Текущее время: 29 мар 2024, 12:12
Koyper2009
Заголовок сообщения: Re: Помогите с дампом на Dahua HCVR5108H-S2 Добавлено: 12 апр 2021, 15:51 |
Зарегистрирован: 03 сен 2019, 11:14 Наличности на руках: 10.06
Сообщения: 10 Откуда: г. Измаил
0cmp okSYSTEM go...............DR 1.6 1GB
MP SPI-NOR Bootstrap v0.2
SPI020 Revision:0x10001
SPI flash ID code:c2 20 18
Boot image offset: 0x5000. size: 0x4b000. Booting Image .....
U-Boot 2013.01-svn1807 (Jul 08 2015 - 18:04:33)svn:1807
I2C: ready DRAM: 1008 MiB ROM CODE has enable I cache
Init 8210 PCIe RC...done
SPI mode SF: Got idcodes 00000000: c2 20 18 c2 . ..
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode
In: serial Out: serial Err: serial
------------------------------- ID:82101100 AC: 396 HC: 332 P1:1188 P4: 996 C7: 996 C6: 792 DR:1584 J: 332 H1: 396 H2: 396 ------------------------------- Net: eth0, eth1 [PRIME] 16M SF: Got idcodes 00000000: c2 20 18 c2 . ..
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode nice on GMAC1 found PHYID 0x001cc810 hwid_gpio_val=0x117 Hit any key to stop autoboot: 3 2 1 0 usb device not found part_table->offet:0x00e80000,part_table->size:0x00040000 SF: Got idcodes 00000000: c2 20 18 c2 . ..
### CRAMFS loading '/bmp_logo.bmp' to 0x100000 ### CRAMFS LOAD ERROR<ffffffff> for /bmp_logo.bmp! load log failed showlogo - showlogo - show the logo picture on screen.
Usage: showlogo RTL8201 found Phy ID = 0x001cc816 FULL PHY_SPEED_100M Using eth1 device TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'upgrade_info_7db780a713a4.txt'. Load address: 0x3000000 Loading: *T T T Retry count exceeded; starting again autoup - load update file from server
Usage: autoup part_table->offet:0x00060000,part_table->size:0x00c80000 SF: Got idcodes 00000000: c2 20 18 c2 . ..
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs loading '/slave/fc7500.bin' to 0x0 SF: Got idcodes 00000000: c2 20 18 c2 . ..
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e FATAL ERROR aborting: uncompress_directory_table: failed to read block lzma uncompress failed with error code 1 read_block: failed to read block @0xb7322e
! | Ozzy писал(а): | Еще раз такую партянку выложите не под спойлером, будет бан |
Koyper2009
Заголовок сообщения: Re: Помогите с дампом на Dahua HCVR5108H-S2 Добавлено: 12 апр 2021, 20:03 |
Менять на точно такую или можно поставить совместимую? ---------- Добавлено спустя 2 часа 42 минуты 3 секунды: ---------- Аналоги MX25L12805D и MX25L12845E, только найти их осталось. ---------- Добавлено спустя 44 минуты 25 секунд: ----------
Ещё лог после прошивки другого дампа. U-Boot 2013.01-svn2018 (Apr 13 2017 - 13:52:23)svn:2018
SPI mode SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
------------------------------- ID:82101100 AC: 360 HC: 332 P1:1080 P4: 996 C7: 996 C6: 720 DR:1440 J: 332 H1: 360 H2: 360 ------------------------------- Net: eth0 [PRIME] Warning: failed to set MAC address , eth1 Warning: failed to set MAC address
16M SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode nice on GMAC1 found PHYID 0x001cc810 hwid_gpio_val=0x117 Hit any key to stop autoboot: 3 2 1 0 usb device not found RTL8201 found Phy ID = 0x001cc816 FULL PHY_SPEED_100M Using eth1 device TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'upgrade_info_7db780a713a4.txt'. Load address: 0x3000000 Loading: *T T T Retry count exceeded; starting again tftp receive failed ,please check net environment autoup - load update file from server
Usage: autoup part_table->offet:0x00e80000,part_table->size:0x00040000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
### CRAMFS loading '/bmp_logo.bmp' to 0x100000 BMPW:300 BMPH:113 bit:16 biSizeImage:67802 bmp_size = 67802 start hdmi polling thread. HDMI cable not connect part_table->offet:0x00060000,part_table->size:0x00c80000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs loading '/slave/fc7500.bin' to 0x0 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs load complete: 634728 bytes loaded to 0x0 part_table->offet:0x00060000,part_table->size:0x00c80000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs loading '/boot/uImage' to 0x18100000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs load complete: 2020632 bytes loaded to 0x18100000 part_table->offet:0x00060000,part_table->size:0x00c80000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs loading '/slave/rootfs_slave' to 0x3f600000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs load complete: 1380476 bytes loaded to 0x3f600000 part_table->offet:0x00060000,part_table->size:0x00c80000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs loading '/boot/uImage' to 0x2000000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs load complete: 2020632 bytes loaded to 0x2000000 ## Booting kernel from Legacy Image at 02000000 ... Image Name: gm8210 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2020568 Bytes = 1.9 MiB Load Address: 02000000 Entry Point: 02000040 Verifying Checksum ... OK XIP Kernel Image ... OK OK slave: initrd=0x3f600000,0x300000 ramdisk_size=10240 root=/dev/ram rw init=/init mem=256M@0x10000000 gmmem=190M console=ttyS0,115200 mem=512M@0x20000000 : mem=240M@0x01000000 gmmem=30M console=ttyS0,115200 user_debug=31 root=/dev/mtdblock1 dh_keyboard=1 load_modules=1 matchinit_mode=16852 env_off=327680 env_size=32768 sec_era=2
Starting kernel ...
Uncompressing Linux... done, booting the kernel. start to copy FC7500 core boot image at 0x18100000 and wait response... wait FA6 core response ok done, FA7 core now is booting.
Koyper2009
Заголовок сообщения: Re: Помогите с дампом на Dahua HCVR5108H-S2 Добавлено: 15 апр 2021, 13:25 |
Прилагаю полный лог загрузки после команд setenv dh_keyboard 0, saveenv, reset. Помогите пожалуйста растолковать.
0cmp okSYSTEM go...............set ddr1 arg DR 1.6 1GB Test addr: 0x0, len = 0x100000 Test pass, pattern 0x5a5a5a5a, 0xa5a5a5a5 Test addr: 0x20000000, len = 0x100000 Test pass, pattern 0x5a5a5a5a, 0xa5a5a5a5 MP SPI-NOR Bootstrap v0.2 SPI020 Revision:0x10001 SPI flash ID code:c2 20 18 Boot image offset: 0x5000. size: 0x4b000. Booting Image .....
------------------------------- ID:82101100 AC: 360 HC: 332 P1:1080 P4: 996 C7: 996 C6: 720 DR:1440 J: 332 H1: 360 H2: 360 ------------------------------- Net: eth0, eth1 [PRIME] 16M SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode nice on GMAC1 found PHYID 0x001cc810 hwid_gpio_val=0x117 Hit any key to stop autoboot: 0 usb device not found RTL8201 found Phy ID = 0x001cc816 FULL PHY_SPEED_100M Using eth1 device TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending throu gh gateway 192.168.1.1 Filename 'upgrade_info_7db780a713a4.txt'. Load address: 0x3000000 Loading: * Abort autoup - load update file from server
Usage: autoup GM # <INTERRUPT> GM # <INTERRUPT> GM # <INTERRUPT> GM # <INTERRUPT> GM # setenv dh_keyboard 0 GM # saveenv Saving Environment to SPI Flash... SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode Erasing SPI flash...Writing to SPI flash...done GM # reset resetting ... 0cmp okSYSTEM go...............set ddr1 arg DR 1.6 1GB Test addr: 0x0, len = 0x100000 Test pass, pattern 0x5a5a5a5a, 0xa5a5a5a5 Test addr: 0x20000000, len = 0x100000 Test pass, pattern 0x5a5a5a5a, 0xa5a5a5a5 MP SPI-NOR Bootstrap v0.2 SPI020 Revision:0x10001 SPI flash ID code:c2 20 18 Boot image offset: 0x5000. size: 0x4b000. Booting Image .....
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode nice on GMAC1 found PHYID 0x001cc810 hwid_gpio_val=0x117 Hit any key to stop autoboot: 0 usb device not found RTL8201 found Phy ID = 0x001cc816 FULL PHY_SPEED_100M Using eth1 device TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'upgrade_info_7db780a713a4.txt'. Load address: 0x3000000 Loading: T T T Retry count exceeded; starting again tftp receive failed ,please check net environment autoup - load update file from server
### CRAMFS loading '/bmp_logo.bmp' to 0x100000 BMPW:300 BMPH:113 bit:16 biSizeImage:67802 bmp_size = 67802 start hdmi polling thread. part_table->offet:0x00060000,part_table->size:0x00c80000 SF: Got idcodes 00000000: c2 20 18 c2 . .. sector erase support!
