xps8940 (win11) factory bios need https://vlab.su/viewtopic.php?f=294&t=136330 |
dany_l2003 [ 09 авг 2023, 10:29 ] | |
Заголовок сообщения: | xps8940 (win11) factory bios need |
hello , Hi, after bios update my bios is broken. I'm trying to copy the bios dump from another and write the broken one. Everything is fine but can't save service tag in bios. the window remains blank. and on the other hand at every start it displays , the tpm module was not found, the service tag is not programmed, the manufacturing mode is active press alt+f to return to normal mode. can i do something |
foxy544 [ 09 авг 2023, 11:10 ] | |
Заголовок сообщения: | Re: xps8940 (win11) factory bios need |
try it, in general the patch costs $30 ---------- Добавлено спустя 2 минуты 55 секунд: ---------- может этот поможет |
vzrivpaket [ 09 авг 2023, 11:53 ] | |
Try. Press start (Manufacturing mode active). Press Alt+F . |
foxy544 [ 09 авг 2023, 12:17 ] | |
у него проблема TPM модуль при старте не включатся на win11 |
dany_l2003 [ 11 авг 2023, 10:03 ] | |
thank you, I'll try now ---------- Добавлено спустя 57 минут 3 секунды: ---------- thousands of thanks, WORKS |
