgs: Unknown symbol CMPI_CreateProc (err 0) hi3518e_vgs: Unknown symbol CMPI_GetModuleName (err 0) hi3518e_vgs: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_vgs: Unknown symbol VB_Phy2Handle (err 0) hi3518e_vgs: Unknown symbol HI_LOG (err 0) hi3518e_vgs: Unknown symbol CMPI_MmzFree (err 0) hi3518e_vgs: Unknown symbol VB_Handle2Kern (err 0) hi3518e_vgs: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_vgs: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_vgs: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_vgs: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_vgs: Unknown symbol VB_Handle2Phys (err 0) hi3518e_vgs: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_vgs.ko': unknown symbol in module, or unknown parameter updatePos = 0 chip_id = hi3518e_isp: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_isp: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_isp: Unknown symbol CMPI_CreateProc (err 0) hi3518e_isp: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMallocCached (err 0) hi3518e_isp: Unknown symbol HI_LOG (err 0) hi3518e_isp: Unknown symbol CMPI_MmzFree (err 0) hi3518e_isp: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_isp: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_isp: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_isp: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_isp.ko': unknown symbol in module, or unknown parameter hi3518e_viu: Unknown symbol VB_Handle2Supplement (err 0) hi3518e_viu: Unknown symbol VB_InquirePoolUserCnt (err 0) hi3518e_viu: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_viu: Unknown symbol VB_UserAdd (err 0) hi3518e_viu: Unknown symbol CMPI_UserCopy (err 0) hi3518e_viu: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_viu: Unknown symbol VB_UserSub (err 0) hi3518e_viu: Unknown symbol CMPI_CreateProc (err 0) hi3518e_viu: Unknown symbol VB_GetBlkByPoolId (err 0) hi3518e_viu: Unknown symbol VB_CreatePool (err 0) hi3518e_viu: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_viu: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_viu: Unknown symbol ISP_GetDCFInfo (err 0) hi3518e_viu: Unknown symbol VB_IsBlkValid (err 0) hi3518e_viu: Unknown symbol HI_LOG (err 0) hi3518e_viu: Unknown symbol VB_Handle2Kern (err 0) hi3518e_viu: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_viu: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_viu: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_viu: Unknown symbol vi_vpss_online (err 0) hi3518e_viu: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_viu: Unknown symbol VB_DestroyPool (err 0) hi3518e_viu: Unknown symbol VB_Handle2Phys (err 0) hi3518e_viu: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_viu.ko': unknown symbol in module, or unknown parameter hi3518e_vpss: Unknown symbol VB_Handle2Supplement (err 0) hi3518e_vpss: Unknown symbol coefficient6_3M_a15 (err 0) hi3518e_vpss: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_vpss: Unknown symbol g_power_save_enable (err 0) hi3518e_vpss: Unknown symbol VB_UserAdd (err 0) hi3518e_vpss: Unknown symbol coefficient4_2M_a05 (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_vpss: Unknown symbol CMPI_UserCopy (err 0) hi3518e_vpss: Unknown symbol coefficient4_5M_a15 (err 0) hi3518e_vpss: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_vpss: Unknown symbol VB_UserSub (err 0) hi3518e_vpss: Unknown symbol CMPI_CreateProc (err 0) hi3518e_vpss: Unknown symbol coefficient8_lanczos2_8tap (err 0) hi3518e_vpss: Unknown symbol coefficient6_cubic (err 0) hi3518e_vpss: Unknown symbol coefficient8_2M_a05 (err 0) hi3518e_vpss: Unknown symbol coefficient8_3M_a19 (err 0) hi3518e_vpss: Unknown symbol coefficient6_4M_a20 (err 0) hi3518e_vpss: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_vpss: Unknown symbol coefficient8_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_vpss: Unknown symbol VIU_DRV_IsFrameFlashed (err 0) hi3518e_vpss: Unknown symbol coefficient8_cubic (err 0) hi3518e_vpss: Unknown symbol coefficient4_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol ISP_GetDCFInfo (err 0) hi3518e_vpss: Unknown symbol coefficient6_2M_a05 (err 0) hi3518e_vpss: Unknown symbol VB_IsBlkValid (err 0) hi3518e_vpss: Unknown symbol g_proc_enable (err 0) hi3518e_vpss: Unknown symbol HI_LOG (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzFree (err 0) hi3518e_vpss: Unknown symbol VB_Handle2Kern (err 0) hi3518e_vpss: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_vpss: Unknown symbol coefficient6_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_vpss: Unknown symbol coefficient4_cubic (err 0) hi3518e_vpss: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_vpss: Unknown symbol vi_vpss_online (err 0) hi3518e_vpss: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_vpss: Unknown symbol coefficient6_5M_a25 (err 0) hi3518e_vpss: Unknown symbol VB_Handle2Phys (err 0) hi3518e_vpss: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_vpss.ko': unknown symbol in module, or unknown parameter hi3518e_vou: Unknown symbol VB_InquirePoolUserCnt (err 0) hi3518e_vou: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_vou: Unknown symbol VB_UserAdd (err 0) hi3518e_vou: Unknown symbol CMPI_UserCopy (err 0) hi3518e_vou: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_vou: Unknown symbol VB_UserSub (err 0) hi3518e_vou: Unknown symbol CMPI_CreateProc (err 0) hi3518e_vou: Unknown symbol VB_GetBlkByPoolId (err 0) hi3518e_vou: Unknown symbol VB_CreatePool (err 0) hi3518e_vou: Unknown symbol VB_IsBlkValid (err 0) hi3518e_vou: Unknown symbol g_proc_enable (err 0) hi3518e_vou: Unknown symbol HI_LOG (err 0) hi3518e_vou: Unknown symbol VB_GetPoolInfo (err 0) hi3518e_vou: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_vou: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_vou: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_vou: Unknown symbol VB_DestroyPool (err 0) hi3518e_vou: Unknown symbol VB_Handle2BlkId (err 0) hi3518e_vou: Unknown symbol VB_Handle2Phys (err 0) hi3518e_vou: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_vou.ko': unknown symbol in module, or unknown parameter hi3518e_rc: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_rc: Unknown symbol g_proc_all (err 0) hi3518e_rc: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_rc: Unknown symbol CMPI_CreateProc (err 0) hi3518e_rc: Unknown symbol HI_LOG (err 0) hi3518e_rc: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_rc: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_rc: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_rc.ko': unknown symbol in module, or unknown parameter hi3518e_venc: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_venc: Unknown symbol VB_UserAdd (err 0) hi3518e_venc: Unknown symbol CMPI_UserCopy (err 0) hi3518e_venc: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_venc: Unknown symbol VB_UserSub (err 0) hi3518e_venc: Unknown symbol CMPI_CreateProc (err 0) hi3518e_venc: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_venc: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_venc: Unknown symbol VB_IsBlkValid (err 0) hi3518e_venc: Unknown symbol g_proc_enable (err 0) hi3518e_venc: Unknown symbol HI_LOG (err 0) hi3518e_venc: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_venc: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_venc: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_venc: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_venc: Unknown symbol VB_Handle2Phys (err 0) hi3518e_venc: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_venc.ko': unknown symbol in module, or unknown parameter hi3518e_chnl: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_chnl: Unknown symbol g_proc_all (err 0) hi3518e_chnl: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_chnl: Unknown symbol CMPI_CreateProc (err 0) hi3518e_chnl: Unknown symbol HI_LOG (err 0) hi3518e_chnl: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_chnl: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_chnl: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_chnl.ko': unknown symbol in module, or unknown parameter hi3518e_h264e: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_h264e: Unknown symbol VB_UserAdd (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_h264e: Unknown symbol hil_mmb_invalid_cache_byaddr (err 0) hi3518e_h264e: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_h264e: Unknown symbol VB_UserSub (err 0) hi3518e_h264e: Unknown symbol CMPI_CreateProc (err 0) hi3518e_h264e: Unknown symbol VB_GetBlkByPoolId (err 0) hi3518e_h264e: Unknown symbol VB_CreatePool (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMallocCached (err 0) hi3518e_h264e: Unknown symbol HI_LOG (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzFree (err 0) hi3518e_h264e: Unknown symbol hil_mmb_flush_dcache_byaddr (err 0) hi3518e_h264e: Unknown symbol VB_Handle2BlkSize (err 0) hi3518e_h264e: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_h264e: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_h264e: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_h264e: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_h264e: Unknown symbol VencBufferCache (err 0) hi3518e_h264e: Unknown symbol VB_DestroyPool (err 0) hi3518e_h264e: Unknown symbol VB_Handle2Phys (err 0) hi3518e_h264e: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_h264e.ko': unknown symbol in module, or unknown parameter hi3518e_jpege: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_jpege: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_jpege: Unknown symbol hil_mmb_invalid_cache_byaddr (err 0) hi3518e_jpege: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_jpege: Unknown symbol CMPI_CreateProc (err 0) hi3518e_jpege: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_jpege: Unknown symbol HI_LOG (err 0) hi3518e_jpege: Unknown symbol CMPI_MmzFree (err 0) hi3518e_jpege: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_jpege: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_jpege: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_jpege: Unknown symbol VencBufferCache (err 0) hi3518e_jpege: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_jpege.ko': unknown symbol in module, or unknown parameter insmod: can't open 'hi3518e_vda.ko': No such file or directory
[OSA-DRV] OSA Build on Jun 12 2017 at 16:08:32. [OSA-DRV] SVN NUM: 5514.