SF: Detected MX25L12805D with page size 64 KiB, total 16 MiB flash is 3byte mode compressor use:lzma ### squashfs load complete: 2020632 bytes loaded to 0x2000000 ## Booting kernel from Legacy Image at 02000000 ... Image Name: gm8210 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2020568 Bytes = 1.9 MiB Load Address: 02000000 Entry Point: 02000040 Verifying Checksum ... OK XIP Kernel Image ... OK OK slave: initrd=0x3f600000,0x300000 ramdisk_size=10240 root=/dev/ram rw init=/init mem=256M@0x10000000 gmmem=190M console=ttyS0,115200 mem=512M@0x20000000 : mem=240M@0x01000000 gmmem=30M console=ttyS0,115200 user_debug=31 root=/dev/mtdblock1 dh_keyboard=0 load_modules=1 matchinit_mode=16852 env_off=327680 env_size=32768 sec_era=2
Starting kernel ...
Uncompressing Linux... done, booting the kernel. start to copy FC7500 core boot image at 0x18100000 and wait response... wait FA6 core response ok done, FA7 core now is booting. Booting Linux on physical CPU 0 Linux version 3.3.0 SVN:6105 (29830@yanfa213) (gcc version 4.4.0 20100318 (experimental) (Buildroot 2012.02) ) #7 PREEMPT Fri Mar 17 15:58:37 CST 2017 CPU: FA7 [66057261] revision 1 (ARMv5TE), cr=00053177 CPU PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Machine: Grain-Media GM8210 Memory policy: ECC disabled, Data cache writeback Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60960 Kernel command line: mem=240M@0x01000000 gmmem=30M console=ttyS0,115200 user_debug=31 root=/dev/mtdblock1 dh_keyboard=0 load_modules=1 matchinit_mode=16852 env_off=327680 env_size=32768 sec_era=2 ==>start:"=0 load_modules=1 matchinit_mode=16852 env_off=327680 env_size=32768 sec_era=2" use_console:1 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 240MB = 240MB total Memory: 238184k/238184k available, 7576k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0x8f800000 - 0xff000000 (1784 MB) lowmem : 0x80000000 - 0x8f000000 ( 240 MB) modules : 0x7f000000 - 0x80000000 ( 16 MB) .text : 0x80008000 - 0x804b8324 (4801 kB) .init : 0x804b9000 - 0x804db000 ( 136 kB) .data : 0x804dc000 - 0x80500560 ( 146 kB) .bss : 0x80500584 - 0x80548618 ( 289 kB) NR_IRQS:128 Timer use APB0 clock gm_jiffies_init, system HZ: 100, pClk: 45000000 console [ttyS0] enabled Calibrating delay loop... 990.41 BogoMIPS (lpj=4952064) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok Setting up static identity map for 0x137d260 - 0x137d2cc devtmpfs: initialized FMEM: 7680 pages(0x1e00000 bytes) from bank0 are reserved for Frammap. FMEM: Logical memory ends up at 0x8f000000, init_mm:0x80004000(0x1004000), PAGE_OFFSET:0x80000000(phys:0x1000000), FMEM: FA726 Test and Debug Register: 0x100000 Fmem hooks external data-abort handler. NET: Registered protocol family 16 PMU: Mapped at 0xfe000000 IC: GM8210, version: 0x11 PCIE PMU: Mapped at 0xfe00a000 IC: GM8312(1) iotable: VA: 0xfe000000, PA: 0x99000000, Length: 4096 iotable: VA: 0xfe001000, PA: 0x98300000, Length: 4096 iotable: VA: 0xfe002000, PA: 0x98400000, Length: 4096 iotable: VA: 0xfe003000, PA: 0x98500000, Length: 4096 iotable: VA: 0xfe004000, PA: 0x98800000, Length: 4096 iotable: VA: 0xfe005000, PA: 0x98900000, Length: 4096 iotable: VA: 0xfe006000, PA: 0x82600000, Length: 4096 iotable: VA: 0xfe007000, PA: 0x99100000, Length: 4096 iotable: VA: 0xfe008000, PA: 0x98d00000, Length: 4096 iotable: VA: 0xfe009000, PA: 0x96000000, Length: 4096 iotable: VA: 0xfe00a000, PA: 0xc2700000, Length: 4096 iotable: VA: 0xfe00b000, PA: 0xc2800000, Length: 4096 8210 PCIE: 0x8f80a000(0x99e00000), 8312 PCIE: 0x8f80c000(0xc3700000) bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Switching to clocksource fttmr010:1 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Video Timer(timer3) Max 95000ms in 0xfecf52c0 HZ. ftdmac030 ftdmac030.0: DMA engine driver: irq 34, mapped at 8f80e000 squashfs: version 4.0 (2009/01/31) Phillip Lougher JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. msgmni has been set to 465 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) gpiochip_add: registered GPIOs 0 to 31 on device: ftgpio010.0 probe ftgpio010.0 OK, at 0x8f878000 gpiochip_add: registered GPIOs 32 to 63 on device: ftgpio010.1 probe ftgpio010.1 OK, at 0x8f87a000 Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled serial8250: ttyS0 at I/O 0xfe001000 (irq = 9) is a 16550A serial8250: ttyS2 at I/O 0xfe003000 (irq = 20) is a 16550A serial8250: ttyS3 at I/O 0xfe004000 (irq = 21) is a 16550A serial8250: ttyS4 at I/O 0xfe005000 (irq = 22) is a 16550A serial8250: ttyS5 at I/O 0xfe006000 (irq = 25) is a 16550A brd: module loaded loop: module loaded FTSATA100_AHCI driver version 0.15 GM SATAPHY clock source : SATA0==PLL, SATA1==SATA0, SATA2==SATA1, SATA3==SATA2 GM SATAPHY Clock = 30 MHz GM SATA0 config iSATA PHY setting GM SATA0 PHY program i2c register offset 0x03, value=0x40 GM SATA1 config iSATA PHY setting GM SATA1 PHY program i2c register offset 0x03, value=0x40 GM SATA2 config iSATA PHY setting GM SATA2 PHY program i2c register offset 0x03, value=0x40 GM SATA3 config iSATA PHY setting GM SATA3 PHY program i2c register offset 0x03, value=0x40 ahci ftsata100.0: forcing PORTS_IMPL to 0x1 ahci: SSS flag set, parallel bus scan disabled ahci ftsata100.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode ahci ftsata100.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc scsi0 : ahci_platform ata1: SATA max UDMA/133 mmio [mem 0xc1100000-0xc1100fff] port 0x100 irq 97 ahci ftsata100.1: forcing PORTS_IMPL to 0x1 ahci: SSS flag set, parallel bus scan disabled ahci ftsata100.1: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode ahci ftsata100.1: flags: ncq sntf stag pm led clo only pmp pio slum part ccc scsi1 : ahci_platform ata2: SATA max UDMA/133 mmio [mem 0xc1200000-0xc1200fff] port 0x100 irq 98 ahci ftsata100.2: forcing PORTS_IMPL to 0x1 ahci: SSS flag set, parallel bus scan disabled ahci ftsata100.2: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode ahci ftsata100.2: flags: ncq sntf stag pm led clo only pmp pio slum part ccc scsi2 : ahci_platform ata3: SATA max UDMA/133 mmio [mem 0xc1300000-0xc1300fff] port 0x100 irq 99 ahci ftsata100.3: forcing PORTS_IMPL to 0x1 ahci: SSS flag set, parallel bus scan disabled ahci ftsata100.3: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode ahci ftsata100.3: flags: ncq sntf stag pm led clo only pmp pio slum part ccc scsi3 : ahci_platform ata4: SATA max UDMA/133 mmio [mem 0xc1400000-0xc1400fff] port 0x100 irq 100 Not for NAND pin mux SPI020 init ftspi020 ftspi020.0: Faraday FTSPI020 Controller at 0x80300000(0x8f898000) irq 92. spi spi0.0: setup: bpw 8 mode 3 CLK = 332000000,50000000 CLK div field set 1 ERASE SECTOR 64K SPI_FLASH spi0.0: MX25L12845E (16384 Kbytes) Creating 7 MTD partitions on "wb_spi_flash": 0x000000000000-0x000000060000 : "boot" 0x000000060000-0x000000ce0000 : "rootfs" 0x000000ce0000-0x000000e60000 : "web" 0x000000e60000-0x000000e80000 : "custom" 0x000000e80000-0x000000ec0000 : "logo" 0x000000ec0000-0x000001000000 : "config" 0x000000000000-0x000001000000 : "ALL" Probe FTSPI020 SPI Controller at 0x80300000 (irq 92) bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) nice use GMAC1 ftgmac100: Loading version 0.1 ... ata1: SATA link down (SStatus 0 SControl 310) ata2: SATA link down (SStatus 0 SControl 310) ata3: SATA link down (SStatus 0 SControl 310) ata4: SATA link down (SStatus 0 SControl 310) ftgmac100-1-mdio: probed found Phy ID:0x001cc816 ftgmac100-1 ftgmac100-1.1: eth0: 1 tx queue used (max: 2) ftgmac100-1 ftgmac100-1.1: eth0: 1 rx queue used (max: 1) ftgmac100-1 ftgmac100-1.1: eth0: irq 33, mapped at 8f89a000 ftgmac100-1 ftgmac100-1.1: eth0: MAC address 20:13:12:26:12:23 PPP generic driver version 2.4.2 PPP BSD Compression module registered PPP Deflate Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 usbcore: registered new interface driver cdc_ncm ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver FOTG2XX Controller Initialization Enter Device A Drive Vbus because of ID pin shows Device A fotg210 fotg210.0: FOTG2XX fotg210 fotg210.0: new USB bus registered, assigned bus number 1 fotg210 fotg210.0: irq 101, io mem 0xc1500000 fotg210 fotg210.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected FOTG2XX Controller Initialization Enter Device A Drive Vbus because of ID pin shows Device A fotg210 fotg210.1: FOTG2XX fotg210 fotg210.1: new USB bus registered, assigned bus number 2 fotg210 fotg210.1: irq 102, io mem 0xc1600000 fotg210 fotg210.1: USB 2.0 started, EHCI 1.00 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected FOTG2XX Controller Initialization Enter Device A Drive Vbus because of ID pin shows Device A fotg210 fotg210.2: FOTG2XX fotg210 fotg210.2: new USB bus registered, assigned bus number 3 fotg210 fotg210.2: irq 103, io mem 0xc1700000 fotg210 fotg210.2: USB 2.0 started, EHCI 1.00 hub 3-0:1.0: USB hub found hub 3-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mousedev: PS/2 mouse device common for all mice i2c /dev entries driver ftiic010 ftiic010.0: irq 18, mapped at 8f8aa000 usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP cubic registered NET: Registered protocol family 10 Mobile IPv6 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 VFS: Mounted root (squashfs filesystem) readonly on device 31:1. devtmpfs: mounted Freeing init memory: 136K [RCS]: /etc/init.d/S00devs mknod: /dev/console: File exists mkdir: can't create directory '/dev/input': File exists mknod: /dev/input/mice: File exists [RCS]: /etc/init.d/S01udev mdev: applet not found [RCS]: /etc/init.d/S80network [RCS]: /etc/init.d/S81toe [RCS]: /etc/init.d/S99dh Success to mount jffs2 /dev/mtdblock5!!
