Dahua IPC-HDW1220S виснет через 10-30 минут https://vlab.su/viewtopic.php?f=270&t=99121 |
vova_w810i [ 31 янв 2020, 21:03 ] | |
Заголовок сообщения: | Dahua IPC-HDW1220S виснет через 10-30 минут |
Dahua IPC-HDW1220S (1.1.01.04.12195) - виснет через 10-30 минут Дамп прошивки выложил ранее здесь: viewtopic.php?f=270&t=98892 Вот лог загрузки:
System startup
U-Boot 2010.06-svn4554 (Jun 19 2017 - 21:29:06) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 In: serial Out: serial Err: serial TEXT_BASE:81000000 MMC: Hisilicon ETH net controler MAC: E0-50-8B-FA-D3-76 Up/Down PHY not link. Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: E0-50-8B-FA-D3-76 Up/Down PHY not link. Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: E0-50-8B-FA-D3-76 Up/Down PHY not link. ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1177544 Bytes = 1.1 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK partition file version 2 rootfstype squashfs root /dev/mtdblock6 cmdLine mem=128M console=ttyS0,115200 root=/dev/mtdblock6 rootfstype=squashfs crashflasg:1, logmagic:54410011. Starting kernel ... Uncompressing Linux... done, booting the kernel. |
vova_w810i [ 01 фев 2020, 13:05 ] | |
Заголовок сообщения: | Re: Dahua IPC-HDW1220S виснет через 10-30 минут |
Вот полный лог, после команд: setenv dh_keyboard 0 saveenv reset
System startup
System startup U-Boot 2010.06-svn4554 (Jun 19 2017 - 21:29:06) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 In: serial Out: serial Err: serial TEXT_BASE:81000000 MMC: Hisilicon ETH net controler MAC: E0-50-8B-FA-D3-76 Up/Down PHY not link. Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: E0-50-8B-FA-D3-76 Up/Down PHY not link. Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: E0-50-8B-FA-D3-76 Up/Down PHY not link. ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1177544 Bytes = 1.1 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK partition file version 2 rootfstype squashfs root /dev/mtdblock6 cmdLine mem=128M console=ttyS0,115200 root=/dev/mtdblock6 rootfstype=squashfs crashflasg:1, logmagic:54410011. Starting kernel ... Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518ev200 gLogRamRes: start=0x87fb7000;size=0x47000 mem_relimitAddr:0x87ffe000 console [ttyS0] enabled яmount: mounting tmpfs on /tmp failed: No such file or directory mknod: /dev/console: File exists mknod: /dev/ttyS0: File exists mknod: /dev/ttyS1: File exists mknod: /dev/null: File exists chmod: /dev/fd: Operation not permitted chmod: /dev/fd: Operation not permitted keyboard = 0 mount: mounting devpts on /dev/pts failed: Device or resource busy Hisilicon Media Memory Zone Manager address is 0x8c000000 ,length is 33554432 address is 0x8e000000 ,length is 16777216 address is 0x8f000000 ,length is 16777216 Module himedia: init ok hi3518e_base: module license 'Proprietary' taints kernel. load sys.ko for Hi3518EV200...OK! load tde.ko ...OK! load region.ko ....OK! load vgs.ko for Hi3518EV200...OK! updatePos = 0 chip_id = 1E ISP Mod init! load viu.ko for Hi3518EV200...OK! load vpss.ko ....OK! load rc.ko for Hi3518EV200...OK! load venc.ko for Hi3518EV200...OK! load chnl.ko for Hi3518EV200...OK! load h264e.ko for Hi3518EV200...OK! load jpege.ko for Hi3518EV200...OK! insmod: can't open 'hi3518e_vda.ko': No such file or directory [OSA-DRV] OSA Build on Jun 19 2017 at 21:24:30. [OSA-DRV] SVN NUM: 5514. [OSA-DRV] Monitor Task pid=754 tid=754 [LOG-DRV] LOG Build on Jun 19 2017 at 21:23:24. [LOG-DRV] SVN NUM: 9984. [LOG-DRV] ramStart:0x87fb7000;ramSize:0x47000;select:1 [OSA-DRV] Char device create OK ! [LOG-DRV] coreId = 0, logLevel = 2 [LOG-DRV] coreId = 1, logLevel = 2 [LOG-DRV] coreId = 2, logLevel = 2 [LOG-DRV] coreId = 3, logLevel = 2 [LOG-DRV] coreId = 4, logLevel = 2 [LOG-DRV] coreId = 5, logLevel = 2 n 19 2017 at 21:32:59. |[pdc] SenCfgSize: 220 Bytes 00:00:05|[pdc] PDC_MODULE_SENSOR en = 2000 ate OK ! cmdstr:himm 0x200f0044: 0x00000001 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0080: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0088: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f008c: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0090: 0x00000000 --> 0x00000002 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0094: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x2003002c: 0x000C4003 --> 0x000B4001 [END] audioin = 0 hasIVS = 1 load ive.ko for Hi3518EV200...OK! CATEGORY = 2 IPC Device Get flash total size failed. uild on Jun 19 2017 at 21:30:54. ls]:SVN NUM: 21111. _disableRoute = 0 2017 at 21:30:54. product_name =IPC-HFW2220M Fail to get env coremnt! fvideo_chip = 79 cap_sd 0 wifi = 0 product = IPC-HFW2220M product = IPC-HFW2220M aewcfg = IPC-HFW2220M appauto=1 x87ffe000, memLen= 0x2000 -Lib] libbinder.so Build on Jun 19 2017 at 21:20:40. ated successful! 1:22|[libpdi] pAdcObj->bDex = 0.000000 32m16:01:23|[libvsf] numStream: 2 ;32m16:01:23|[pdc] Get motor cfg failed ! er to sensor 79 r vencgroup[0],vencchn[0] algPktInit call back t |16:01:25|[StreamApp@445535][DHEncryptLiveStreamSource.cpp:17]|INFO [StreamAppComponent] initStreamAppDHEncryptComponent $$$$$$$$$$$MEM_SIZE:256$$$$$$$$$$$$$ total bytes allocated = 4980736 total bytes in use bytes = 4970168 total non-mmapped bytes allocated = 782336 number of mmapped regions = 1 total allocated mmap space = 4198400 total allocated sbrk space = 771768 maximum total allocated space = 4980736 total free space = 10568 memory releasable via malloc_trim = 8328 setFilter: tagDncMode:1, irCutStatus:2, filterDelayFrames:0, setFilter: tagDncMode:1, irCutStatus:2, filterDelayFrames:0, _DRV] setDayNightColor Called. dncMode:1 |[libpdi] ERROR (PDI_irisAdjustSize|117): Para: hIris is NULL! 0, f32Fps=====25.0000 00 5.0000 [0;32;32m16:01:27|[AEW] defFps====25.0000, f32Fps=====25.0000 [AEW] defFps====25.0000, f32Fps=====25.0000 32m16:01:28|[libpdi] processorType: 30 Manager] [ver:] warn tid:926 init:84 use default cmos def path! 756ec4 info tid:926 CMagicBox::m_systemInfo.noSdCard == [1] defFps====25.0000, f32Fps=====25.0000 s====25.0000, f32Fps=====25.0000 Class DeviceSubClass empty ! ;32m16:01:29|[AEW] defFps====25.0000, f32Fps=====25.0000 0 16:01:29 pdi] English 01:29|[AEW] defFps====25.0000, f32Fps=====25.0000 Fps====25.0000, f32Fps=====25.0000 Main.cpp main 993 tid:926 >>>>>>>>>>>>>>>>>GDI_begin:42949401670 ] [ver:] trace tid:926 AlarmServer setDefault 