[OSA-DRV] Monitor Task pid=676 tid=676
[LOG-DRV] LOG Build on Jun 12 2017 at 16:05:37. [LOG-DRV] SVN NUM: 9984.
[LOG-DRV] ramStart:0x82eb7000;ramSize:0x47000;select:1 [OSA-DRV] Char device create OK ! [LOG-DRV] coreId = 0, logLevel = 2 [LOG-DRV] coreId = 1, logLevel = 2 [LOG-DRV] coreId = 2, logLevel = 2 [LOG-DRV] coreId = 3, logLevel = 2 [LOG-DRV] coreId = 4, logLevel = 2 [LOG-DRV] coreId = 5, logLevel = 2 00:00:06|[Binder] Binder.ko Build on Jun 12 2017 at 16:01:40. 00:00:06|[Binder] SVN NUM: 2593.
00:00:06|[Binder] NameServer Initial OK ! 00:00:06|[Binder] Create binder memory pool(size:16384) OK! 00:00:06|[Binder] Create binder memory pool(size:225280) OK! 00:00:06|[Binder] Binder Initial OK ! 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[Binder] SR driver initial OK ! 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[Binder] NS driver initial OK ! 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[Binder] Binder driver initial OK ! 00:00:06|[prc] PRC Driver Build on Jun 12 2017 at 16:02:33. 00:00:06|[prc] SVN NUM: 5578.
00:00:06|[prc] Start to init module! 00:00:06|[prc] pinmux init ok 00:00:06|[prc] gpio soc init ok 00:00:06|[prc] spi init ok 00:00:06|[prc] IIC init ok 00:00:06|[prc] PRC_wdtInit OK 00:00:06|[prc] PRC_rtcInit OK! 00:00:06|[prc] Success to init module! 00:00:06|[pdc]
PDC Build on Apr 14 2017 at 16:45:44. 00:00:06|[pdc] SVN NUM: 7430.
00:00:06|[pdc] BASE_LINE: 240 00:00:06|[pdc] OSA_kProcCreate OK 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[pdc] PDC_PartionInit ok!! 00:00:06|[pdc] HWID : 00:00:06|[pdc] ERROR (HWID_parsePdtType|4548): nPrdtLineId 0 wrong ! 00:00:06|[pdc] ERROR (PDC_hwidInit|5824): Hwid init failed ! 00:00:06|[pdc] ERROR (PDC_drvInit|187): PDC_hwidInit() 00:00:06|[pdc] ERROR (PDC_cfgFindInitOps|327): Not probed, please check it ! 00:00:06|[pdc] ERROR (PDC_cfgInit|357): Device not found ! 00:00:06|[pdc] ERROR (PDC_drvInit|193): PDC_cfgInit() 00:00:06|[pdc] Dev has No Key Cfg! 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[pdc] SramFile init ok ! 00:00:06|[pdc] Both of Chief and Backup File CRC check OK! 00:00:06|[OSA-DRV] recordTsk Task pid=703 tid=703 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[OSA-DRV] Char device create OK ! 00:00:06|[pdc] ERROR (PDC_drvInit|208): PDC Driver Initial Failed ! <1>mipi_init init phy power successful! load hi_mipi driver successful! *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0040: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0044: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0080: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0088: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f008c: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0090: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0094: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x2003002c: 0x000C4003 --> 0x000B4001 [END]
рошивки не работает
Alexpastur
