Powerman писал(а):
for example NX5P3290 Marking Code X5PT4
Hi, I'm still with this laptop.
I have received a few NX5P3090 (X5PT2) that has the same number of pins (balls) that the one I need, but it is smaller.
The X5PT2 is "wafer level chip-scale package; 12 bumps; 1.65 x 1.35 x0.525 mm; 0.4 mm pitch" according to datasheet.
The one I need is "wafer level chip-scale package, 12 terminals, 0.4 mm pitch, 1.97 mm x 1.42 mm x 0.525 mm" according to SOT1390-10 datasheet.
I tried to find an equivalent to NX5P3090 a bit longer (1.97 mm x 1.42 mm x 0.525 mm) but no luck till now.
I'm still trying to find out the original one.
I will appreciated any help.
Thanks.
SOT1390-10.rar
