Текущее время: 09 май 2024, 14:03
siberian
Заголовок сообщения: Re: NP270 (Lampard) 14 Bios need Добавлено: 13 сен 2021, 20:42 |
R EZ A писал(а): NP270 (Lampard) 14 Full name of noutbook, like NP270XXX or/and BIOS ID like RBC, RBD, RBK...?
R EZ A
Заголовок сообщения: Re: NP270 (Lampard) 14 Bios need Добавлено: 13 сен 2021, 21:58 |
Зарегистрирован: 08 дек 2013, 21:10 Наличности на руках: 226.84
Сообщения: 406 Откуда: Earth
siberian писал(а): Full name of noutbook, like NP270XXX or / and BIOS ID like RBC, RBD, RBK ...? original board is amd and dead,i want to replace it with intel i have those 3 board from 15" notebooks
siberian
Заголовок сообщения: Re: NP270 (Lampard) 14 Bios need Добавлено: 14 сен 2021, 14:09 |
try it. Intel, 14" Вложение: Samsung NP270E4E BA41-02206A_02RBE.rar
R EZ A
Заголовок сообщения: Re: NP270 (Lampard) 14 Bios need Добавлено: 28 сен 2021, 20:23 |
siberian писал(а): try it. Intel, 14 " no change,same as before keyboard works wrong this is what model shows with your bios file Вложение: photo_2021-09-28_19-51-51.jpg
siberian
Заголовок сообщения: Re: NP270 (Lampard) 14 Bios need Добавлено: 28 сен 2021, 23:26 |
R EZ A писал(а): no change,same as before Which is to be expected... You asked for the BIOS - you got it. In Samsung laptops, the size of the keyboard is determined by the information recorded in the matrix EEPROM.
R EZ A
Заголовок сообщения: Re: NP270 (Lampard) 14 Bios need Добавлено: 29 сен 2021, 11:31 |
siberian писал(а): Which is to be expected ... You asked for the BIOS - you got it. In Samsung laptops, the size of the keyboard is determined by the information recorded in the matrix EEPROM. Damn samsung i thought it can be solve by bios but if it determined by matrix,how it doesn't work on 14" laptop? should i test with another 14" led?
siberian
Заголовок сообщения: Re: NP270 (Lampard) 14 Bios need Добавлено: 29 сен 2021, 22:31 |
R EZ A писал(а): should i test... try