Заголовок сообщения: Re: iIPC-HDW1220SP-0360B ремонт камеры Добавлено: 14 апр 2020, 11:24 |
прошивка сайта DAHUA SUPPORT DH_IPC_HX!XXX-Eos3_P_v2.420.0000.11.R.2017.06.12
U-Boot 2010.06-svn3105 (May 05 2016 - 07:25:42) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. data crc error, data crc:0x002c5566, crc:0x37a12b5a. Fail to read boot img. partition file version 2 rootfstype squashfs root /dev/mtdblock6 In: serial Out: serial Err: serial TEXT_BASE:81000000 fail to get updateflag partition info fail to get updateflag partition info Fail get partition from backup. get backup part info failedfail to get backup updateflag partition info fail to get updateflag offset and size Hit any key to stop autoboot: 0 > printenv bootargs=mem=47M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs bootcmd=kload 0x82000000; bootm 0x82000000 bootdelay=1 baudrate=115200 ethaddr=00:13:34:56:78:9A ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 ID=000000000000000000 da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite dk=tftp 0x82000000 kernel.img; flwrite du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img; flwrite tk=tftp 0x82000000 uImage; bootm appauto=1 loglevel=4 pd=tftp 0x82000000 pd-x.squashfs.img; flwrite filesize=7D6040 fileaddr=82000000 dh_keyboard=0 stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn3105 (May 05 2016 - 07:25:42)
Environment size: 980/262140 bytes
_
Alexpastur
Заголовок сообщения: Re: iIPC-HDW1220SP-0360B ремонт камеры Добавлено: 15 апр 2020, 14:35 |
не пошла на DH_IPC-HX12XX-Eos3_Eng_P_V2.622.0000001.13.R.170930 вот еще HFW1XXX-Alps http://ftp.viatec.ua/Dahua/Firmware/IPC ... 1XXX-Alps/ V2.622.0000000.31.R.171229 "IPC-HDBW1220EP-0280B-EZIP IPC-HDBW1220EP-0360B-EZIP IPC-HDBW1320EP-0280B-EZIP IPC-HDBW1320EP-0360B-EZIP IPC-HDW1220SP-0280B-EZIP ]
IPC-HDW1220SP-0360B-EZIP IPC-HDW1320SP-0280B-EZIP IPC-HDW1320SP-0360B-EZIP IPC-HFW1220SP-0280B-EZIP IPC-HFW1220SP-0360B-EZIP IPC-HFW1320SP-0280B-EZIP IPC-HFW1320SP-0360B-EZIP"
U-Boot 2010.06-svn3105 (May 05 2016 - 07:25:42) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. Fail to get uboot hd. fail to load partition.txt fail to load partition file fail to init partinfo In: serial Out: serial Err: serial TEXT_BASE:81000000 fail to get updateflag partition info Fail get partition from backup. get backup part info failedfail to get backup updateflag partition info fail to get updateflag offset and size Hit any key to stop autoboot: 0 > printenv bootargs=mem=47M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs bootcmd=kload 0x82000000; bootm 0x82000000 bootdelay=1 baudrate=115200 ethaddr=00:13:34:56:78:9A ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite dk=tftp 0x82000000 kernel.img; flwrite du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img; flwrite tk=tftp 0x82000000 uImage; bootm appauto=1 loglevel=4 pd=tftp 0x82000000 pd-x.squashfs.img; flwrite ID=2F0597DPAK00079 dh_keyboard=0 filesize=2BC040 fileaddr=82000000 stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn3105 (May 05 2016 - 07:25:42)
