Текущее время: 26 апр 2024, 22:47
 Заголовок сообщения: Dell Precision T5500 - No video screen
СообщениеДобавлено: 26 янв 2020, 14:00
Hello guys,
Здраствуйте ребята!
My Dell T5500 doesn't post any video screen - black screen. It happened ever since it has been moved to another room (perhaps moisture broke it - it is just a speculation).
Symptom - When I powered it ON:
- the LED indication in front of the PC are (1) is solid green, the rest (2), (3) and (4) are OFF.
- The power button is Solid GREEN.
- The Sound code beep is 1-3-2.
According to the book the sound been indication means "1st 64 K RAM test in progress or failure".
Pre – POST Diagnostic LED Patterns - Reserved / Reserved
POST Diagnostic LED Patterns - MEM / Memory / Memory subsystem configuration activity is in progress. No memory modules were detected.
Референция - https://www.dell.com/support/article/bg/en/bgbsdt1/sln288786/precision-t3500-t5500-t7500-workstations-diagnostic-lights-and-beep-codes?lang=en
All parts - RAM, CPU, VIDEO have been tested separately and together on another machine and are working fine, so it seems the motherboard is the problem.
Not sure if it is the BIOS or some paths to the RAM slots, perhaps resistors or DIODs?
Looked for cold joints, did a hot air spoils on some sections of the board but after this the PC is acting the same, no difference!
Would like to have some additional ideals or guidance what to check, or what to do.
Don't have the motherboard schematic so kind of running on blind.
What I can check, which paths, or electronic elements ?
For additional info let me know.
Спосибо!
 Заголовок сообщения: Re: Dell Precision T5500 - No video screen
СообщениеДобавлено: 01 фев 2020, 14:50
Any suggestions ?
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL PRECISION T5500 вырубается за 5-10сек нет ИЗО
в форуме Dell
lifeparovoz
03 мар 2016, 13:40
lifeparovoz Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. DELL Precision M6400 (Precision) проблема с видеокартой.
в форуме Dell
galicia
24 май 2015, 15:36
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 14:23
anarasgarli Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Precision M4600 (10ELT13F001-B Brooks 15) video card replacment
в форуме Dell
R EZ A
04 фев 2024, 19:19
R EZ A Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. acer (la-5912p rev: 1.0) no video in lcd , video external monitor only
eletmoraes
12 июл 2019, 08:13
eletmoraes Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 7
