Текущее время: 20 май 2024, 00:33
 Заголовок сообщения: Asus X515JA (X415JA Rev2.2) Чистка ME
СообщениеДобавлено: 25 апр 2023, 10:34
Доброго времени суток товарищи.
Помогите с чисткой МЕ на этого зверя, а то у меня что то вот такая бяка вываливается:
Start Building Image
Executing pre-build actions
Warning: CSE FW version: 13.0.47.1763 is not the same as the FIT version: 13.0.20.1312
Committing ME configuration.
Building objects
Processing attribute: BuildSettings
Processing attribute: FlashLayout
Processing attribute: FlashSettings
Processing attribute: IntelMeKernel
Processing attribute: IntelAmt
Processing attribute: PlatformProtection
Processing attribute: Icc
Processing attribute: NetworkingConnectivity
Processing attribute: InternalPchBuses
Processing attribute: Power
Processing attribute: IntegratedSensorHub
Processing attribute: Camera
Processing attribute: Debug
Processing attribute: CpuStraps
Processing attribute: IfwiBinaryLayout
Error 309: Error opening file for read. D:\Программаторы\Intel Tools\Intel CSME System Tools v13.0 r2 (For Ice Lake systems which run CSME v13.0)\Flash Image Tool\x415ja_back\Decomp\EcRegionPointer.bin
Error 108: [Bin Actions] Failed to open file. D:\Программаторы\Intel Tools\Intel CSME System Tools v13.0 r2 (For Ice Lake systems which run CSME v13.0)\Flash Image Tool\x415ja_back\Decomp\EcRegionPointer.bin
Error 3: [Csme Binary Gen] Build general error. In build action.
Error 5: [Csme Binary Gen] Error building attribute. EcRegionPointerLayout
Error 5: [Csme Binary Gen] Error building attribute. Blob collect target build error.
Attribute name: DescFdBar
Attribute parent: BLOB
trace: DescFdBar --> SpiHeader --> SpiHeader --> IfwiImage --> IfwiImage --> IfwiBinaryLayout --> IfwiBinaryLayout --> FitData
Error 5: [Csme Binary Gen] Error building attribute. Descriptor
Error 5: [Csme Binary Gen] Error building attribute. SpiHeader
Error 5: [Csme Binary Gen] Error building attribute. IfwiImage
Error 5: [Csme Binary Gen] Error building attribute. IfwiBinaryLayout
Error 2: Failed to build.
Failed to build!
Более свежую FIT не могу найти, Вин-Рэйд что то третий день у меня уже не доступен, по этому и к инструкциям тож не имею доступа. С 13 версией работаю в первые, мож делаю что не так?
З.Ы. После замены "проце-хаба" имею очень долгий старт.
З.Ы.ы. В архиве родной дамп и МЕ из репозитория с моей версией.
 Заголовок сообщения: Re: Asus X515JA (X415JA Rev2.2) Чистка ME
СообщениеДобавлено: 25 апр 2023, 11:27
Пробуйте
В сети
СообщениеДобавлено: 25 апр 2023, 11:42
Переименуй папку, программа некорректно работает из путей, содержащих неанглийские символы (например, кириллицу, китайский, арабский, греческий).
СообщениеДобавлено: 25 апр 2023, 13:10
sergej66 писал(а):
Пробуйте
По моему старт стал еще дольше, до этого не засекал, но сейчас 2мин.20сек. С зарядником, если не отключать, то 35 сек, если отключить, то снова 2.20. Из хорошего, USB стали работать нормально, до этого люто тормозили. И по моему он стал сильнее греться(корпус стал теплее), и куллер сильнее молотит.
З.Ы. В диспетчере, в системных устройствах как висел под восклицательным знаком (Код 10) :Технология Intel(R) Smart Sound-OED. Так и висит.
---------- Добавлено спустя 7 минут 9 секунд: ----------
И впрямь, спасибо, учту.
Building objects
Processing attribute: StrapsDifferences
Processing attribute: FlexIO
Processing attribute: Gpio
Processing attribute: IntelPreciseTouchAndStylus
Processing attribute: (Disabled) FWUpdateImage
Executing post-build actions
Full Flash Image written to D:\Programmers\Intel Tools\Intel CSME System Tools v13.0 r2 (For Ice Lake systems which run CSME v13.0)\Flash Image Tool\outimage.bin
Writing map file D:\Programmers\Intel Tools\Intel CSME System Tools v13.0 r2 (For Ice Lake systems which run CSME v13.0)\Flash Image Tool\outimage.map
---------- Добавлено спустя 3 часа 14 минут 43 секунды: ----------
Скормил FIT-ке второй файл МЕ, который полтора метра, теперь старт всегда 35 сек, и греться стал значительно меньше, еще где то пять секунд, и запускается винда, правда она тут на SSD M2.
Мне кажется, что 35 сек для старта, это все равно очень много. З.Ы. проц тут: Intel i3-1005G1 (SRGKF).
СообщениеДобавлено: 25 апр 2023, 17:11
X415JA_cleanME.rar
СообщениеДобавлено: 25 апр 2023, 17:34
Mardekai писал(а):
X415JA_cleanME.rar [5.18 МБ]
13.0.40.1594 тоже пробовал ему скормить, тоже самое... видимо это особенность такая у этого асуса.
СообщениеДобавлено: 25 апр 2023, 17:58
Дело не в версии, просто шей. Если твой родной дамп действительно родной, должен быть нормальный старт.
СообщениеДобавлено: 25 апр 2023, 18:00
Или качните с офф сайта и попробуйте залить вообще чистый дамп, все станет понятно, в биосе трабла или нет
В сети
 Заголовок сообщения: Re: Asus X515JA (X415JA Rev2.2) Чистка ME  [РЕШЕНО]
СообщениеДобавлено: 25 апр 2023, 18:11
Зашил что что вы выложили, огонь, старт три секунды, еще секунд шесть, и винда уже вот она.
Спасибо большое.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. X515JA (x415ja) Не заряжает АКБ после прошивки BIOS
Малахов Максим
08 сен 2023, 13:28
Малахов Максим Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS X415JA (X415JA R3.1) Опознать деталь
daetoun
30 май 2022, 22:43
felix2604 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS X415JA (X415JA rev.3.1) Помогите опознать микросхемы
Bristol88
09 июл 2022, 13:15
В этой теме нет новых непрочитанных сообщений. ASUS X415JA (X415JA R3.1) Опознать деталь мосфет n or p
alexkundara
19 июн 2023, 16:11
Vlad_os Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus X515JA (X415 JA REV:2.0) Bios help
tarum2003
14 апр 2021, 20:30
tarum2003 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 7