Environment size: 977/262140 bytes
fobos
Заголовок сообщения: Re: iIPC-HDW1220SP-0360B ремонт камеры Добавлено: 15 апр 2020, 18:09 |
Зарегистрирован: 24 май 2017, 01:56 Наличности на руках: 682.31
Сообщения: 644 Откуда: г. Ставрополь
fobos писал(а): без HWID камера работать не будет
Alexpastur
Заголовок сообщения: Re: iIPC-HDW1220SP-0360B ремонт камеры Добавлено: 16 апр 2020, 15:07 |
Fail to read boot img согласен. Вот еще одна камера HFW2200SP-v2-0360B printenv
Checking DDR......OK
UBL Version: 1.43t(DM368 12/25/2012) Oscillator: 24MHZ ARM Rate: 432 MHZ DDR Rate: 340 MHZ start watchdog BootMode: SPI Starting SPI Memory Copy... DONE
U-Boot 1.3.6 (jerry) (Feb 12 2014 - 21:00:07)
DRAM: 128 MB SF: Got idcode ef 40 17 SF: Detected W25Q64 with page size 256, total 8 MB In: serial Out: serial Err: serial Ethernet PHY: GENERIC @ 0x03,id:221513 total gio 2 gio[22]=1 gio[25]=1 Loading...DHBOOT# printenv bootdelay=3 baudrate=115200 eth2addr=00:01:5b:00:77:88 bootfile="uImage" appauto=1 single=0 dc=tftp 81a00000 custom-x.cramfs.img; flwrite dr=tftp 81a00000 romfs-x.cramfs.img; flwrite du=tftp 81a00000 user-x.cramfs.img; flwrite dd=tftp 81a00000 data-x.cramfs.img; flwrite dw=tftp 81a00000 web-x.cramfs.img; flwrite up=tftp 81a00000 update.img; flwrite tk=tftp 80800000 uImage; bootm 80800000 gionum=22.25 gioval=1.1 dh_com=0 autosip=192.168.254.254 autolip=192.168.1.108 autogw=192.168.1.1 autonm=255.255.255.0 bootargs=console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=squashfs ,nolock mem=78M video=davincifb:vid0=OFF:vid1=OFF:osd0=OFF:osd1=OFF armrate=432 HWID=IPC-HFW2200B-V2:01:02:02:03:05:00:01:00:00:00:00:1B0:00:00:02:00:00:00:00:00:80 devalias=IPC-HFW2200S-V2 bootcmd=fsload 0x80800000 0x00060000;bootm 0x80800000 da=protect off all;tftp 81a00000 dm365_ubl_boot_8M_spiflash.bin.img;flwrite filesize=660140 fileaddr=81A00000 ID=TZC4HW265W00024 ethaddr=90:02:A9:6C:0B:2E dh_keyboard=0 ipaddr=10.12.10.28 serverip=192.168.1.1 stdin=serial stdout=serial stderr=serial ver=U-Boot 1.3.6 (jerry) (Feb 12 2014 - 21:00:07)
Environment size: 1126/16380 bytes DHBOOT# reset Checking DDR......OK
DRAM: 128 MB SF: Got idcode ef 40 17 SF: Detected W25Q64 with page size 256, total 8 MB In: serial Out: serial Err: serial Ethernet PHY: GENERIC @ 0x03,id:221513 total gio 2 gio[22]=1 gio[25]=1 Loading... TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'upgrade_info_7db780a713a4.txt'. Load address: 0x80100000 Loading: * Retry count exceeded; starting again Fail to get info file! Init error! TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'failed.txt'. Load address: 0x80200000 Loading: * Retry count exceeded; starting again ==>use default images ## Booting kernel from Legacy Image at 80800000 ... Image Name: boot Image Type: ARM Linux Kernel Image (lzma compressed) Data Size: 1033256 Bytes = 1009 kB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
Starting kernel ...