7z ANSI-C Decoder 9.20 : Igor Pavlov : Public domain : 2010-11-18
Extracting lib/ Extracting lib/avss.ko Extracting lib/cpu_comm_fa726.ko Extracting lib/driverbox.ko Extracting lib/fa726_lcd.ko Extracting lib/fe_common.ko Extracting lib/frammap.ko Extracting lib/ft2dge.ko Extracting lib/lc_ether.ko Extracting lib/log.ko Extracting lib/osa.ko Extracting lib/rt5370sta.ko Extracting lib/usbserial.ko Extracting lib/vpd_master.ko
Everything is Ok cp: can't stat '/var/lib/*.cfg': No such file or directory Setting hostname ... [ftgmac100_set_rfifo_size:2106]size_sel=0x3,rxthr_size=0xC0 Insmod Connect drivers!!
############## frammap.ko svn 28748 Apr 17 2017 18:21:45 Frammap: DDR0: memory base=0xd800000, memory size=0x1e00000, align_size = 4K. Frammap: version 1.1.2, and the system has 1 DDR. Frammap: fail to open /mnt/mtd/config_8210, /tmp/template_8210 is created.
cpucomm svn 28748 Apr 17 2017 18:21:41 ep_cnt = 0, non_ep_cnt = 1 #### open /proc/cmdline succeed!!!#### #### close /proc/cmdline succeed!!!#### #### not find /proc/cmdline fail!!!#### mem_alloc_init: physical memory begins at 0xd800000, ends at 0xe000000, 0x800000 bytes. cpucomm: PCI host, pool paddr:0xd800000, axi base:0x0, pci DDR base:0xf0000000, <guard:0x2000000> --- mbox paddr: 0xd800000, vaddr: 0x90000000 --- Wait FA626 core ready.....phy speed is 10, half duplex [ftgmac100_set_rfifo_size:2106]size_sel=0x3,rxthr_size=0xC0 ...done cpucomm: board FA626, PoolMem:(paddr:0x14000000, size:0x1000000, vaddr:0x91000000, cbaddr:0x93000000). ShareMem:(paddr:0x14004000, size:0x12000, vaddr:0x91004000) ok, cpu_comm_2.7 driver is executed in FA726 core with dma_type: 0(1). ---------------------------------------------------------------- ddr name: frammap0 base: 0xd800000 end: 0xf600000 size: 0x1e00000 bytes
memory allocated: 0x800000 bytes memory free: 0x1600000 bytes[OSA-DRV] OSA Build on Apr 17 2017 at 18:13:33.
max available slice: 0x1600000 bytes memory [OSA-DRV] SVN NUM: 1795.
allocate count: 1 clear address: 0xe000000 d[OSA-DRV] Monitor Task pid=136 tid=136 irty pages: 2048 clear pages: 5632 size alignment: 0x1000
------------------------------------------------------------ driverbox.ko SVN version:11526 build date: Mar 17 2017 time: 15:59:58 ------------------------------------------------------------ open hwid config file failed ProlicyTable[0] = 0 ProlicyTable[1] = 2 ProlicyTable[2] = 1 ProlicyTable[3] = 0 ProlicyTable[4] = 0 ProlicyTable[5] = 0 ProlicyTable[6] = 0 [DRVBOX] Default product_pre_deal system gpio infor:111010001 fun:dh_resource_init,line:412, AnalogChnCount:8 name:HCVR5108H-S2, AnalogChnCount:8 [DRVBOX] our product ID: 0x040000AA [DRVBOX] our board ID: 0x03000007 host_hwid_value:[0x002004cd00040506][0x000000104000828c] [DRVBOX] NICE, This System Has No I2c SwitchChips. [DRVBOX] NICE, This System Has No Signal Selector. [DRVBOX] WDT base virtual address = 8fe6a000 [DRVBOX] Total 0 spi bus registered [ExpComDriver]: NICE, This System Has No ExpandComs. This Machine Has No Expand Coms. This Machine Has No LCD devices. [INFRARED]: NICE, This Machine Doesn't Support INFRARED. [DRVBOX] WARN (dh_misc_init_device|147): UNKONW TYPE. Using Default. [DRVBOX] WARN (default_misc_init|63): Default default_misc_init bpamem_init NICE, The Kernel Supports BPA, But We Don't Use it. NICE, This System Has No EDMA FUNCTION. [DRVBOX] WARN (plat_rtc_init|76): System has no SOC RTC module. No TouchScreen [DRVBOX] [MBUS]: NICE, This Machine Doesn't Support MBUS. [DRVBOX] [PSTN]: NICE, This Machine Doesn't Support PSTN. lc_cdc_change mtu 1492 usbcore: registered new interface driver lc_ether usbcore: registered new interface driver usbserial USB Serial support registered for generic usbcore: registered new interface driver usbserial_generic usbserial: USB Serial Driver core rtusb init rt2870 ---> rt3070_2.5.0.3 SVN_VERSION:3114 Complie time Apr 17 2017 18:16:41 usbcore: registered new interface driver rt2870 insmod: can't open '/var/lib/cdc_ether.ko': No such file or directory [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:41 Value:0x2 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:42 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:515 Value:0x1 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:43 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:516 Value:0x1 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:517 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:518 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:44 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:45 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:46 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:47 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:48 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:49 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:50 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:51 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:52 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:53 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:57 Value:0x2 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:60 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:62 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:63 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:64 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:65 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:71 Value:0x40000aa [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:56 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:69 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:75 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:79 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:74 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>179): Info: Hwid Info Item:80 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:640 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:641 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:642 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:643 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:644 Value:0x0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:645 Value:0x8 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:646 Value:0x0 [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 3ef [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>186): Info: Hwid Info Item:647 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 454 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:648 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 455 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:649 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 456 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:650 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 457 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:651 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 458 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:652 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 459 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:653 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 45a [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:654 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 45b [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:655 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 45c [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:656 Value:0xfffffffe [DRVBOX] ERROR (DvrGetHwidInformation|1146): unknow cmd 45d [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>193): Info: Hwid Info Item:657 Value:0xfffffffe [AVSS] INFO (func = AVSS_ReadConfigFile line =>165): video_channel_mode 0 hdmi2_reslution 0 -> 56 0 [AVSS] INFO (func = AVSS_ReadConfigFile line =>165): hdmi2_reslution 0 -> 58 0 [AVSS] INFO (func = __AVSS_DvrSetHwidInfo_Init line =>211): Info: Hwid Info Addr:0x8b315000 Size:0x1000