926 [*] StreamApp 3.8.2.445535 Built in 2017/ 6/19 [*] bService" }, { "Enable" : true, "InnerPort" : 37777, "OuterPort" : 37777, "Protocol" : "TCP", "ServiceName" : "TCP", "ServiceType" : "PrivService" }, { "Enable" : true, "InnerPort" : 37778, "OuterPort" : 37778, "Protocol" : "UDP", "ServiceName" : "UDP", "ServiceType" : "PrivService" }, { "Enable" : true, "InnerPort" : 554, "OuterPort" : 554, "Protocol" : "TCP", "ServiceName" : "RTSP", "ServiceType" : "RTSPService" } ], "Mode" : "Manual", "StartDeviceDiscover" : true } [Src/UPnP/UpnpGeneralPortmap.cpp:77] "http:\/\/\/", "PresentationUrl" : "http:\/\/192.168.0.75:80", "SerialNumber" : "e0:50:8b:fa:d3:76", "Udn" : "uuid:www.dahuatech.com.device_3_0-3H00BD5PAA00036", "Upc" : "" } } } [Src/NetAppMgr.cpp:20] 25.0000, f32Fps=====25.0000 6] [ver:] warn tid:926 tid:926, Leave setNetMode. [Src/NetworkManager/NetworkManager.cpp:779] :32|[libpdi] fe80::e250:8bff:fefa:d376/64 00, f32Fps=====25.0000 6:01:32|[NetApp-445666] [ver:] debug tid:938 tid:938, eth0 isn't online now! Insert to map [Src/NetworkManager/RouteManager.cpp:598] /NetworkManager/NetworkManager.cpp:2227] m1:33|[AEW] defFps====25.0000, f32Fps=====25.0000 ] [ver:] warn tid:926 tid:926, wpa_supplicant not run becaues 802.1x is disable! [Src/802_1x/802_1x.cpp:84] 40m16:01:33|[NetApp-445666] [ver:] debug tid:926 tid:926, config params is { "MaxCacheNum" : 5, "MergeDelay" : 0, "StopDelay" : 0 } [Src/smtpNew/EventHandle.cpp:224] 26 tid:926, CProviderManager::start() with config[MobilePushNotification]>>>>>>>>>>> [Src/PushNotification/ProviderManager.cpp:51] [libStorage] [ver:] trace tid:926 ---->>CStorage::CStorage() 0, "Memo" : "For FTP Files", "Name" : "FTP", "OverWrite" : true, "PicturePathRule" : "%y-%M-%d\/%c\/jpg\/%h\/%m\/%s[%E][%O@%S][%R].jpg", "RecordPathRule" : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav" } ] [Unknown] [ver:Unknown] info AttrLinkMgr.cpp loadRules 126 tid:926 CAttrLinkMgr::loadRules /usr/data/AttributeRule/LinkRule, rule count = 99 tions linkRule 54 tid:926 CAttrLink::linkRule of VideoInOptions an exist name:[*] ons warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInDayNight oInOptions Link::linkTo an exist name:VideoInOptions o an exist name:VideoInDenoise Unknown] [ver:Unknown] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInDenoise nk::linkRule of VideoInOptions an exist name:[*].Backlight ideoInExposure trLink::linkTo an exist name:VideoInOptions n] [ver:Unknown] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInOptions exist name:VideoInExposure 16:01:34|[Unknown] [ver:Unknown] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInExposure :VideoInExposure Unknown] [ver:Unknown] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInOptions e wn] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInOptions 6:01:34|[Unknown] [ver:Unknown] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInExposure 666] [ver:] error tid:938 tid:938, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:721] ink::linkTo an exist name:VideoInExposure arn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInExposure o 32 tid:926 CAttrLink::linkTo an exist name:VideoInExposure .cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInExposure 6 CAttrLink::linkTo an exist name:VideoInExposure nknown] [ver:Unknown] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInExposure kTo an exist name:VideoInOptions ver:Unknown] warn AttrLink.cpp linkTo 32 tid:926 CAttrLink::linkTo an exist name:VideoInIRExposure 32 tid:926 CAttrLink::linkTo an exist name:VideoInOptions an exist name:VideoInOptions To 32 tid:926 CAttrLink::linkTo an exist name:VideoInWhiteBalance o an exist name:VideoInOptions 6 CAttrLink::linkTo an exist name:VideoInWhiteBalance fFps====25.0000, f32Fps=====25.0000 0;36m16:01:35|[libpdi] device videoInCaps: ps.coverCount[3] m_caps.coverType[1] m_caps.titleCount[2] m_caps.iris[1] m_caps.irisAuto[0] m_caps.infraRed[0] m_caps.setcolor[1] m_caps.formatCout[1] m_caps.rotate90[1] m_caps.signalForamtMask[0] m_caps.syncChipChannels[0] m_caps.chipID[0] m_caps.multiOptions[0] m_caps.snapshotExposure[0] m_caps.limitedAutoExposure[1] m_caps.customManualExposure[1] m_caps.externalSyncInput[0] m_caps.refrenceLevel[0] m_caps.flashAdjust[0] m_caps.minExposureTime[1] m_caps.maxExposureTime[300] m_caps.wideDynamicRange[1] m_caps.glareInhibition[1] m_caps.doubleExposure[0] m_caps.utc[0] m_caps.version[0] m_caps.meteringRegionCount[0] m_caps.exposureMode[401] m_caps.afPeak[0] m_caps.gammaModeRange[100] m_caps.gammaMode[1] m_caps.fishEye[0] m_caps.dayNightSwitchCtrl[1] ultConfig is empty! name = VideoInFocus getCustomDefaultCfg: The m_defaultConfig is empty! name = VideoSubColor ultCfg 77 tid:926 CCustomCamCfg::getCustomDefaultCfg: The m_defaultConfig is empty! name = DenoiseParam Cfg 110 tid:926 CCustomCamCfg::getCustomAbilityCfg: The m_defaultConfig is empty! name = VideoInZoom efaultConfig is empty! name = VideoInColor 26 CCustomCamCfg::getCustomAbilityCfg: The m_defaultConfig is empty! name = VideoInDenoise empty! name = PrivacyMasking InExposureCaps: get VideoInExposure custom ability config fail! er/RouteManager.cpp:887] 00 ---------- , videoInWB.mode = 1 VideoInAttribute::setVideoInExposureToSys: VideoInEx.iris = 50 ] [ver:] info tid:926 CVideoInAttribute::setVideoInExposureToSys: VideoInEx.WDRMode = 0 P:awbCustomLocalRect left=0,top=0,right=8191,bottom=8191 veryTime = 900 s deoInExposureToSys: enableAutoIris error, m_input->enableAutoIris:0xb6f454cc is NULL! 0mue(50),brightness(50),saturation(50),chromaSuppress(50),gamma(50),style(0),contrast(50) o tid:926 CVideoInAttribute::setVideoInDenoiseToSys m_input->setDenoise tridimDenoise:1 Auto:Mod[0] level[50] ManulType:tnfLevel[0] snfLevel[50] 2DLevel[3] DenoiseAlgorithm1[2] DenoiseAlgorithm1TnfLevel[50] DenoiseAlgorithm1SnfLevel[50] deoInBacklightToSys viBklight:mode(0),backlightMode(0),ssaMode(2) ribute::setPrivacyMaskingToSys: tilt = 0.000000 ut->setSpaceCover:(nil) is NULL! kingToSys: rect.left = 0 6 CVideoInAttribute::setPrivacyMaskingToSys: enable = 0 0;32;32m16:01:38|[ICR] currCutMethod=5, lastCutMethod =0 00000 bute::setPrivacyMaskingToSys: index = 4 deoInAttribute::setPrivacyMaskingToSys: rect.right = 0 nknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: tilt = 0.000000 vacyMaskingToSys setSpaceCover err, m_input->setSpaceCover:(nil) is