Linux version 2.6.18_pro500-davinci_evm-arm_v5t_le (jenkins@localhost.localdomain) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Fri Mar 7 17:07:52 CST 2014 Kernel SVN NUM : 3011 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 Machine: DaVinci DM365 EVM Memory policy: ECC disabled, Data cache writeback DaVinci DM0365 variant 0x8 prediv = 6, pll0_mult = 85, postiv = 1, pll_div4 = 4, pll_rate = 680000000, pll_div6 = 15 PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000 PLL1_ARMRATE = 340000000 PLL0: vencrate_sd: 45333333, ddrrate: 340000000 mmcsdrate: 85000000 ##: prediv = 1, pll1_mult = 9, postdisv = 1, pll-rate = 432000000, pll_div2 = 1, pll_div4 = 21, pll-div5 = 16 PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000, ddrratePLL2 = 432000000 CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets Built 1 zonelists. Total pages: 19968 PID hash table entries: 512 (order: 9, 2048 bytes) Clock event device timer0_0 configured with caps set: 07 Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 78MB = 78MB total Memory: 76032KB available (2612K code, 277K data, 160K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 DaVinci: 104 gpio irqs MUX: initialized GPIO20 MUX: initialized I2C_SCL Generic PHY: Registered new driver NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 4096 bind 2048) TCP reno registered VFS: Disk quotas dquot_6.5.1 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) squashfs: version 3.4 (2008/08/26) Phillip Lougher squashfs: LZMA suppport for slax.org by jro JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc. Initializing Cryptographic API io scheduler noop registered (default) davinci_wdt_init proc enable rtc probe addr 0x68, probeByte 0x00... rtc probe addr 0x6f, probeByte 0x00... rtc probe addr 0x57, probeByte 0x00... rtc probe addr 0x32, probeByte 0x00... probe none!!! change to another probeByte rtc probe addr 0x68, probeByte 0x10... rtc probe addr 0x6f, probeByte 0x10... rtc probe addr 0x57, probeByte 0x10... rtc probe addr 0x32, probeByte 0x10... RTC_i2c_attach_client:addr:0x32 regValue:0x20 == Found RTC chip RX8010, I2C addr 0x32 == probe really none!!!DS1338 driver v1.04sem proc enable, Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled &&&: uart_add_one_port, line = 0, uartclk = 0 &&&: uart_add_one_port, line = 1, uartclk = 170000000 ttyS0: autoconf (0x0000, 0xfbc20000): <6>serial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550A &&&: uart_add_one_port, line = 0, uartclk = 24000000 ttyS1: autoconf (0x0000, 0xfbd06000): <6>serial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A &&&: uart_add_one_port, line = 1, uartclk = 170000000 PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 Linux video capture interface: v2.00 i2c /dev entries driver DaVinci flash: probing 16-bit flash bus MTD Sharp chip driver <ds@lineo.com> System bootup mode:SPI m25p80 spi0.0: s25fl064k (8192 Kbytes) Creating 7 MTD partitions on "spi0.0": 0x00000000-0x00040000 : "bootloader" 0x00040000-0x00060000 : "HWID" 0x00060000-0x00160000 : "kernel" 0x00160000-0x001c0000 : "data" 0x001c0000-0x00600000 : "rootfs" 0x00600000-0x00740000 : "web" 0x00740000-0x00800000 : "config" dm_spi.0: davinci SPI Controller driver at 0xc5176000 (irq = 42) use_dma=0 register master =0xc4842600;bus_num = 0 register master =0xc4842600;bus_num = 0 Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC). ASoC version 0.13.1 ALSA device list: No soundcards found. u32 classifier Performance counters on TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 10 lo: Disabled Privacy Extensions IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 drivers/rtc/hctosys.c: unable to open rtc device (rtc0) Time: timer0_1 clocksource has been installed. Clock event device timer0_0 configured with caps set: 08 Switched to high resolution mode on CPU 0 IP-Config: No network devices available. VFS: Mounted root (squashfs filesystem) readonly. Freeing init memory: 160K init started: BusyBox v1.9.1 (2014-02-27 13:33:52 CST) starting pid 125, tty '': '/etc/init.d/dnode' mount: mounting devpts on /dev/pts failed: No such file or directory mount: mounting none on /proc/bus/usb failed: No such file or directory starting pid 144, tty '': '/etc/init.d/rcS' Wed Dec 8 01:04:10 1999 0.000000 seconds [gpio] ************************************************************* [gpio] Build on Mar 7 2014 at 16:41:07. [gpio] SVN NUM: 3561. [gpio] ************************************************************* [gpio] dm365_gpio_init