****************************************************************************** GENERAL: AVSS Version: V0.00.29 Svn: 3743+ Compile at Apr 17 2017 18:17:42 ****************************************************************************** get_standard_string: "PAL" get_resolution_string:"1280x1024" do nothing! video_resolution: 7 tar: removing leading '/' from member names mnt/mtd/Config/output_type mnt/mtd/Config/input_res mnt/mtd/avss.info mnt/mtd/Config/standard tar: /mnt/mtd/Config/vcapMode.cfg: No such file or directory tar: error exit delayed from previous errors HOST_FA726::Start to send msg... HOST_FA726::Finish to send msg... log: module license 'GM' taints kernel. Disabling lock debugging due to kernel taint
log.ko:svn 28748 Apr 17 2017 18:21:37 (mmap 0x8b3b0000 size 0xc000)
LOG base 0x90801000 size 1024K (start pointer 0x7f1b8444) PAGE_OFFSET(0x80000000) VMALLOC START(0x8f800000) HZ(100) open /mnt/mtd/Config/vcapMode.cfg error cpu_type=18 video_chip=19 digital_chn_num=0 video_chn_num=8 speceial_custom 0,audio_chn_num=1 abroad=0 hwid=0x40000aa iva_support=0 mic_mux=1 tv_support=0 vstd=0 ad_dev_num=2 input_res 0 vcap_mode=-1 tvvo_mode:0
fa726_lcd.ko: svn 28748 Apr 17 2017 18:21:41 zebra_device_open -- lcd0_drv opens a channel for read/write. zebra_device_open -- lcd2_drv opens a channel for read/write. Initialize FA726 LCD driver ... Wait FA626 LCD0 driver to be ready ......... done(6) FB0, physical addr: 0x15001000 LCD0, plane0, in_fmt: 0, xres: 1280, yres: 1024, bpp: 16 FB1, physical addr: 0x1543a000 LCD0, plane1, in_fmt: 18, xres: 1280, yres: 1024, bpp: 16 FB2, physical addr: 0x15873000 LCD0, plane2, in_fmt: 23, xres: 1280, yres: 1024, bpp: 1 zebra_device_open -- hdmi opens a channel for read/write. Wait FA626 LCD2 driver to be ready ... done(0) FB0, physical addr: 0x158fb000 LCD2, plane0, in_fmt: 0, xres: 720, yres: 576, bpp: 16 FB1, physical addr: 0x158fb000 LCD2, plane1, in_fmt: 18, xres: 720, yres: 576, bpp: 16 FB2, physical addr: 0x159c7000 LCD2, plane2, in_fmt: 23, xres: 720, yres: 576, bpp: 1 probe done! scaler_trans_init, version: 0x20140822 fe_common version 140714 videograph ioctl v0.38
vpd_master.ko v1.1 svn 28748 Apr 17 2017 18:21:33 vpd_master: chipnr=1. cpucomm master init: register major chip master cpu m01: Bus(100) zebra_device_open -- m01 opens a channel for read/write. getcp_m01: Bus(101) zebra_device_open -- getcp_m01 opens a channel for read/write. qbs_m01: Bus(102) zebra_device_open -- qbs_m01 opens a channel for read/write. pk_m01: Bus(103) zebra_device_open -- pk_m01 opens a channel for read/write. Set VPD debug level(0). Debug Level:0 [SYSNET-12894] MSG LibSysNet Module Version 6 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x60000 [LIBPRCCOM] page size: 0x1 [LIBDVR] EnvBuf Size=8000, used Size=1514 [SYSNET-12894] MSG ifconfig eth0 hw ether 20:13:12:26:12:23 Successful [ftgmac100_set_rfifo_size:2106]size_sel=0x3,rxthr_size=0xC0 ADDRCONF(NETDEV_UP): eth0: link is not ready [SYSNET-12894] MSG has no bondx dev at /proc/net/dev ----------------------------------------------------------------- Version: 12894(Apr 17 2017 18:11:09) Usage: netinit [ethname] [Ipaddress] [Netmask] [Gateway] Example for set all(ip, netmask, gateway): netinit eth0 192.168.1.100 255.255.0.0 192.168.1.1 Example for set ip : netinit 192.168.1.34 Example for set netmask : netinit NULL 255.255.0.0(keep original ip) ----------------------------------------------------------------- eth0 etinit uses obsolete (PF_INET,SOCK_PACKET) 0;32;32m[LIBPRCCOM] I2C BusHandle=49324300.[LIBDVR] Cmos dev init success [SYSNET-12894] MSG [eth0]mac : 20-13-12-26-12-23 [SYSNET-12894] ERR (config.c|NetWorkGetFromCmos|308): NetWorkGetFromCmos flag = 0xa,cmos.reserved[0] 0,crcdata 67 [SYSNET-12894] ERR (config.c|NetWorkGetFromCmos|308): NetWorkGetFromCmos flag = 0xa,cmos.reserved[0] 0,crcdata 67 [ftgmac100_set_rfifo_size:2106]size_sel=0x3,rxthr_size=0xC0 ADDRCONF(NETDEV_UP): eth0: link is not ready [SYSNET-12894] ERR (config.c|NetWorkGetFromCmos|308): NetWorkGetFromCmos flag = 0xa,cmos.reserved[0] 0,crcdata 67 ip : 192.168.1.108 netmask : 255.255.255.0 gateway : 192.168.1.1 mtu : 1500
[SYSNET-12894] ERR (config.c|NetWorkGetFromCmos|308): NetWorkGetFromCmos flag = 0xa,cmos.reserved[0] 0,crcdata 67 [SYSNET-12894] MSG Mark Cmos.
==============> 3gnet version: 1.00 - Complie time Apr 7 2017 13:45:01 SvnVersion = 4446<============= telnetd: applet not found kernel version = 3.3.0
ioctl DH_GET_3G_RES called
i2c i2c-0: NAK! Extracting Challenge
Everything is Ok
----------------------------------------------------------- | libdvr.a version: 11527 - Apr 17 2017 18:11:03 | libsysbase ver[DRVBOX] initing UART(2) sion: 11527 - Apr 17 2017 18:11:03 -------------------------------------------[DRVBOX] Kernel I2cDevRes Hit, i2c handle=49324300... ----------------
| libres version: 11345 - Apr 17 2017 18:10:49 DRVBOX] initing UART(3) ;32;32m[LIBPRCCOM] GpioManager Init sucessed. | libcom version: 11345 - Apr 17 2017 18:10:49 [LIBDVR] system using watchdog to reboot. [LIBDVR] system using watchdog to shutdown. GpioDevProbing(port:0 bit:8 Idx:0 type:0) Alloc New Gpio(port:0 bit:8 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). [LIBDVR] system beep type: GPIO. [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x60000 [LIBPRCCOM] page size: 0x1 [LIBDVR] EnvBuf Size=8000, used Size=1514 [LIBDVR] no alarm in dev [LIBDVR] no alarm out dev!! [LIBDVR] noNeed to set alarm valid type in dev [LIBDVR] Create alarm in device success [LIBDVR] Create alarm out device success [LIBDVR] Create alarm out device success GpioDevProbing(port:0 bit:29 Idx:0 type:0) Alloc New Gpio(port:0 bit:29 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). GpioDevProbing(port:0 bit:30 Idx:0 type:0) Alloc New Gpio(port:0 bit:30 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). [LIBPRCCOM] unknow RtsUseMode SupportWorkMode = 2, WorkMode = 1 [LIBPRCCOM] WARN (UartOpen|324): index = 2, name = /dev/ttyS2 has opened [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0xc80000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x180000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x20000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x40000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x140000 [LIBPRCCOM] page size: 0x1 no front board key or not support, row = 0, col = 0 [LIBPRCCOM] I2C BusHandle=49324300.