NULL! [Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: zoom = 0.000000 deoInAttribute::setPrivacyMaskingToSys: enable = 0 tid:926 CVideoInAttribute::setPrivacyMaskingToSys: rect.top = 0 16:01:38|[Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: pan = 0.000000 te::setPrivacyMaskingToSys: rect.bottom = 0 1:38|[Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: pan = 0.000000 setPrivacyMaskingToSys: rect.bottom = 0 bute::setPrivacyMaskingToSys: rect.right = 0 oSys: rect.top = 0 oInAttribute::setPrivacyMaskingToSys: pan = 0.000000 32;40m16:01:38|[Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: rect.right = 0 skingToSys: pan = 0.000000 own] [ver:] warn tid:926 CVideoInAttribute::setPrivacyMaskingToSys setSpaceCover err, m_input->setSpaceCover:(nil) is NULL! .000000 ] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: pan = 0.000000 01:38|[Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: rect.right = 0 d:926 VideoInAttribute::setPrivacyMaskingToSys: rect.top = 0 Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: pan = 0.000000 NULL! tid:926 CVideoInAttribute::setPrivacyMaskingToSys: zoom = 0.000000 m16:01:39|[AEW] APP:receive params:imageStab = 0 0meoInAttribute::setPrivacyMaskingToSys setSpaceCover err, m_input->setSpaceCover:(nil) is NULL! [Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: rect.left = 0 nAttribute::setPrivacyMaskingToSys: pan = 0.000000 id:926 CVideoInAttribute::setPrivacyMaskingToSys: rect.right = 0 Unknown] [ver:] info tid:926 CVideoInAttribute::setPrivacyMaskingToSys: index = 22 skingToSys: rect.top = 0 CVideoInAttribute::setPrivacyMaskingToSys: pan = 0.000000 = 0 kManager/RouteManager.cpp:721] ne? [Src/NetworkManager/RouteManager.cpp:721] ode :BufMode, line : 597 16:01:42|[] [ver:] info tid:926 AddrRange(0xa634e400-0xa734e400) :Unknown] info DevVideoEnc.cpp CDevVideoEnc 382 tid:926 CDevVideoEnc stream [0] encoder ChipCaps:[ladenBitrate:1130400] 16:01:42|[Unknown] [ver:Unknown] info DevVideoEnc.cpp CDevVideoEnc 378 tid:926 CDevVideoEnc stream [1] encoder Caps:[types 24,coverCount:4,titleCount:5,snapByOtherSize:0coverRemain:0,snapFps:1.000000,roiCount:4,h264ProfileMask:0xb,svcTLevel:0indepBymainCapture:0x2, bppTypeMask:0, dynamicTrack:1, maxRoiWidth:0, maxRoiHeight:0,encodePolicy:0] OSDFactory.cpp instance 30 tid:926 COSDObj::instance channel = 0, group = 0, stream = 3 OSDFactory.cpp instance 30 tid:926 COSDObj::instance channel = 0, group = 0, stream = 3 Obj::instance channel = 0, group = 0, stream = 2 6:01:42|[libaudio] getAudioADCount, ADcount=0 workManager/RouteManager.cpp:721] Caps == Json::nullValue amNum=2, fps[25.000000 25.000000 0.000000], enable[1 1 0] encodePolicy:0 ,configs[0].vinFps:25.000000 000==bitrate[1792, 9216] Limit = [.min=1792, .max=9216, .suggest=4096], bitrateFpsMax = 11360.000000, bitrateMin = 2144.000000 FpsMax = 2832.000000, bitrateMin = 528.000000 Num=2, fps[25.000000 25.000000 0.000000], enable[1 1 0] encodePolicy:0 ,configs[0].vinFps:25.000000 itrateFpsMax = 2832.000000, bitrateMin = 528.000000 n] error DevAudioEnc.cpp CDevAudioEnc 116 tid:926 CDevAudioEnc :: createAudioEncoder Failed !!! cObj|2712): init ad obj err cy:0 ,configs[0].vinFps:25.000000 6:01:43|[Unknown] [ver:] trace tid:926 ==channel:0==streamId:0==fpsMax:25.000000==bitrate[768, 4864] y:0 ,configs[0].vinFps:25.000000 CDevVideoEnc::getRoiCount>>>4 nSensorCfg::setVideoSensor m_input(0x0x17027f0) or m_input->setSensorOptions error! ate: 0 1, priority = 0,----isVideoChanged = 0 encodePolicy=0---- libvsf] User set stream0 enc 3, 1280x720@25.0fps GOP 50; bitrate 1024, type 1 smartEncEnable:0. ex=-1 2, priority = 8 mergerIndex=-1 2, priority = 13 mergerIndex=-1 0mknown] info DevVideoEnc.cpp setTemporaryEncodeROI 633 tid:926 CDevVideoEnc::setTemporaryEncodeROI VideoEnc setROI succeed ROI[0] nknown] info DevVideoEnc.cpp setTemporaryEncodeROI 633 tid:926 CDevVideoEnc::setTemporaryEncodeROI VideoEnc setROI succeed eoIn.cpp:3777,rotate state: 0 16:01:44|[Unknown] [ver:] info tid:926 CEncode::onConfigVideoInDefog enter! ;32m16:01:44|[libvsf] after change, fps:25,25,0 [0;32;32m16:01:44|[libvsf] User set stream3 enc 4, 1280x720@1.0fps GOP 60; bitrate 5120, type 1 smartEncEnable:0. ConfigManager.cpp getConfig 371 tid:926 CCommonConfigManager::getConfig Talkback is Json::nullValue! FocusStatus:: Video In Not support this Interface .cpp rotateState 3777 tid:926 Src/Media/DevVideoIn.cpp:3777,rotate state: 0 e DevVideoIn.cpp rotateState 3777 tid:926 Src/Media/DevVideoIn.cpp:3777,rotate state: 0 :01:44|[Unknown] [ver:Unknown] info DevVideoEnc.cpp parseConfig 1012 tid:926 CDevVideoEnc::parseConfig SVCTLayer:0 :0 [Unknown] [ver:Unknown] trace DevVideoEnc.cpp setFormat 1170 tid:926 CDevVideoEnc::setFormat channel = 0, stream = 0, size = [1280, 720], fps = 25.000000, gop = 50, bitratectrl = 1, bitrate = 1024 kbps, quality = 6,pack = 0, type = 3, h264profile = 1, priority = 0,----isVideoChanged = 0 encodePolicy=0---- d:926 CDevVideoEnc::parseConfig SVCTLayer:0 :0 c.cpp setWorkFormat 793 tid:926 ----libMedia-------CDevVideoEnc::setWorkFormat: width: 704, height: 576 m_stream:1 [32;40m16:01:45|[Unknown] [ver:Unknown] info DevVideoEnc.cpp setFormat 1200 tid:926 Src/Media/DevVideoEnc.cpp:1200 format is same, do nothing. eoIn.cpp setFormat 2198 tid:926 CDevVideoIn::setFormat channel = 0, size = [1920, 1080], fps = 25.000000, window = [0, 0, 1920, 1080] mlity = 6,pack = 0, type = 3, h264profile = 1, priority = 0,----isVideoChanged = 0 encodePolicy=0---- 2m16:01:45|[AEW] defFps====25.0000, f32Fps=====25.0000 :45|[Unknown] [ver:] warn tid:926 onConfigEncrypt failed,at channelID 0 stream 0 [libvsf] VSF_COM_ENCPAL_SET_ROI[1] 5|[Unknown] [ver:] info tid:926 CEncode::onConfigVideoInFaceAutoExposure enter! etworkState::instance: channel=0 Src/Media/OSD/OSDManager.cpp:setTitle:563, stream = 0,title is 0 ;40m16:01:46|[Unknown] [ver:Unknown] warn Detect.cpp start 655 tid:926 CAudioDetect::start()>>>unSupported AudioDetect! igAudioOutputVolume()>>>setVolume [50] failed! tDeviceTypeInter:14 realDeviceType(IPC-HFW2220M) RemoteService] [ver:] trace tid:926 CWideViewControlService::CWideViewControlService info Main.cpp main 1118 tid:926 >>>>>>>>>>>>>>>>>DVRIP_begin:42949416260 :926 >>>>>>>>>>>>>>>>>STORAGE_begin:42949416270 ============ :963 stream 3 chn 0 fps 0 width 704 height 576 rate 0 minDspRate:0 ] trace tid:926 