Текущее время: 26 апр 2024, 01:11
 Заголовок сообщения: Xiaomi Air. MA18 MB 15315-2 448.09U02.0021
СообщениеДобавлено: 19 янв 2021, 19:48
Hi there.
I need to know the name of this bga 12 chip from this Xiaomi motherboard.
It is like the NX5P3290 but only have 12 balls, not 16 as NX5P3290 have.
Sorry for the quality of photos. (it's the best I can get with my smartphone)
 Заголовок сообщения: Re: Xiaomi Air. MA18 MB 15315-2 448.09U02.0021
СообщениеДобавлено: 20 янв 2021, 10:06
Marking code UA704?
СообщениеДобавлено: 20 янв 2021, 15:33
Powerman писал(а):
Marking code UA704?
UA704 is what is written neaar it on motherboard.
I've found the NX20P0407UKAZ have the same number of pins, but don't know it is a direct equivalent.
There's no schematic nor boardview, so it's difficult to say.
Here's the pdf for NX20P0407UKAZ:
NX20P0407.rar
СообщениеДобавлено: 20 янв 2021, 17:41
for example NX5P3290 Marking Code X5PT4
What marking IC UA704?
СообщениеДобавлено: 21 янв 2021, 13:36
The inscription in top of chip is:
HERU (perhaps HEAU)
H1D
I'm googled for "heru h1d" and cant find any good answer.
Also "heau h1d top marking code" and same.
Does that inscription says something for you?
Thanks for your help.
СообщениеДобавлено: 09 мар 2021, 23:30
Hi, I'm still with this laptop.
I have received a few NX5P3090 (X5PT2) that has the same number of pins (balls) that the one I need, but it is smaller.
The X5PT2 is "wafer level chip-scale package; 12 bumps; 1.65 x 1.35 x0.525 mm; 0.4 mm pitch" according to datasheet.
The one I need is "wafer level chip-scale package, 12 terminals, 0.4 mm pitch, 1.97 mm x 1.42 mm x 0.525 mm" according to SOT1390-10 datasheet.
I tried to find an equivalent to NX5P3090 a bit longer (1.97 mm x 1.42 mm x 0.525 mm) but no luck till now.
I'm still trying to find out the original one.
I will appreciated any help.
Thanks.
SOT1390-10.rar
СообщениеДобавлено: 12 мар 2021, 09:42
andromedax
HE** FPF2281BUCX
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Xiaomi mi notebook air 13 MA18 MB 15315-1 (448.09U02.0011) нет изображения
в форуме Xiaomi
ValeriyM
21 апр 2021, 14:33
ValeriyM Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Xiaomi Mi Notebook Air 13.3 MA18 MB 15315-1M нужен рабочий дамп
в форуме temp
novakov
26 янв 2018, 19:18
novakov Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Ультрабук Xiaomi Mi Air 13 плата MA18 MB 15315-2 ОПОЗНАТЬ ШИМ
в форуме Xiaomi
Nurzone
08 апр 2019, 17:17
swansic Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Xiaomi Mi Notebook Air 13.3" (MA18 MB 15315-2) кз по питанию
в форуме Xiaomi
shadow39
20 ноя 2019, 17:35
shadow39 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Xiaomi Air 13.3 (MA18 MB 15315-2) не открываются входные ключи
в форуме Xiaomi
anrigor
3878
13 фев 2021, 02:14
kvadriga Перейти к последнему сообщению
Сейчас этот форум просматривают: serSIM и гости: 1