[LIBDVR] Cmos dev init success [LIBDVR] RTC_RX8010 rtc initing... [LIBDVR] rtc adjust policy(system adjust RTC) [LIBDVR] RX8010_FLAGREG_OFF is 0x20 [LIBDVR] Rtc dev init success GpioDevProbing(port:0 bit:9 Idx:0 type:0) Alloc New Gpio(port:0 bit:9 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). SupportWorkMod i2c i2c-0: NAK! e = 4, WorkMode = 2 [LIBDVR] WARN (SysGetTimezone|254): Time zone not set. [LIBDVR] init: Setting system time from RTC time. [LIBDVR] unknow dev type [LIBDVR] SERIAL_TYPE_UNKNOW | libad version: 11345 - Apr 17 2017 18:10:45 [LIBDVR] WARN (GpsDevInit|244): No GpsDev [LIBDVR] Creating New IR Devs, Total 0 Devices [LIBDVR] DH_BASELINE_2_0 not implement this module [LIBDVR] This dev has no encrypt chip [LIBDVR] dul-backup: DO NOT SUPPORT. ********************************************************* | PRODUCT INFORMATION | libsysbase version: 11527 - Apr 17 2017 18:10:59 | 1.system information | ProductName: HCVR5108H-S2 | ModCapMask: 0 | GpsModType: NO | ForNRT: YES | ForATM: NO | HasAudioBoard: YES | HasLoopBoard: NO | HasMatrixBoard: NO | HasPtzBoard: YES | HasWlanBoard: NO | BeepType: GPIO | SystemRestType: TEMP DON'T KNOW | DspCount: 0 | ProductType: HCVR | ProductSubType: NO RS232 | CpldVersion: 104 | CpuChipType: GM8210 | IsInland: ABROAD | SupportEsata: NO | SupportPm: YES | AppVersion: 0 | SdcardToDisk: NO | NetType: Normal | SwitchPoeNumber: 0 | DspChip: NONE | VideoChip: DH9910_1080P | AudioMode: STxx control | FbdSize: Base | NetCard: Single | FbdDigit: NO | FbdShift: NO | AudioInterface: Mul_audio | SupportHdmi: YES | VideoTour: YES | DiskInterface: NO | SupportLcd: NO | HdVersion: 0 | ProductVersion: A | DevSubType: 0 | PoePortNum: 0 | ProductTypeV2: 0 | ProductSubTypeV2: 0 | CpuChipIdV2: 0 | VideoInputNumV2: 8 | VideoOutputNumV2: 0 | AudioInputNumV2: 0 | AudioOutputNumV2: 0 |VideoStreamInputNumV2: 0 |AudioStreamInputNumV2: 0 | VideoChnEncodeNumV2: 0 | AudioChnEncodeNumV2: 0 | VideoChnDecodeNumV2: 0 | AudioChnDecodeNumV2: 0 | 2.Env information | Env startaddr: 0x50000 | Env size: 0x8000 | 3.Alarm information | Alarm in: 0 | Alarm out: 0 | 4.Frontboard information | Frontboard count: 2 | 5.Flash information | Flash chip count: 1 | chip 0 size: 0x1000000 | chip 0 baseaddr: 0xa0000000 | 6.Cmos,Rtc information | Cmos,Rtc chip: RX8010SJ | Cmos,Rtc chip addr: 0x64 | Cmos offset: 0x20 | 7.others information | VideoChannel: 8 | AudioChannel: 1 | DigitalChannel: 0 | DiskNumber: 1 | CDRomSupportNum: 1 | PlayBackNum: 0 | SupportRs232: NO | SupportRs485: YES ********************************************************* dvrhelper version: 11527 Apr 17 2017 18:11:01 [LIBDVR] dvrhelper: father process(dvrhelper) waitting for State = 0... +++++++++++++++++++++++++++++++++ Name:challenger log Version:ver 1.01 Build date:Apr 17 2017 18:07:20 Desc:challenger log ver 1.01 +++++++++++++++++++++++++++++++++ 00:00:21|trace CThread name:DevHDiskReader m_internal:0x1bac830 +++++++++++++++++++++++++++++++++ Name:storage Version:1.03.0 Build date:Apr 17 2017 17:53:08 Desc:DriverManager release +++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++ Name:manager Version:1.02.1 Build date:Apr 17 2017 17:47:52 Desc: +++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++ Name:manager Version:1.02.1 Build date:Apr 17 2017 17:47:56 Desc: +++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++ Name:guictrls Version:1.05.5 Build date:Apr 17 2017 17:47:34 Desc:GUI ctrls Relese +++++++++++++++++++++++++++++++++ main argv[0]:/var/Challenge Run Challenge [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x60000 [LIBPRCCOM] page size: 0x1 [LIBDVR] EnvBuf Size=8000, used Size=1514 00:00:21|[NetFramework] info NetThread.cpp 193 tid:251 [*] NetFramework 1.0.0.412535 Built in Apr 17 2017 17:54:54[*] 00:00:21|[NetFramework] info NetThread.cpp 194 tid:251 [*] NetFramework with open_sslVerison= 1.0.2i Built in Apr 17 2017 17:54:54[*] 00:00:21|[libInfra] info tid:251 [*] Infra 1.0.0.336537 Built in 2017/ 4/17 [*] 00:00:21|[libInfra] trace tid:251 [Src/Infra3/Thread.cpp:923] this:0x1c048d8 tid:251, CThreadManager::CThreadManager()>>>>>>>>> 00:00:21|[libInfra] debug tid:257 ThreadBody Enter name = NetFramework, id = 257, prior = N64, stack = 0x7455ad44 00:00:21|[libInfra] debug tid:258 ThreadBody Enter name = NetFramework, id = 258, prior = N64, stack = 0x73d5ad44 00:00:21|[libInfra] debug tid:259 ThreadBody Enter name = NetFramework, id = 259, prior = N64, stack = 0x7355ad44 00:00:21|[libInfra] debug tid:256 ThreadBody Enter name = NetFramework, id = 256, prior = N64, stack = 0x74d5ad44 00:00:21|[libInfra] debug tid:255 ThreadBody Enter name = NetFramework, id = 255, prior = N64, stack = 0x7555ad44 00:00:21|[libInfra] debug tid:254 ThreadBody Enter name = NetFramework, id = 254, prior = N64, stack = 0x75d5ad44 00:00:21|[libInfra] debug tid:253 ThreadBody Enter name = NetFramework, id = 253, prior = N64, stack = 0x7655ad44 00:00:21|[libInfra] debug tid:252 ThreadBody Enter name = NetFramework, id = 252, prior = N64, stack = 0x76d5ad44 |00:00:21|[StreamApp][InitStreamAppComponentLibrary.cpp:25]|INFO [StreamAppComponent] register all Component |00:00:21|[StreamApp][StreamApp.cpp:18]|INFO [StreamAppComponent] initStreamAppServerComponent |00:00:21|[StreamApp][DHEncryptLiveStreamSource.cpp:17]|INFO [StreamAppComponent] initStreamAppDHEncryptComponent |00:00:21|[StreamApp][RtspRealStream.cpp:35]|INFO [StreamAppComponent] initStreamAppRtspStreamSourceComponent real stream factory, Src/Rtsp/Client/RtspRealStream.h:186, iid=StreamSource |00:00:21|[StreamApp][QuickMulticast.cpp:17]|INFO [StreamAppComponent] initStreamAppQuickMulticastComponent |00:00:21|[StreamApp][TalkbackClient.cpp:12]|INFO [StreamAppComponent] initStreamAppHttpTalkClientComponent |00:00:21|[StreamApp][TsMulticastService.cpp:7]|INFO [StreamAppComponent] initStreamAppTsMulticastServiceComponent |00:00:21|[StreamApp][UdpMulticastService.cpp:7]|INFO [StreamAppComponent] initStreamAppUdpMulticastServiceComponent |00:00:21|[StreamApp][TalkbackSvr.cpp:18]|INFO [StreamAppComponent] initStreamAppHttpTalkbackSvrComponent |00:00:21|[StreamSvr][TransformatBase.cpp:9]|INFO [StreamAppComponent] initStreamSvrParseCreaterComponent |00:00:21|[StreamApp][MikeyAdapter.cpp:21]|INFO [StreamAppComponent] initStreamAppDHEncryptClientComponent 00:00:21|[Unknown] trace F6Adaptor.h 17 tid:251 registerFactory CF6AdaptorFactory /var/Challenge buf) 00:00:21|[] trace tid:251 CApplication::CApplication()>>>>>>>>> 00:00:21|[libInfra] debug tid:260 ThreadBody Enter name = TimerManager, id = 260, prior = N1, stack = 0x72d5ad44
******************************************************************[DRVBOX] initing UART(2) ********* * Lua Engine Version: Lua 5.0.2 * Supported Language: English * SupportedVideoStand: PAL ***[DRVBOX] Kernel I2cDevRes Hit, i2c handle=49324300... ************************************************************************
00:00:22|[] trace tid:251 path1:/mnt/mtd/Config/Config1 path2:/mnt/mtd/Config/Config2 00:00:22|trace CThread name:SaveDelay m_internal:0x1c5a7a8 00:00:22|trace CThread name:SaveLogDelay m_internal:0x1c5abe8 00:00:22|[] trace tid:251 readConfig file1 failed 00:00:22|[] trace tid:251 CConfigManager::initialize() first config file parsing failed. 00:00:22|[] trace tid:251 readConfig file2 failed 00:00:22|[] trace tid:251 CConfigManager::initialize() second config file parsing failed too. 00:00:22|trace CThreadManager::CThreadManager()>>>>>>>>> 00:00:22|[] trace tid:251 CChallenger::CChallenger()>>>>>>>>> 00:00:22|[] trace tid:251 libkeyboard.a::CFrontboardImp::CFrontboardImp()>>>> [LIBPRCCOM] GpioManager Init sucessed. GpioDevProbing(port:0 bit:29 Idx:0 type:0) Alloc New Gpio(port:0 bit:29 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). GpioDevProbing(port:0 bit:30 Idx:0 type:0) Alloc New Gpio(port:0 bit:30 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). [LIBPRCCOM] unknow RtsUseMode SupportWorkMode = 2, WorkMode = 1 [LIBPRCCOM] WARN (UartOpen|324): index = 2, name = /dev/ttyS2 has opened libkeyboard.a::FrontboardCreate :0 libkeyboard.a::CKeyboardDefault::CKeyboardDefault CCommandLedBase::operate 00:00:22|[libInfra] trace tid:251 [Src/Infra3/Timer.cpp:288] this:0x1c41468 tid:251, CTimerManager::CTimerManager()>>>>>>>>>
----------------------------------------------------------- | libdvr.a version: 11527 - Apr 17 2017 18:11:03 | libsysbase version: 11527 - Apr 17 2017 18:11:03 -----------------------------------------------------------