CNfsClient::start() finished! App-445666] [ver:] debug tid:926 tid:926, code: StopDelDir, index: 0, action: 4 [Src/smtpNew/EventHandle.cpp:254] >>>>>>>>>>>>>>>>>STORAGE_end:42949416630 e DevVideoEnc.cpp adjustPre 1423 tid:926 presecond set to: 7 ######## ########## OpenSSL1.0.2i Ready ################# et to: 65 trace DevVideoEnc.cpp adjustPre 1423 tid:926 presecond set to: 7 e file format e tid:926 mode:1, mask:2 ] before change, H264 encaps 72806400, fps:25,25,0 tid:926 CMagicBox::getDeviceSubClass DeviceSubClass empty ! " : 0, "is_hide_TrafficTollGate" : 0, "is_hide_audManage" : 1, "is_hide_connectHttpsEnable" : 1, "is_hide_iExclusionConfig" : 0, "is_k6_DeviceType" : 0, "is_new_IVSUI" : false, "is_noNeed_reboot" : 0, "is_numberOK_Gate" : 0, "is_show_CusBitRateRange" : 0, "is_show_DevInit" : 0, "is_show_FullyDefault" : 0, "is_show_HTTPS" : 1, "is_show_ICR" : 1, "is_show_LDAP" : 0, "is_show_LocationInfo" : 1, "is_show_MP4DownLoad" : 0, "is_show_OSDinfo" : 1, "is_show_Onvif" : 1, "is_show_PCM" : 0, "is_show_QT_VidAnalyse_VidInAttr" : true, "is_show_Syslog" : 1, "is_show_T2UServer" : 1, "is_show_VPN_Certificate" : 0, "is_show_WtchNtCust;40m16:01:47|[Unknown] [ver:Unknown] info Main.cpp main 1170 tid:926 >>>>>>>>>>>>>>>>>INTERVIDEO_begin:42949417750 ;40m16:01:47|[Unknown] [ver:Unknown] info Main.cpp main 1170 tid:926 >>>>>>>>>>>>>>>>>INTERVIDEO_begin:42949417750 pp Start 102 tid:926 CInterVideo::Start!! 48|[libpdi] syncFocus: 0 8|[libpdi] ---------------------------------- oIn getImageCaps succeed! AnalyticsManager.cpp::initConfig@0051 | COnvifVideoAnalyticsManager initConfig -01 16:01:48 | ONVIF | Src/OnvifComm.cpp::getSDPtzCaps@1301 | Ptz Component is NULL. 2000-01-01 16:01:48 | ONVIF | Src/OnvifInterVideo.cpp::Run@0088 | OnvifDefaultConifg is completed 2000-01-01 16:01:48 | ONVIF | Src/OnvifInterVideo.cpp::Run@0091 | OnvifEventService is completed t Vendor: Dahua t Vendor: Dahua Device. :01:48 | ONVIF | Src/OnvifInterVideo.cpp::Run@0098 | ONVIF start OK feng#########[22] feng#########[27] #########CInterVideoUpgrate::Run([73] adBody Enter name = IV_WorkerMgr, id = 975, prior = N64, stack = 0x9b80fec4 er.cpp:986]|WARN [0xc5c420], tid:926, Component::getComponentInstance<IUdpMulticastService> failed! |16:01:48|[StreamApp@445535][ConfigSupplier.h:179]|ERR [0xbedcb114], tid:926, rtp_size=2, rhs's=2, ts_size=2, rhs's=2, udp_size=0, rhs's=0,dh_size=2, rhs's=0. |16:01:48|[StreamApp@445535][RtspServiceLoader.cpp:975]|WARN [0xc5c420], tid:926, Component::getComponentInstance<ITsMulticastService> failed! CommonConfigManager.cpp getConfig 371 tid:926 CCommonConfigManager::getConfig RemoteChannel is Json::nullValue! ver" : "www.easy4ip.com", "ThreadNum" : 1, "Type" : "dhp2p", "UUID" : "3H00BD5PAA00036", "WebVersion" : "2.420.0" } . [Src/P2P/P2P.cpp:241] ] minute[58] enable[1] tUpdateState" : "failed" } ] [0m [Pooled] 954 64 Normal m16:01:48|[libInfra] [ver:] info tid:926 NetFramework 945 64 Normal m16:01:48|[libInfra] [ver:] info tid:926 [Pooled] 938 64 Normal RunningTime Period Used/Timeout State [ver:] info tid:926 PushNotification 42949419930 0 1000 0/ 60000 Idle 0 0/ 60000 Idle 000 340/180000 Running 01:49|[libInfra] [ver:] info tid:926 DNSCache 42949462840 0 60000 0/ 60000 Idle ] defFps====25.0000, f32Fps=====25.0000 info tid:926 [*] Manager 1.1.0.463227 Built in 2017/ 6/20 [*] cpp main 1242 tid:926 >>>>>>>>>>>>>>>>>SOME_end:42949419780 n 1250 tid:926 [ INITION] run time: 3040############# 250 tid:926 [ RPCCOM] run time: 60############# r.cpp:721] [AEW] defFps====25.0000, f32Fps=====25.0000 kManager/RouteManager.cpp:854] or tid:957 tid:957, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] 6:01:58|[NetApp-445666] [ver:] error tid:938 tid:938, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:887] :] error tid:938 tid:938, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] ager.cpp:721] [NetApp-445666] [ver:] error tid:957 tid:957, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:887] Manager/RouteManager.cpp:854] 66] [ver:] error tid:938 tid:938, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] ror tid:956 tid:956, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] r.cpp:721] [0msystools] ERROR (../../src/sendarp/sendarp.c|PDI_sendFreeNA|504): inet_pton error for ager.cpp:854] 445666] [ver:] error tid:956 tid:956, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] th is not on line? [Src/NetworkManager/RouteManager.cpp:854] total bytes allocated = 53288960 total bytes in use bytes = 53274560 total non-mmapped bytes allocated = 4685824 number of mmapped regions = 10 total allocated mmap space = 48603136 total allocated sbrk space = 4671424 maximum total allocated space = 53547008 total free space = 14400 memory releasable via malloc_trim = 5840 etApp-445666] [ver:] error tid:954 tid:954, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] App-445666] [ver:] error tid:956 tid:956, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] 66] [ver:] error tid:952 tid:952, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:887] anager.cpp:854] teManager.cpp:721] ll Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] ;40m16:02:38|[NetApp-445666] [ver:] error tid:957 tid:957, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:887] anager/RouteManager.cpp:854] RouteManager.cpp:854] ager.cpp:854] 45666] [ver:] error tid:957 tid:957, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] App-445666] [ver:] error tid:952 tid:952, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:854] r:] error tid:952 tid:952, All Eth is not on line? [Src/NetworkManager/RouteManager.cpp:887] ---------- Добавлено спустя 3 минуты 31 секунду: ---------- Почему то пишет product_name =IPC-HFW2220M, может кто то до меня обновил не той прошивкой и потому зависает? |
vova_w810i [ 01 фев 2020, 18:45 ] | |
В логе пишет ее IP: 192.168.1.108 но заходит под этим: 192.168.0.75 и через несколько минут изображение замораживается, при этом по веб-интерфейсу можно клацать все настройки, а картинка мертво стоит и не меняется, не реагирует камера на движения. |
fobos [ 01 фев 2020, 20:14 ] | |
вывод команд printenv и help показывайте....ttl-uart адаптер есть? |
vova_w810i [ 01 фев 2020, 22:28 ] | |
Вот лог команд printenv и help:
Checking DDR......OK