[libdvr] libdvr.so Build on Dec 30 2013 at 16:21:17. [libdvr] SVN NUM: 5333. [gpio] CMD=9, Setting product type: 40 [li[gpio] CMD=4, Setting product fchip: 21 bdvr] ...dataBuf[gpio] CMD=3, Setting hardware version: 0 [0] 26, dataBuf[1] 4 [libdvr] Real fchip type is 21 [gpio] IPC_HFW2200B_V2<6>Davinci EMAC MII Bus: probed MAC address is 90:02:A9:6C:0B:2E TI DaVinci EMAC Linux version updated 4.0 ADDRCONF(NETDEV_UP): eth0: link is not ready
[libdvr] libdvr.so Build on Dec 30 2013 at 16:21:17. [libdvr] SVN NUM: 5333. [libdvr] ..netinit uses obsolete (PF_INET,SOCK_PACKET) .dataBuf[0] 26, dataBuf[1] 4 [libdvr] Real fchip type is 21 only init eth0 "netinit help" for help eth0: MAC: <90:02:a9:6c:0b:2e> IP: <192.168.1.108> netmask: <255.255.255.0> Gateway: <192.168.1.1> [libdvr] set success
IPV6: only init eth0 "netinit6 help" for help eth0: MAC: <90:02:a9:6c:0b:2e> IPV6: <2008::6> preFixLen: <112> [libdvr] WARN (../../src/net/network6.c|NetWorkDelIP|999): del ip failed:No such device or address IPV6 Gateway: <2008::1>
[libdvr] libdvr.so Build on Dec 30 2013 at 16:21:17. [libdvr] SVN NUM: 5333. [libdvr] ...dataBuf[0] 26, dataBuf[1] 4 [libdvr] Real fchip type is 21 type:40, Model=IPC-HFW2200B-V2
[li[bd6735] bd6735.ko Build on Mar 7 2014 at 17:14:21. bdvr] ...dataBuf[bd6735] SVN NUM: 3559. [0] 26, dataBuf[1] 4 [libdvr] Real fchip type is 2[bd6735] IPC-HFW3101C class IR-CUT,control by IO port 1 IPC Device [bd6735] <6>BD6735 MOTOR init:bd6735! [bd6735] BD6735 Initial OK [bd6735] ....turn into find ZERO.....
[libdvr] libdvr.so Build on Dec 30 2013 at 16:21:17. [libdvr] SVN NUM: 5333. [libdvr] ...dataBuf[0] 26, dataBuf[1] 4 [libdvr] Real fchip type is 21 syshelper V1.13(no exit): startup time=120 s, appauto=1, hctosystime=1500,type=IPC-HFW2200B-V2 [libdvr] ...dataBuf[0] 26, dataBuf[1] 4 [libdvr] Real fchip type is 21 coremnt not found
[li[dm365_ad] dm365_ad.ko Build on Mar 7 2014 at 17:05:20. bdvr] ...dataBuf[dm365_ad] SVN NUM: 13163. [0] 26, dataBuf[[dm365_ad] ==Enable ADC PSC successfully!== 1] 4 [libdvr] Real fchip type is 21 IPC-HFW2200B-V2 [dm365_ad] dm365_ad init:dm365_ad! [spi] Build on Mar 7 2014 at 17:19:06. [spi] SVN NUM: 2849. [spi] kernel: spi module insmod. SPIPLLK = 18 [spi] Start to set PSC and enable spi [spi] Start to set PSC and enable RTCIF [spi] Set RTC PSC success [spi] DH_PDT_ITC142_GB3A: Init PRTCSS Device PERI_CLKCTL:0x640f04fc [spi] pinmux4 is 0xaa800016 [spi] @@: SPI1 CLK Param :Prescale = 11
[sensor] Sensor.ko Build on Mar 7 2014 at 17:03:26. [sensor] SVN NUM: 3634. [sensor] The Sensor Driver Version:Ver 2.0 [sensor] Found I2C Device (i2c addr 0x18) [sensor] The AR0330 model ID is 0x2604 [sensor] sensor change format ->[23] [sensor] ar0330 init ok! [sensor] We found the sensor chip: ar0330 on i2c bus [sensor] sensor device init success [Crypt] platType = [0], DM36X = [0], A5S_CRYPT = [1], hi351x=[2]. [Crypt] major = [253], minor = [0] [Crypt] CRYPT_setChipOps ...... [Crypt] GIO = [1], g_dh_hardware_encode = [2] [Crypt] CRYPT_authenticate ...... error: write byte error error: write_nbytes failed error: verify_read_password failed, PAC = ffffffff error: authenticate failed [Crypt] ERROR (/home/li_guang/DM368_driver/IPC_cryptDrv/crypt/P_2013.02.22_CryptoMemory_DM8127_IPC/build/../src/crypt.c|crypt_init|1250): CRYPT_authenticate failed! [Crypt] ERROR (/home/li_guang/DM368_driver/IPC_cryptDrv/crypt/P_2013.02.22_CryptoMemory_DM8127_IPC/build/../src/crypt.c|crypt_init|1251): reboot........ <6>ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Restarting system. .
может что подскажете, постоянная перезагрузка.