| libres version: 11345 - Apr 17 2017 18:10:49 | libcom version: 11345 - Apr 17 2017 18:10:49 [LIBDVR] system using watchdog to reboot. [LIBDVR] system using watchdog to shutdown. GpioDevProbing(port:0 bit:8 Idx:0 type:0) Alloc New Gpio(port:0 bit:8 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). [LIBDVR] system beep type: GPIO. [LIBDVR] no alarm in dev [LIBDVR] no alarm out dev!! [LIBDVR] noNeed to set alarm valid type in dev [LIBDVR] Create alarm in device success [LIBDVR] Create alarm out device success [LIBDVR] Create alarm out device success [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0xc80000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x180000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x20000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x40000 [LIBPRCCOM] page size: 0x1 [LIBPRCCOM] mtd patition info: [LIBPRCCOM] flash type: [NOR FLASH] [LIBPRCCOM] total size: 0x140000 [LIBPRCCOM] page size: 0x1 00:00:22|[libInfra] debug tid:264 ThreadBody Enter name = EventManager, id = 264, prior = N64, stack = 0x70c58d44 00:00:22|[libInfra] debug tid:263 ThreadBody Enter name = CFrontboardInitTimer, id = 263, prior = N64, sta[DRVBOX] initing UART(3) ck = 0x71458d44 00:00:22|[] trace tid:263 libkeyboard.a::CKeyboardDefault::CKeyboardDefault libkeyboard.a::CKeyboardDefault::addCommand getfbdtype libkeyboard.a::CKeyboardDefault::addCommand keepalive libkeyboard.a::CCommandGetFbdType::operate(1)! no front board key or not support, row = 0, col = 0 [LIBPRCCOM] I2C BusHandle=49324300.[LIBDVR] Cmos dev init success [LIBDVR] RTC_RX8010 rtc initing... [LIBDVR] rtc adjust policy(system adjust RTC) [LIBDVR] RX8010_FLAGREG_OFF is 0x20 [LIBDVR] Rtc dev init success GpioDevProbing(port:0 bit:9 Idx:0 type:0) Alloc New Gpio(port:0 bit:9 Idx:0 type:0) [LIBPRCCOM] embeded/pch/sio gpio driver(implentment in drvbox). SupportWorkMode = 4, WorkMode = 2 [LIBDVR] unknow dev type [LIBDVR] SERIAL_TYPE_UNKNOW | libad version: 11345 - Apr 17 2017 18:10:45 [LIBDVR] WARN (GpsDevInit|244): No GpsDev [LIBDVR] Creating New IR Devs, Total 0 Devices [LIBDVR] DH_BASELINE_2_0 not implement this module [LIBDVR] WARN (SysGetTimezone|254): Time zone not set. [LIBDVR] init: Setting system time from RTC time. [LIBDVR] This dev has no encrypt chip [LIBDVR] dul-backup: DO NOT SUPPORT. ********************************************************* | PRODUCT INFORMATION | libsysbase version: 11527 - Apr 17 2017 18:10:59 | 1.system information | ProductName: HCVR5108H-S2 | ModCapMask: 0 | GpsModType: NO | ForNRT: YES | ForATM: NO | HasAudioBoard: YES | HasLoopBoard: NO | HasMatrixBoard: NO | HasPtzBoard: YES | HasWlanBoard: NO | BeepType: GPIO | SystemRestType: TEMP DON'T KNOW | DspCount: 0 | ProductType: HCVR | ProductSubType: NO RS232 | CpldVersion: 104 | CpuChipType: GM8210 | IsInland: ABROAD | SupportEsata: NO | SupportPm: YES | AppVersion: 0 | SdcardToDisk: NO | NetType: Normal | SwitchPoeNumber: 0 | DspChip: NONE | VideoChip: DH9910_1080P | AudioMode: STxx control | FbdSize: Base | NetCard: Single | FbdDigit: NO | FbdShift: NO | AudioInterface: Mul_audio | SupportHdmi: YES | VideoTour: YES | DiskInterface: NO | SupportLcd: NO | HdVersion: 0 | ProductVersion: A | DevSubType: 0 | PoePortNum: 0 | ProductTypeV2: 0 | ProductSubTypeV2: 0 | CpuChipIdV2: 0 | VideoInputNumV2: 8 | VideoOutputNumV2: 0 | AudioInputNumV2: 0 | AudioOutputNumV2: 0 |VideoStreamInputNumV2: 0 |AudioStreamInputNumV2: 0 | VideoChnEncodeNumV2: 0 | AudioChnEncodeNumV2: 0 | VideoChnDecodeNumV2: 0 | AudioChnDecodeNumV2: 0 | 2.Env information | Env startaddr: 0x50000 | Env size: 0x8000 | 3.Alarm information | Alarm in: 0 | Alarm out: 0 | 4.Frontboard information | Frontboard count: 2 | 5.Flash information | Flash chip count: 1 | chip 0 size: 0x1000000 | chip 0 baseaddr: 0xa0000000 | 6.Cmos,Rtc information | Cmos,Rtc chip: RX8010SJ | Cmos,Rtc chip addr: 0x64 | Cmos offset: 0x20 | 7.others information | VideoChannel: 8 | AudioChannel: 1 | DigitalChannel: 0 | DiskNumber: 1 | CDRomSupportNum: 1 | PlayBackNum: 0 | SupportRs232: NO | SupportRs485: YES ********************************************************* CVersionInfo::CVersionInfo()>>>>>>>>> 00:00:22|[] trace tid:251 Application Version Info:3.200.0004.11 BuildDate 2017-04-17 18:27:12 01:14:45|[] trace tid:263 libkeyboard.a::InitFrontboardParam FrontboardRead.............. 01:14:45|[] trace tid:251 ******************************************************************* * Challenge svn version: 442473 - Apr 17 2017 18:27:15 ******************************************************************* 01:14:45|[] trace tid:251 >>>>>>>>>>>>>has audio 1 , MatrixBoard has 0 loop 01:14:45|[] trace tid:251 --------g_CapsEx.ForATM = 0---------- 01:14:45|[] trace tid:251 CLocales::loadFont()>>>>>>>>> 01:14:45|[] trace tid:251 CFontManager::config ret = 1 01:14:45|[] trace tid:251 libguikit: Font::load file /usr/data/Data/Font.bin Successed! 01:14:45|[] trace tid:251 libguikit: Font::load file /usr/data/Data/FontSmallEn.bin Successed! 01:14:45|[] trace tid:251 IPacketManager::instance()->pages:81920 01:14:45|[] info tid:251 CPacketManager: malloc total(83886080) pagesize(1024)blockCount (81920) ManagermentSize(1638740) 01:14:45|[] info tid:251 AddrRange(0x6ac59400-0x6fc59400) 01:14:47|[libInfra] trace tid:251 CThreadManager::CThreadManager()>>>>>>>>> 01:14:47|[Unknown] trace DeviceManager.cpp 73 tid:251 CDeviceManager::Start()>>>>>>>>> 01:14:47|trace CThread name:DevComm m_internal:0x1c29350 01:14:47|trace CThread name:Backup m_internal:0x1c29c38 01:14:47|trace CThread name:DevPtz m_internal:0x1c29de8 [LIBPRCCOM] WARN (UartOpen|324): index = 3, name = /dev/ttyS3 has opened ../src/Video.c ERROR (func = Gmcap_GetCapMode line =>48): Open vcap.cfg Failed! ../src/Config.c INFO (func = Init_HardWare_Info line =>269): iProductType = 18 ../src/Config.c INFO (func = Init_HardWare_Info line =>270): iLogicAudioChlNum = 1 ../src/Config.c INFO (func = Init_HardWare_Info line =>271): iNrPhysChnNum = 8 ../src/Config.c INFO (func = Init_HardWare_Info line =>272): iDigtalChlNum = 0 ../src/Config.c INFO (func = Init_HardWare_Info line =>273): iLogicVideoChlNum = 16 ../src/Config.c INFO (func = Init_HardWare_Info line =>274): iVideoChipType=19 ../src/Config.c INFO (func = Init_HardWare_Info line =>275): iAudioMicMux=1 ../src/Config.c INFO (func = Init_HardWare_Info line =>276): iCpuChip=18 ../src/Config.c INFO (func = Init_HardWare_Info line =>277): iEncodeType=0xff ../src/Config.c INFO (func = Init_HardWare_Info line =>278): iCapOsdMode=0 ../src/Config.c INFO (func = Init_HardWare_Info line =>279): iDevInland = 0 ../src/Config.c INFO (func = Init_HardWare_Info line =>280): iVideoChipNum=2 ../src/Config.c INFO (func = Init_HardWare_Info line =>281): iSank=0 ../src/Config.c INFO (func = Init_HardWare_Info line =>282): iCustomizeType=0 ../src/Config.c INFO (func = Init_HardWare_Info line =>283): iHwid=40000aa ../src/Config.c INFO (func = Init_HardWare_Info line =>284): iMjpegSupport=0 ../src/Config.c INFO (func = Init_HardWare_Info line =>285): iVcapMode=0 **************************************************************************************** libcap.a: Version: V0.02.184 Svn: 8310 APIs(Svn:40608) Compile at Apr 17 2017 18:17:21 ****************************************************************************************