UBL Version: 1.43t(DM368 12/25/2012) Oscillator: 24MHZ ARM Rate: 432 MHZ DDR Rate: 340 MHZ start watchdog BootMode: SPI Starting SPI Memory Copy... DONE U-Boot 1.3.6 (jerry) (Oct 13 2014 - 11:56:55) DRAM: 128 MB [22]=1 gio[25]=1 Loading...[22]=1 gio[25]=1 Loading...Detected W25Q64 with page size 256, total 8 MB In: serial Out: serial Err: serial Ethernet PHY: GENERIC @ 0x03,id:221513 total gio 2 gioDHBOOT# printenv bootdelay=3 baudrate=115200 wifiaddr=00:01:5b:00:77:88 ipaddr=10.12.10.28 serverip=10.12.9.27 bootfile="uImage" appauto=1 single=0 dc=tftp 81a00000 custom-x.cramfs.img; flwrite dr=tftp 81a00000 romfs-x.cramfs.img; flwrite du=tftp 81a00000 user-x.cramfs.img; flwrite dd=tftp 81a00000 data-x.cramfs.img; flwrite dw=tftp 81a00000 web-x.cramfs.img; flwrite up=tftp 81a00000 update.img; flwrite tk=tftp 80800000 uImage; bootm 80800000 gionum=22.25 gioval=1.1 dh_com=0 autosip=192.168.254.254 autolip=192.168.1.108 autogw=192.168.1.1 autonm=255.255.255.0 HWID=IPC-HFW2200B-V2:01:02:02:03:05:00:01:00:00:00:00:1B0:00:00:02:00:00:00:00:00:80 devalias=IPC-HFW1200S bootcmd=fsload 0x80800000 0x00060000;bootm 0x80800000 bootargs=console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=squashfs ,nolock mem=78M video=davincifb:vid0=OFF:vid1=OFF:osd0=OFF:osd1=OFF da=protect off all;tftp 81a00000 dm365_ubl_boot_8M_spiflash.bin.img;flwrite ID=TZC4LU190W00838 filesize=200 fileaddr=87000000 ethaddr=4C:11:BF:8B:6C:7B dh_keyboard=0 stdin=serial stdout=serial stderr=serial ver=U-Boot 1.3.6 (jerry) (Oct 13 2014 - 11:56:55) Environment size: 1107/16380 bytes DHBOOT# help ? - alias for 'help' autoscr - run script from memory base - print or set address offset boot - boot default, i.e., run 'bootcmd' bootd - boot default, i.e., run 'bootcmd' bootm - boot application image from memory bootp - boot image via network using BootP/TFTP protocol cmp - memory compare coninfo - print console devices and information cp - memory copy cpll - chang PLL multiplier crc32 - checksum calculation echo - echo args to console erase - erase FLASH memory flinfo - print FLASH memory information flwrite - write data into FLASH memory fsload - load binary file from a filesystem image gpio init - set gionum to gioval go - start application at address 'addr' help - print online help flwrite - write hwid into FLASH memory id - set product id and save to flash iminfo - print header information for application image lip - set local ip address but not save to flash loadb - load binary file over serial line (kermit mode) loads - load S-Record file over serial line loady - load binary file over serial line (ymodem mode) loop - infinite loop on address range mac - set mac address and save to flash md - memory display meminit - memset 0xcc memsize - set mem size mii - MII utility commands mm - memory modify (auto-incrementing) mtest - simple RAM test mw - memory write (fill) nm - memory modify (constant address) ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables protect - enable or disable FLASH write protection rarpboot- boot image via network using RARP/TFTP protocol recover default env reset - Perform RESET of the CPU run - run commands in an environment variable saveenv - save environment variables to persistent storage saves - save S-Record file over serial line setenv - set environment variables sf - spi and nor flash sub-system probe [bus:]cs [hz] [mode] - init flash device on given SPI bus and chip select sf write addr offset len - write `len' bytes from memory at `addr' to flash at `offset' sf erase startaddr endaddr - erase bytes from `startaddr' to `endaddr' sip - set server ip address but not save to flash tftpboot- boot image via network using TFTP protocol uartUp- update image via uart using uart1 version - print monitor version DHBOOT# |
fobos [ 02 фев 2020, 00:43 ] | |
это для hdw1220s https://cloud.mail.ru/public/3BGz/4F77TRBvg это для hfw1200sp https://cloud.mail.ru/public/5fsg/54NJ1775c |
vova_w810i [ 02 фев 2020, 01:22 ] | |
После прошивки никаких команд вводить не нужно? |
fobos [ 02 фев 2020, 01:42 ] | |
если камера загрузится, то надо будет прописывать мас и id |
vova_w810i [ 02 фев 2020, 01:52 ] | |
Можете сразу написать команды как это сделать? Я по очереди подпаюю адаптер TTL проводами на какую камеру, у этих камер нет разъёмов. |
vova_w810i [ 02 фев 2020, 10:26 ] | |
Прошил флешку программатором, камера не грузится, на веб интерфейс не заходит. Вот лог загрузки:
System startup
U-Boot 2010.06-svn4554 (Sep 29 2017 - 21:11:12) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. *** Warning - bad CRC, using default environment partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 In: serial Out: serial Err: serial TEXT_BASE:81000000 sd update init:HWID is missing! Hit any key to stop autoboot: 0 > setenv dh_keyboard o > saveenv Saving Environment to SPI Flash... Erasing SPI flash... Writing to SPI flash... done > reset resetting ... System startup System startup U-Boot 2010.06-svn4554 (Sep 29 2017 - 21:11:12) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 In: serial Out: serial Err: serial TEXT_BASE:81000000 sd update init:HWID is missing! Hisilicon ETH net controler MAC: 00-13-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'upgrade_info_7db780a713a4.txt'. Download to address: 0x84000000 Downloading: Retry count exceeded; starting again Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'upgrade_info_7db780a713a4.txt'. Download to address: 0x84000000 Downloading: Retry count exceeded; starting again Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Download Filename 'failed.txt'. Download to address: 0x82000000 Downloading: Retry count exceeded; starting again ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1247144 Bytes = 1.2 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to parse HWID fail to parse bootargsParameters.text info get bootargs info failed cmdLine mem=47M console=ttyS0,115200 root=/dev/mtdblock6 rootfstype=squashfs crashflasg:1, logmagic:54410011. Starting kernel ... Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518ev200 gLogRamRes: start=0x82eb7000;size=0x47000 mem_relimitAddr:0x82efe000 console [ttyS0] enabled |
fobos [ 02 фев 2020, 13:32 ] | |
пропишите hwid командой, которую я вам давал на камеру к12w, только сам hwid возьмите из лога той камеры, которая сейчас в работе...там же есть команды всего остального...посмотрите внимательно...команды одинаковые, только значения ставите данной камеры из еелога |