****************************************************************************** GMXX: libaudio.a Version: V1.01.63 Svn: 12780 Compile at Apr 17 2017 18:17:24 ****************************************************************************** [libaudio.a] INFO (AudioDeviceInit|486): CPLD_AUDIO_INTERFACE=1 cpuType=18 [libaudio.a] INFO (AudioBufInfoInit|1031): AUDIO_PLAY_TYPE p_addr=0x1c7a740 [libaudio.a] INFO (AudioBufInfoInit|1039): AUDIO_MONITOR_TYPE p_addr=0x1c7a740 [libaudio.a] INFO (AudioBufInfoInit|1047): AUDIO_TALK_TYPE p_addr=0x1c7e740 [libaudio.a] INFO (AudioBufInfoInit|1049): AudioBufInfoInit done *************************************************************************** libgm.a: Version: 0x31 Svn: 28756 Compile at Apr 17 2017 18:19:00 *************************************************************************** ZEBRA(zebra_read_timeout_handler): - @@@ BAD! dev0 of board: FA626, the application doesn't read data over 30s! *************** board name: FA626, READ LIST **************** read sharemem sharemem xmit xmit on id name list rx_rdy tx_empty rx_rdy tx_empty hand read_in read_out write_in write_out -- ------------- ----- -------- -------- ------ -------- ---- -------- -------- -------- --------- 0 m01 0 0 0 0 0 0 0 ffff90a2 0 0 1 getcp_m01 0 0 0 0 0 0 0 0 0 0 2 qbs_m01 0 0 0 0 0 0 0 0 0 0 3 pk_m01 0 0 0 0 0 0 0 0 0 0 4 hdmi 0 0 0 0 0 0 0 0 0 0 6 lcd0_drv 0 1 1 1 1 0 ffff9080 ffff905d 0 0 7 lcd2_drv 0 1 1 1 1 0 ffff9092 ffff9085 0 0
*************** board name: FA626, WRITE LIST **************** write xmit sharemem sharemem xmit xmit id name list list rx_rdy tx_empty rx_rdy tx_empty timer read_in read_out write_in write_out -- ------------- ----- ----- -------- -------- ------ -------- ----- -------- -------- -------- --------- 0 m01 0 0 0 0 0 0 no 0 ffff90a2 0 0 1 getcp_m01 0 0 0 0 0 0 no 0 0 0 0 2 qbs_m01 0 0 0 0 0 0 no 0 0 0 0 3 pk_m01 0 0 0 0 0 0 no 0 0 0 0 4 hdmi 0 0 0 0 0 0 no 0 0 0 0 6 lcd0_drv 0 0 0 0 0 0 no ffff9080 ffff905d 0 0 7 lcd2_drv 0 0 0 0 0 0 no ffff9092 ffff9085 0 0 ioctl "pif_env_update" fail: Operation not permitted [err] gm_init: Platform is not ready!, please check inser module driver flow. [libaudio.a] INFO (CreateAudioGmxxSystem|990): pGroupAoFd[0]=0x1 [libaudio.a] INFO (CreateAudioGmxxSystem|990): pGroupAoFd[1]=0x1 [libaudio.a] INFO (CreateAudioGmxxSystem|990): pGroupAoFd[2]=0x1 [libaudio.a] INFO (CreateAudioGmxxSystem|990): pGroupAoFd[3]=0x1 [251][err]pif_check_audio_file_attr_value:3515 gm_set_attr (null) sample_rate(8000) not support. vch(3,) [err] gm_bind (0x1, 0x1c82a10, 0x1c829d0): Invalid attribute pointer. [err] gm_apply groupfd(0x1): Group is empty, It can't use gm_apply without gm_bind [libaudio.a] ERROR (FileBindAo|487): File bind Ao gm_apply error!!! ret=-2097151998 [libaudio.a] INFO (AudioInit|1072): >>>>AudioInit successful<<<<<<<< [libaudio.a] INFO (AudioDeviceInit|526): NeedPriority=1 SpeakOutPort=0 SelfSpeakIn=0 boardtype=0 numId=0 [libaudio.a] INFO (AudioDeviceInit|528): audioTotalChnNum=1 chip=0 productType=18 cpuType=18 videochip=19
************************************************************************************ * libdec.a version: 1.0.1 svn: 22170 Compile at: 18:17:30 Apr 17 2017 * *************************************************************i2c i2c-0: NAK! *********************** libvos INFO (func = GM_init line =>4638): init is done,just need once![libaudio.a] INFO (AudioPutDataThread|768): AudioPutDataThread crate 01:15:17|[Unknown] trace DeviceManager.cpp 142 tid:251 --------------------CDeviceManager::Start()----------------------- 01:15:17|[Unknown] trace DeviceManager.cpp 143 tid:251 g_nCaptZEBRA(zebra_read_timeout_handler): - @@@ BAD! dev0 of board: FA626, the application doesn't read data over 30s! ure ------------*************** board name: FA626, READ LIST **************** ----8 ead sharemem sharemem xmit xmit on 40m01:15:17|[Unkid name list rx_rdy tx_empty rx_rdy tx_empty hand read_in read_out write_in write_out nown] trace Devi-- ------------- ----- -------- -------- ------ -------- ---- -------- -------- -------- --------- ceManager.cpp 140 m01 0 0 0 0 0 0 0 ffff90a2 0 0 4 tid:251 g_nD1 getcp_m01 0 0 0 0 0 0 0 0 0 0 ecoders---------2 qbs_m01 0 0 0 0 0 0 0 0 0 0 -------0 k_m01 0 0 0 0 0 0 0 0 0 0 37;40m01:15:17|[4 hdmi 0 0 0 0 0 0 0 0 0 0 Unknown] trace D6 lcd0_drv 0 1 1 1 1 0 ffff9080 ffff905d 0 0 eviceManager.cpp7 lcd2_drv 0 1 1 1 1 0 ffff9092 ffff9085 0 0 145 tid:251 g *************** board name: FA626, WRITE LIST **************** _nPlay ------ write xmit sharemem sharemem xmit xmit ----------9 d name list list rx_rdy tx_empty rx_rdy tx_empty timer read_in read_out write_in write_out m01:15:1-- ------------- ----- ----- -------- -------- ------ -------- ----- -------- -------- -------- --------- 7|[Unknown] trac0 m01 0 0 0 0 0 0 no 0 ffff90a2 0 0 e DeviceManager.1 getcp_m01 0 0 0 0 0 0 no 0 0 0 0 cpp 146 tid:251 2 qbs_m01 0 0 0 0 0 0 no 0 0 0 0 g_nAlarmIn ---3 pk_m01 0 0 0 0 0 0 no 0 0 0 0 -------------0 4 hdmi 0 0 0 0 0 0 no 0 0 0 0 01:16 lcd0_drv 0 0 0 0 0 0 no ffff9080 ffff905d 0 0 5:17|[Unknown] t7 lcd2_drv 0 0 0 0 0 0 no ffff9092 ffff9085 0 0 race DeviceManager.cpp 147 tid:251 g_nAlarmOut----------------0 01:15:17|[Unknown] trace DeviceManager.cpp 148 tid:251 g_nAudioIn ----------------1 01:15:17|[Unknown] trace DeviceManager.cpp 149 tid:251 g_nVideoOut ----------------1 01:15:17|[Unknown] trace DeviceManager.cpp 150 tid:251 g_nNetCard -----------------1 01:15:17|[Unknown] trace DeviceManager.cpp 152 tid:251 DeviceNum-----------------4 01:15:17|[Unknown] trace DeviceManager.cpp 154 tid:251 ------------------------------------------------------------------ ^A01:15:20|[] trace tid:251 libkeyboard.a::warn: CFrontboardImp::getFrontboardParam m_IsInit over time! libkeyboard.a::CFBD::CFBD m_Ffrmmap_open: AP0 open file: 0x8c6281c0 BDType:0 libkeyFrammap: AP0, off:e004000, p:0xe004000, v:0x660b0000, size:0x1000, pfn:57348, alloc_type:cachable board.a::CFBD::Cfrmmap_open: AP0 open file: 0x8b074f60 FBD m_OEMType:-1Frammap: AP0, off:e005000, p:0xe005000, v:0x660af000, size:0x1000, pfn:57349, alloc_type:cachable
libkeyboard.a:frmmap_open: AP0 open file: 0x8e79a9a0 :VFD unknown typFrammap: AP0, off:e006000, p:0xe006000, v:0x660ae000, size:0x1000, pfn:57350, alloc_type:cachable frmmap_open: AP0 open file: 0x8c628740
libkeyboard.a::Frammap: AP0, off:e007000, p:0xe007000, v:0x660ad000, size:0x1000, pfn:57351, alloc_type:cachable VFD unknown typefrmmap_open: AP0 open file: 0x8e79aaa0 !!!!!:remote liFrammap: AP0, off:e008000, p:0xe008000, v:0x660ac000, size:0x1000, pfn:57352, alloc_type:cachable bkeyboard.a::FBDfrmmap_open: AP0 open file: 0x8e79aa20 unknown type!!!Frammap: AP0, off:e009000, p:0xe009000, v:0x660ab000, size:0x1000, pfn:57353, alloc_type:cachable !!hddsunell libfrmmap_open: AP0 open file: 0x8e79a920 keyboard.a::VFD Frammap: AP0, off:e00a000, p:0xe00a000, v:0x660aa000, size:0x1000, pfn:57354, alloc_type:cachable unknown type!!!!frmmap_open: AP0 open file: 0x8c6289c0 !:hddsunell libFrammap: AP0, off:e00b000, p:0xe00b000, v:0x660a9000, size:0x1000, pfn:57355, alloc_type:cachable keyboard.a::FBD frmmap_open: AP0 open file: 0x8e79a0a0 unknown type!!!!Frammap: AP0, off:e00c000, p:0xe00c000, v:0x660a8000, size:0x1000, pfn:57356, alloc_type:cachable !netsunell libkfrmmap_open: AP0 open file: 0x8c6285c0 eyboard.a::VFD uFrammap: AP0, off:e00d000, p:0xe00d000, v:0x660a7000, size:0x1000, pfn:57357, alloc_type:cachable nknown type!!!!!frmmap_open: AP0 open file: 0x8e79a8a0 :netsunell libkFrammap: AP0, off:e00e000, p:0xe00e000, v:0x660a6000, size:0x1000, pfn:57358, alloc_type:cachable eyboard.a::VFD ufrmmap_open: AP0 open file: 0x8e79a520 nknown type!!!!!Frammap: AP0, off:e00f000, p:0xe00f000, v:0x660a5000, size:0x1000, pfn:57359, alloc_type:cachable :alarmh libkeybfrmmap_open: AP0 open file: 0x8b074de0 oard.a::VFD unknFrammap: AP0, off:e010000, p:0xe010000, v:0x660a4000, size:0x1000, pfn:57360, alloc_type:cachable own type!!!!!:alfrmmap_open: AP0 open file: 0x8b074d60 arml libkeyboarFrammap: AP0, off:e011000, p:0xe011000, v:0x660a3000, size:0x1000, pfn:57361, alloc_type:cachable d.a::VFD unknownfrmmap_open: AP0 open file: 0x8b074ce0 type!!!!!:statuFrammap: AP0, off:e012000, p:0xe012000, v:0x660a2000, size:0x1000, pfn:57362, alloc_type:cachable s libkeyboard.afrmmap_open: AP0 open file: 0x8b074160 ::VFD unknown tyFrammap: AP0, off:e013000, p:0xe013000, v:0x660a1000, size:0x1000, pfn:57363, alloc_type:cachable pe!!!!!:statussefrmmap_open: AP0 open file: 0x8b074260 cond libkeyboarFrammap: AP0, off:e014000, p:0xe014000, v:0x660a0000, size:0x1000, pfn:57364, alloc_type:cachable d.a::VFD unknownfrmmap_open: AP0 open file: 0x8b0740e0 type!!!!!:ptz Frammap: AP0, off:e015000, p:0xe015000, v:0x6609f000, size:0x1000, pfn:57365, alloc_type:cachable libkeyboard.a::Vfrmmap_open: AP0 open file: 0x8b074360 FD unknown type!Frammap: AP0, off:e016000, p:0xe016000, v:0x6609e000, size:0x1000, pfn:57366, alloc_type:cachable !!!!:diskrecstatfrmmap_open: AP0 open file: 0x8c6288c0 us libkeyboard.Frammap: AP0, off:e017000, p:0xe017000, v:0x6609d000, size:0x1000, pfn:57367, alloc_type:cachable a::VFD unknown tfrmmap_open: AP0 open file: 0x8e79a2a0 Frammap: AP0, off:e018000, p:0xe018000, v:0x6609c000, size:0x1000, pfn:57368, alloc_type:cachable