vova_w810i [ 02 фев 2020, 15:38 ] | |
Прошил еще раз камеру, прописал hwid и id, но на веб интерфейс не могу зайти
System startup
U-Boot 2010.06-svn4554 (Sep 29 2017 - 21:11:12) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 In: serial Out: serial Err: serial TEXT_BASE:81000000 MMC: Hit any key to stop autoboot: 0 > printenv bootargs=mem=47M console=ttyS0,115200 root=/dev/mtdblock7 rootfstype=squashfs bootcmd=kload 0x82000000; bootm 0x82000000 bootdelay=1 baudrate=115200 ethaddr=00:13:34:56:78:9A ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite dk=tftp 0x82000000 kernel.img; flwrite du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img; flwrite tk=tftp 0x82000000 uImage; bootm appauto=1 loglevel=4 pd=tftp 0x82000000 pd-x.squashfs.img; flwrite dh_keyboard=0 HWID=IPC-HFW2200B-V2:01:02:02:03:05:00:01:00:00:00:00:1B0:00:00:02:00:00:00:00:00:80 ID=TZC4LU190W00838 stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn4554 (Sep 29 2017 - 21:11:12) Environment size: 1028/262140 bytes Вот лог загрузки:
System startup
U-Boot 2010.06-svn4554 (Sep 29 2017 - 21:11:12) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 In: serial Out: serial Err: serial TEXT_BASE:81000000 MMC: Hisilicon ETH net controler MAC: 00-13-34-56-78-9A Up/Down PHY not link. Try again use backup_serverip Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A Up/Down PHY not link. Failed to get info.txt Fail to get info file! Init error! Hisilicon ETH net controler miiphy_register: non unique device name '0:1' miiphy_register: non unique device name '0:2' MAC: 00-13-34-56-78-9A Up/Down PHY not link. ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1247144 Bytes = 1.2 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ...OK OK partition file version 2 rootfstype squashfs root /dev/mtdblock6 can not search bootargs settings fail to parse bootargsParameters.text info get bootargs info failed cmdLine mem=47M console=ttyS0,115200 root=/dev/mtdblock6 rootfstype=squashfs crashflasg:1, logmagic:54410011. Starting kernel ... Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: hi3518ev200 gLogRamRes: start=0x82eb7000;size=0x47000 mem_relimitAddr:0x82efe000 console [ttyS0] enabled яmount: mounting tmpfs on /tmp failed: No such file or directory mknod: /dev/console: File exists mknod: /dev/ttyS0: File exists mknod: /dev/ttyS1: File exists mknod: /dev/null: File exists chmod: /dev/fd: Operation not permitted chmod: /dev/fd: Operation not permitted keyboard = 0 mount: mounting devpts on /dev/pts failed: Device or resource busy Module himedia: init ok hi3518e_base: module license 'Proprietary' taints kernel. hi3518e_base: Unknown symbol hil_mmb_free (err 0) hi3518e_base: Unknown symbol hil_mmb_getby_phys (err 0) hi3518e_base: Unknown symbol hil_mmb_alloc (err 0) insmod: can't insert 'hi3518e_base.ko': unknown symbol in module, or unknown parameter hi3518e_sys: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_sys: Unknown symbol CMPI_StopModules (err 0) hi3518e_sys: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_sys: Unknown symbol CMPI_UserCopy (err 0) hi3518e_sys: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_sys: Unknown symbol CMPI_CreateProc (err 0) hi3518e_sys: Unknown symbol CMPI_GetModuleName (err 0) hi3518e_sys: Unknown symbol CMPI_ExitModules (err 0) hi3518e_sys: Unknown symbol CMPI_InitModules (err 0) hi3518e_sys: Unknown symbol CMPI_QueryModules (err 0) hi3518e_sys: Unknown symbol HI_LOG (err 0) hi3518e_sys: Unknown symbol CMPI_MmzFree (err 0) hi3518e_sys: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_sys: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_sys: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_sys.ko': unknown symbol in module, or unknown parameter hi3518e_tde: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_tde: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_tde: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_tde: Unknown symbol CMPI_CreateProc (err 0) hi3518e_tde: Unknown symbol HI_LOG (err 0) hi3518e_tde: Unknown symbol CMPI_MmzFree (err 0) hi3518e_tde: Unknown symbol hil_mmb_flush_dcache_byaddr (err 0) hi3518e_tde: Unknown symbol CMPI_RegisterModule (err 0) insmod: can't insert 'hi3518e_tde.ko': unknown symbol in module, or unknown parameter hi3518e_region: Unknown symbol TdeOsiCancelJob (err 0) hi3518e_region: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_region: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_region: Unknown symbol CMPI_UserCopy (err 0) hi3518e_region: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_region: Unknown symbol TdeOsiEndJob (err 0) hi3518e_region: Unknown symbol CMPI_CreateProc (err 0) hi3518e_region: Unknown symbol TdeOsiBeginJob (err 0) hi3518e_region: Unknown symbol TdeOsiWaitForDone (err 0) hi3518e_region: Unknown symbol HI_LOG (err 0) hi3518e_region: Unknown symbol CMPI_MmzFree (err 0) hi3518e_region: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_region: Unknown symbol TdeOsiQuickCopy (err 0) hi3518e_region: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_region: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_region: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_region.ko': unknown symbol in module, or unknown parameter hi3518e_vgs: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_vgs: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_vgs: Unknown symbol VB_UserAdd (err 0) hi3518e_vgs: Unknown symbol CMPI_UserCopy (err 0) hi3518e_vgs: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_vgs: Unknown symbol VB_UserSub (err 0) hi3518e_vgs: Unknown symbol CMPI_CreateProc (err 0) hi3518e_vgs: Unknown symbol CMPI_GetModuleName (err 0) hi3518e_vgs: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_vgs: Unknown symbol VB_Phy2Handle (err 0) hi3518e_vgs: Unknown symbol HI_LOG (err 0) hi3518e_vgs: Unknown symbol CMPI_MmzFree (err 0) hi3518e_vgs: Unknown symbol VB_Handle2Kern (err 0) hi3518e_vgs: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_vgs: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_vgs: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_vgs: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_vgs: Unknown symbol VB_Handle2Phys (err 0) hi3518e_vgs: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_vgs.ko': unknown symbol in module, or unknown parameter updatePos = 0 chip_id = 05 hi3518e_isp: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_isp: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_isp: Unknown symbol CMPI_CreateProc (err 0) hi3518e_isp: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_isp: Unknown symbol CMPI_MmzMallocCached (err 0) hi3518e_isp: Unknown symbol HI_LOG (err 0) hi3518e_isp: Unknown symbol CMPI_MmzFree (err 0) hi3518e_isp: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_isp: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_isp: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_isp: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_isp.ko': unknown symbol in module, or unknown parameter hi3518e_viu: Unknown symbol VB_Handle2Supplement (err 0) hi3518e_viu: Unknown symbol VB_InquirePoolUserCnt (err 0) hi3518e_viu: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_viu: Unknown symbol VB_UserAdd (err 0) hi3518e_viu: Unknown symbol CMPI_UserCopy (err 0) hi3518e_viu: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_viu: Unknown symbol VB_UserSub (err 0) hi3518e_viu: Unknown symbol CMPI_CreateProc (err 0) hi3518e_viu: Unknown symbol VB_GetBlkByPoolId (err 0) hi3518e_viu: Unknown symbol VB_CreatePool (err 0) hi3518e_viu: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_viu: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_viu: Unknown symbol ISP_GetDCFInfo (err 0) hi3518e_viu: Unknown symbol VB_IsBlkValid (err 0) hi3518e_viu: Unknown symbol HI_LOG (err 0) hi3518e_viu: Unknown symbol VB_Handle2Kern (err 0) hi3518e_viu: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_viu: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_viu: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_viu: Unknown symbol vi_vpss_online (err 0) hi3518e_viu: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_viu: Unknown symbol VB_DestroyPool (err 0) hi3518e_viu: Unknown symbol VB_Handle2Phys (err 0) hi3518e_viu: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_viu.ko': unknown symbol in module, or unknown parameter hi3518e_vpss: Unknown symbol VB_Handle2Supplement (err 0) hi3518e_vpss: Unknown symbol coefficient6_3M_a15 (err 0) hi3518e_vpss: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_vpss: Unknown symbol g_power_save_enable (err 0) hi3518e_vpss: Unknown symbol VB_UserAdd (err 0) hi3518e_vpss: Unknown symbol coefficient4_2M_a05 (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_vpss: Unknown symbol CMPI_UserCopy (err 0) hi3518e_vpss: Unknown symbol coefficient4_5M_a15 (err 0) hi3518e_vpss: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_vpss: Unknown symbol VB_UserSub (err 0) hi3518e_vpss: Unknown symbol CMPI_CreateProc (err 0) hi3518e_vpss: Unknown symbol coefficient8_lanczos2_8tap (err 0) hi3518e_vpss: Unknown symbol coefficient6_cubic (err 0) hi3518e_vpss: Unknown symbol coefficient8_2M_a05 (err 0) hi3518e_vpss: Unknown symbol coefficient8_3M_a19 (err 0) hi3518e_vpss: Unknown symbol coefficient6_4M_a20 (err 0) hi3518e_vpss: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_vpss: Unknown symbol coefficient8_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_vpss: Unknown symbol VIU_DRV_IsFrameFlashed (err 0) hi3518e_vpss: Unknown symbol coefficient8_cubic (err 0) hi3518e_vpss: Unknown symbol coefficient4_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol ISP_GetDCFInfo (err 0) hi3518e_vpss: Unknown symbol coefficient6_2M_a05 (err 0) hi3518e_vpss: Unknown symbol VB_IsBlkValid (err 0) hi3518e_vpss: Unknown symbol g_proc_enable (err 0) hi3518e_vpss: Unknown symbol HI_LOG (err 0) hi3518e_vpss: Unknown symbol CMPI_MmzFree (err 0) hi3518e_vpss: Unknown symbol VB_Handle2Kern (err 0) hi3518e_vpss: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_vpss: Unknown symbol coefficient6_1_5M_a05 (err 0) hi3518e_vpss: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_vpss: Unknown symbol coefficient4_cubic (err 0) hi3518e_vpss: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_vpss: Unknown symbol vi_vpss_online (err 0) hi3518e_vpss: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_vpss: Unknown symbol coefficient6_5M_a25 (err 0) hi3518e_vpss: Unknown symbol VB_Handle2Phys (err 0) hi3518e_vpss: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_vpss.ko': unknown symbol in module, or unknown parameter hi3518e_rc: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_rc: Unknown symbol g_proc_all (err 0) hi3518e_rc: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_rc: Unknown symbol CMPI_CreateProc (err 0) hi3518e_rc: Unknown symbol HI_LOG (err 0) hi3518e_rc: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_rc: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_rc: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_rc.ko': unknown symbol in module, or unknown parameter hi3518e_venc: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_venc: Unknown symbol VB_UserAdd (err 0) hi3518e_venc: Unknown symbol CMPI_UserCopy (err 0) hi3518e_venc: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_venc: Unknown symbol VB_UserSub (err 0) hi3518e_venc: Unknown symbol CMPI_CreateProc (err 0) hi3518e_venc: Unknown symbol VB_GetBlkBySize (err 0) hi3518e_venc: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_venc: Unknown symbol VB_IsBlkValid (err 0) hi3518e_venc: Unknown symbol g_proc_enable (err 0) hi3518e_venc: Unknown symbol HI_LOG (err 0) hi3518e_venc: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_venc: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_venc: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_venc: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_venc: Unknown symbol VB_Handle2Phys (err 0) hi3518e_venc: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_venc.ko': unknown symbol in module, or unknown parameter hi3518e_chnl: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_chnl: Unknown symbol g_proc_all (err 0) hi3518e_chnl: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_chnl: Unknown symbol CMPI_CreateProc (err 0) hi3518e_chnl: Unknown symbol HI_LOG (err 0) hi3518e_chnl: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_chnl: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_chnl: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_chnl.ko': unknown symbol in module, or unknown parameter hi3518e_h264e: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_h264e: Unknown symbol VB_UserAdd (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMalloc (err 0) hi3518e_h264e: Unknown symbol hil_mmb_invalid_cache_byaddr (err 0) hi3518e_h264e: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_h264e: Unknown symbol VB_UserSub (err 0) hi3518e_h264e: Unknown symbol CMPI_CreateProc (err 0) hi3518e_h264e: Unknown symbol VB_GetBlkByPoolId (err 0) hi3518e_h264e: Unknown symbol VB_CreatePool (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzMallocCached (err 0) hi3518e_h264e: Unknown symbol HI_LOG (err 0) hi3518e_h264e: Unknown symbol CMPI_MmzFree (err 0) hi3518e_h264e: Unknown symbol hil_mmb_flush_dcache_byaddr (err 0) hi3518e_h264e: Unknown symbol VB_Handle2BlkSize (err 0) hi3518e_h264e: Unknown symbol VB_Handle2PoolId (err 0) hi3518e_h264e: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_h264e: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_h264e: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_h264e: Unknown symbol VencBufferCache (err 0) hi3518e_h264e: Unknown symbol VB_DestroyPool (err 0) hi3518e_h264e: Unknown symbol VB_Handle2Phys (err 0) hi3518e_h264e: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_h264e.ko': unknown symbol in module, or unknown parameter hi3518e_jpege: Unknown symbol CMPI_UnRegisterModule (err 0) hi3518e_jpege: Unknown symbol CMPI_MmzMallocNocache (err 0) hi3518e_jpege: Unknown symbol hil_mmb_invalid_cache_byaddr (err 0) hi3518e_jpege: Unknown symbol CMPI_RemoveProc (err 0) hi3518e_jpege: Unknown symbol CMPI_CreateProc (err 0) hi3518e_jpege: Unknown symbol VB_IsSupplementSupport (err 0) hi3518e_jpege: Unknown symbol HI_LOG (err 0) hi3518e_jpege: Unknown symbol CMPI_MmzFree (err 0) hi3518e_jpege: Unknown symbol CMPI_GetModuleFuncById (err 0) hi3518e_jpege: Unknown symbol CMPI_RegisterModule (err 0) hi3518e_jpege: Unknown symbol CMPI_UnRegisterDevice (err 0) hi3518e_jpege: Unknown symbol VencBufferCache (err 0) hi3518e_jpege: Unknown symbol CMPI_RegisterDevice (err 0) insmod: can't insert 'hi3518e_jpege.ko': unknown symbol in module, or unknown parameter insmod: can't open 'hi3518e_vda.ko': No such file or directory [OSA-DRV] OSA Build on Sep 30 2017 at 06:46:17. [OSA-DRV] SVN NUM: 5514. [OSA-DRV] Monitor Task pid=730 tid=730 [LOG-DRV] LOG Build on Sep 30 2017 at 06:43:07. [LOG-DRV] SVN NUM: 9984. [LOG-DRV] ramStart:0x82eb7000;ramSize:0x47000;select:1 [OSA-DRV] Char device create OK ! [LOG-DRV] coreId = 0, logLevel = 2 [LOG-DRV] coreId = 1, logLevel = 2 [LOG-DRV] coreId = 2, logLevel = 2 [LOG-DRV] coreId = 3, logLevel = 2 [LOG-DRV] coreId = 4, logLevel = 2 [LOG-DRV] coreId = 5, logLevel = 2 product = aewcfg = IPC-IPVM2150F cp: can't stat '/var/tmp/2Acfg/IPC-IPVM2150F/icr_para.bin': No such file or directory /usr/etc/IPCimod: line 278: VideoDaemon: not found appauto=1 cat: can't open '/var/tmp/memsize': No such file or directory [: 64: unknown operand ./usr/etc/app.sh: line 21: can't create /proc/osa_root/pdc/pdcWdt: nonexistent directory 0;32;32m00:00:14|[pdc] @haric@ c21c3e58 0x0 ackup partition !!! N NUM: 11853. 2m00:00:18|[AEW] AEWB ALG Build on Sep 29 2017 at 21:03:05. created ok! libpdi] ERROR (PDI_adcCreate|111): Can't open /dev/pdcAdc nd icr_para.bin ! adc! 0:00:19|[libvsf] AEWB run !!! |00:00:19|[StreamApp@492088][StreamApp.cpp:18]|INFO [StreamAppComponent] initStreamAppServerComponent |00:00:19|[StreamApp@492088][QuickMulticast.cpp:17]|INFO [StreamAppComponent] initStreamAppQuickMulticastComponent |00:00:19|[StreamSvr@483652][TransformatBase.cpp:9]|INFO [StreamAppComponent] initStreamSvrParseCreaterComponent |00:00:19|[StreamApp@492088][DHEncrypt.cpp:11]|INFO [StreamAppComponent] initStreamAppDHEncryptComponent i called Storage this = 0xf4e0bc i called 90 I register FileManager Factory in storage clsid=Local ret=1 $$$$$$$$$$$MEM_SIZE:0$$$$$$$$$$$$$ :00:19|[libpdi] >-------System3_getSystemInfo-------> :00:19|[libpdi] deviceClass: IPC regions = 0 total allocated mmap space = 0 total allocated sbrk space = 498440 maximum total allocated space = 507904 total free space = 9464 memory releasable via malloc_trim = 7232 :882 CFileLog::config,get logs from file(/mnt/mtd/Log/log0.zip) failed 2 CFileLog::getLogsFromFiles,open(/mnt/mtd/Log/logbackup0.zip) failed d config file /mnt/mtd/Config/Config1Sec /mnt/backup/Config/Config2Sec failed v devOEM! Fail to get env authcode! AutoStart: 1 ager] [ver:] info tid:882 CMagicBox::CMagicBox() getStartUpFlag 2 RROR (PDI_wdtOpen|109): wdt open error rManager.cpp initialize 353 tid:882 currDevSerial:TZC4LU190W00838 ize=1024, adjust to 16k ebug Thread.cpp InternalThreadBody 113 tid:897 ThreadBody Enter name = Console, id = 897, prior = N1, stack = 0xaeb75eb4 SSHDHelper.cpp start 72 tid:882 CSShConfigHelper::start, get ProductDefinition[SupportSSH] Failed || SupportSSH is false. h) Revision: 30649 Enter 'help' for a list of built-in commands. ~ # есть какието ошибки: fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 |
vova_w810i [ 03 фев 2020, 14:35 ] | |
Может она не загружатся из-за прописанных HWID и ID с другой камеры? |
fobos [ 03 фев 2020, 17:54 ] | |
vova_w810i писал(а): Может она не загружатся из-за прописанных HWID и ID с другой камеры? но эти параметры были изначально в этой камере, если только она к вам пришла с уже измененными HWID и ID |
vova_w810i [ 03 фев 2020, 19:02 ] | |
Я лог printenv попутал с темами, с етой камеры выложил в ту тему, а с той камеры в эту)) ---------- Добавлено спустя 3 часа 44 минуты 30 секунд: ---------- fobos большое вам спасибо за прошивки и помощь! Еще раз прошил, прописал правильный для нее HWID и ID, камера запустилась Вот с нее HWID и ID: BSN=3F0573DPAX00998 HWID=IPC-HFW2220M:01:02:02:4F:1E:00:01:00:00:00:00:258:00:00:00:00:00:01:00:00:100 devalias=IPC-HDW1220S ID=3H00BD5PAA00036 ethaddr=E0:50:8B:FA:D3:76 Подскажите пожалуйста какой командой поменять MAC адрес? ---------- Добавлено спустя 19 минут 13 секунд: ---------- Прописал МАС командой: setenv ethaddr E0:50:8B:FA:D3:76 |
fobos [ 04 фев 2020, 13:29 ] | |
класс!!! рекомендую после всех удачных прошивок сбрасывать на заводские настройки через меню камеры ---------- Добавлено спустя 7 минут 7 секунд: ---------- кстати она была и есть гарантийная |
vova_w810i [ 04 фев 2020, 22:35 ] | |
гарантия ни к чему, так как она покупалась неизвестно где и у кого Сброс через веб интерфейс сделал, видео не виснет, веб интерфейс притормаживает. Отдал человеку. |