libkeyboard.a::frmmap_open: AP0 open file: 0x8c628840 VFD unknown typeFrammap: AP0, off:e019000, p:0xe019000, v:0x6609b000, size:0x1000, pfn:57369, alloc_type:cachable frmmap_open: AP0 open file: 0x8c6284c0
libkeyboard.a::Frammap: AP0, off:e01a000, p:0xe01a000, v:0x6609a000, size:0x1000, pfn:57370, alloc_type:cachable VFD unknown typefrmmap_open: AP0 open file: 0x8b074460 !!!!!:shutrebootFrammap: AP0, off:e01b000, p:0xe01b000, v:0x66099000, size:0x1000, pfn:57371, alloc_type:cachable
libkeyboard.a:frmmap_open: AP0 open file: 0x8b0744e0 :FBD unknown typFrammap: AP0, off:e01c000, p:0xe01c000, v:0x65e9e000, size:0x1fb000, pfn:57372, alloc_type:cachable e!!!!!showtime libkeyboard.a::FBD unknown type!!!!!comm libkeyboard.a::FBD unknown type!!!!!play libkeyboard.a::FBD unknown type!!!!!playpause libkeyboard.a::FBD unknown type!!!!!playfast libkeyboard.a::FBD unknown type!!!!!playslow libkeyboard.a::FBD unknown type!!frmmap_open: AP0 open file: 0x8b074560 !!!playback libkeyboard.a::FBD unknown type!!!!!screenctrl 01:Frammap: 5097 pages in DDR0 are freed. 15:20|trace CThrfrmmap_release is called for AP0 ead name:DevFrontboard m_internal:0x1d17480 01:15:20|trace CThread name:DevPlay m_internal:0x1d17738 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][0]=7 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][1]=6 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][2]=3 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][3]=2 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][4]=5 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][5]=4 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][6]=1 ../src/Config.c INFO (func = Init_ChannelMap line =>569): Map[AUDIO_SOURCE_HDCVI][7]=0 ../src/Config.c INFO (func = Init_ChannelMap line =>575): Map[AUDIO_SOURCE_NORMAL][0]=7 ../src/Video.c ERROR (func = Gmcap_GetCapMode line =>48): Open vcap.cfg Failed! mem_info.aval_bytes:0x15fc000 #########mmap size:0x108 bytes success########### mem_info.aval_bytes:0x15fb000 #########mmap size:0x108 bytes success########### mem_info.aval_bytes:0x15fa000 #########mmap size:0x108 bytes success########### mem_info.aval_bytes:0x15f9000 #########mmap size:0x108 bytes success########### mem_info.aval_bytes:0x15f8000 #########mmap size:0x108 bytes success########### mem_info.aval_bytes:0x15f7000 #########mmap size:0x108 bytes success########### mem_info.aval_bytes:0x15f6000 #########mmap size:0x108i2c i2c-0: NAK! bytes success########### mem_info.aval_bytes:0x15f5000 #########mmap size:0x108 bytes success########### mem_info.aval_bytes:0x15f4000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15f3000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15f2000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15f1000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15f0000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15ef000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15ee000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15ed000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15ec000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15eb000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15ea000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15e9000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15e8000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15e7000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15e6000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15e5000 #########mmap size:0x1000 bytes success########### mem_info.aval_bytes:0x15e4000 #########mmap size:0x1fa400 bytes success########### ## free avalbytes:0x13e9000 libvos INFO (func = GM_init line =>4638): init is done,just need once!../src/cpu_comm_api.c INFO (func = CpuCommInit line =>75): my is FA7! ^A^AZEBRA(zebra_read_timeout_handler): - @@@ BAD! dev0 of board: FA626, the application doesn't read data over 30s! *************** board name: FA626, READ LIST **************** read sharemem sharemem xmit xmit on id name list rx_rdy tx_empty rx_rdy tx_empty hand read_in read_out write_in write_out -- ------------- ----- -------- -------- ------ -------- ---- -------- -------- -------- --------- 0 m01 0 0 0 0 0 0 0 ffff90a2 0 0 1 getcp_m01 0 0 0 0 0 0 0 0 0 0 2 qbs_m01 0 0 0 0 0 0 0 0 0 0 3 pk_m01 0 0 0 0 0 0 0 0 0 0 4 hdmi 0 0 0 0 0 0 0 0 0 0 6 lcd0_drv 0 1 1 1 1 0 ffff9080 ffff905d 0 0 7 lcd2_drv 0 1 1 1 1 0 ffff9092 ffff9085 0 0 12 user_ap0 0 0 0 0 0 0 0 ffffa1ad ffffa1ad ffffa1ad
*************** board name: FA626, WRITE LIST **************** write xmit sharemem sharemem xmit xmit id name list list rx_rdy tx_empty rx_rdy tx_empty timer read_in read_out write_in write_out -- ------------- ----- ----- -------- -------- ------ -------- ----- -------- -------- -------- --------- 0 m01 0 0 0 0 0 0 no 0 ffff90a2 0 0 1 getcp_m01 0 0 0 0 0 0 no 0 0 0 0 2 qbs_m01 0 0 0 0 0 0 no 0 0 0 0 3 pk_m01 0 0 0 0 0 0 no 0 0 0 0 4 hdmi 0 0 0 0 0 0 no 0 0 0 0 6 lcd0_drv 0 0 0 0 0 0 no ffff9080 ffff905d 0 0 7 lcd2_drv 0 0 0 0 0 0 no ffff9092 ffff9085 0 0 12 user_ap0 1 1 3 2 3 2 no 0 ffffa1ad ffffa1ad ffffa1ad [LIBDVR] rtc sync system-time to rtc-time done. ---------- Добавлено спустя 1 час 9 минут 57 секунд: ---------- Команда printenv выдаёт следующий лог. DEVID=000000000000000000 HWID=00000000000000 ID=000000000000000000 appauto=1 autogw=192.168.1.1 autolip=192.168.1.108 autonm=255.255.255.0 autosip=192.168.254.254 baudrate=115200 bootargs=mem=240M@0x01000000 gmmem=30M console=ttyS0,115200 user_debug=31 root=/dev/mtdblock1 bootcmd=run dh_cmd;fsload /slave/fc7500.bin 0x00000000;fsload /boot/uImage 0x18100000;fsload /slave/rootfs_slave 0x3F600000;fsload /boot/uImage 0x02000000;run cmd_set1;bootm 0x02000000 bootdelay=3 cmd_set1=mw 0x18096000 0x10008000; cmds=initrd=0x3f600000,0x300000 ramdisk_size=10240 root=/dev/ram rw init=/init mem=256M@0x10000000 gmmem=190M console=ttyS0,115200 mem=512M@0x20000000 da=tftp 0x3000000 u-boot.bin.img; flwrite dc=tftp 0x3000000 custom-x.cramfs.img; flwrite deviceid=000000000000000000 dh_cmd=usbupdate;autoup;showlogo;fb_needreset;ipclose dh_keyboard=0 dl=tftp 0x3000000 logo-x.cramfs.img; flwrite dr=tftp 0x3000000 romfs-x.cramfs.img; flwrite ds=tftp 0x3000000 slave-x.cramfs.img; flwrite du=tftp 0x3000000 user-x.cramfs.img; flwrite dw=tftp 0x3000000 web-x.cramfs.img; flwrite eracfg_flag=0 eth1addr=20:13:12:26:12:23 ethact=eth1 ethaddr=20:13:12:26:12:23 ethprime=eth1 gatewayip=192.168.1.1 ipaddr=192.168.1.108 key=000000000000000000 load_modules=1 logserver=127.0.0.1 matchinit_mode=16852 netmask=255.255.255.0 netretry=no restore=0 selfchecked=1 serverip=192.168.254.254 stderr=serial stdin=serial stdout=serial tftptimeout=1000 tk=tftp 0x3000000 uImage; bootm up=tftp 0x3000000 update.img; flwrite updatetimeout=0
