Текущее время: 14 июн 2024, 05:29
volp
Заголовок сообщения: SSD Sandisk SDEZS25 не форматируется Добавлено: 10 июн 2022, 18:08 |
Сообщения: 14 Откуда: Zhlobin
Приветствую всех. Имеется SSD Sandisk купленный на Ali , под маркой "EasyStore" Модель SDEZS25-120G-Z01 . SSD перестал реагировать на запись , форматирование ну и на удаление/ изменение разделов. Проверялось на трех компах и трех разных ОС.
smart
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-5.0.0-37-generic] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org=== START OF INFORMATION SECTION === Device Model: SDEZS25-120G-Z01 Serial Number: 182779803189 LU WWN Device Id: 5 001b44 8b6f868af Firmware Version: EE4500RL User Capacity: 120.040.980.480 bytes [120 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Fri Dec 27 11:02:39 2019 +03 SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: FAILED! Drive failure expected in less than 24 hours. SAVE ALL DATA. No failed Attributes found. General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 32) The self-test routine was interrupted by the host with a hard or soft reset. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x15) SMART execute Offline immediate. No Auto Offline data collection support. Abort Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 21) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 389 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 256 165 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 171 166 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 2 167 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 0 168 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 5 169 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 98 170 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 0 171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0 173 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 2 174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 28 184 End-to-End_Error 0x0032 100 100 --- Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 --- Old_age Always - 0 194 Temperature_Celsius 0x0022 067 048 000 Old_age Always - 33 (Min/Max 17/48) 199 UDMA_CRC_Error_Count 0x0032 100 100 --- Old_age Always - 0 230 Unknown_SSD_Attribute 0x0032 100 100 000 Old_age Always - 206161051696 232 Available_Reservd_Space 0x0033 100 100 005 Pre-fail Always - 100 233 Media_Wearout_Indicator 0x0032 100 100 --- Old_age Always - 248 234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 955 241 Total_LBAs_Written 0x0030 100 100 000 Old_age Offline - 362 242 Total_LBAs_Read 0x0030 100 100 000 Old_age Offline - 647 244 Unknown_Attribute 0x0032 000 100 --- Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 180 - Selective Self-tests/Logging not supported
Попытка достучаться до продавца к успеху не привела. Попытка обращения в support Sandisk (русскоязычный) в итоге привела к совету -обратитесь к продавцу. Вопрос - есть ли возможность найти для него прошивку и попробовать через ихнию утилиту SanDiskSSDDashboard прошить .
volp
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 10 июн 2022, 23:01 |
badcode писал(а): Сделайте для начала диску trim из-под Linux а как правильно команду сформировать sudo hdparm --trim-sector-ranges или sudo hdparm --trim-sector-ranges-stdin . В первом случае не знаю, что ставить sector value, во втором случае страшно ругается и предлагает мне ввести --please-destroy-my-drive (напомнило читы с варкрафта )
badcode
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 11 июн 2022, 03:00 |
Зарегистрирован: 08 апр 2019, 23:02 Наличности на руках: 158.02
Сообщения: 491 Откуда: Москва
volp писал(а): предлагает мне ввести --please-destroy-my-drive Ну, так и вводите. Это предупреждение, типа, что все данные будут разрушены. Вообще, для работы с дисками лучше перейти сначала в root. Вообще, по hdparm есть приличный MAN, поищите в сети. В нем линуксоидами все разжевано по этой утильке. Есть и другие утилиты Linux для trim ssd, попроще...
_________________ Не шалю, никого не трогаю, починяю примусы...
volp
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 11 июн 2022, 10:58 |
Вот выхлоп от trim Цитата: $ sudo hdparm --trim-sector-ranges-stdin --please-destroy-my-drive /dev/sdb
/dev/sdb: HDIO_DRIVE_CMD(identify) failed: Input/output error ---------- Добавлено спустя 1 час 7 минут 2 секунды: ----------
А вот фотки внутренностей
badcode
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 11 июн 2022, 17:36 |
volp писал(а): Вот выхлоп от trim Еще раз для тех, кто... Такие вещи делаются из root. Суперпользователь -это здорово, но для контроллеров большинства дисков этого мало, чтобы принять команду. $ sudo -i Вводим пароль ("вслепую") и выходим в корень с максимальными правами на доступ. root $ blkdiscard /dev/sdb Ждем ответа. Если нет сообщений об ошибках и все ОК, втыкаем диск на винду и пытаемся форматнуть. Если есть ошибки, разбираемся с указанной утилитой и пытаемся сделать трим посекторно (с минимально возможным количеством секторов, которое принимает на обработку диск). Это можно глянуть в hdparm запросив соответствующей командой. В принципе, если зададите интервал в 32768, вряд ли ошибетесь. BMA писал(а): Без шансов Почему? Диски на этих контроллерах укладываются в ROM, и UART интерфейс у этого контроллера есть. Предполагаю, что и прошивка там будет SanDisk с теми же плюшками, если диск оригинал. А если левак, и перемарк условного "smi", то должен быть где-то типа MPtool подходящий. Как-то же чинские джентельмены шьют эту хрень перед продажей. Возни, однако, много очень. Я голосую - за ВЕДРО. И на Ali за новым дивайсом :)))))))
volp
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 11 июн 2022, 20:10 |
badcode писал(а): Еще раз для тех, кто... Такие вещи делаются из root. Суперпользователь -это здорово, но для контроллеров большинства дисков этого мало, чтобы принять команду.
Ничего не поменялось Цитата: root@Xeon:~# blkdiscard /dev/sdb blkdiscard: /dev/sdb: BLKDISCARD ioctl failed: Ошибка ввода/вывода
badcode писал(а): Я голосую - за ВЕДРО. И на Ali за новым дивайсом :))))))) да это уже два года как в ведре, вот попался на глаза, решил еще раз попытать удачу.
BMA
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 11 июн 2022, 20:21 |
Зарегистрирован: 08 окт 2013, 00:56 Наличности на руках: 689.76
Сообщения: 1232 Откуда: Kohma
badcode писал(а): Предполагаю, что и прошивка там будет SanDisk с теми же плюшками Ничего там не будет . Не внушай ТС ложные надежды . SanDisk ( оно же теперь WD ) даже флешки лучше не брать . Да , для защиты информации клиента контроллер впадает в readonly от любого чиха . Данные на месте , диск на выброс . Можешь пробовать форматировать в чем угодно . Файловая система и аппаратная залочка диска - что тут состыкуется и с чем ? badcode писал(а): Диски на этих контроллерах укладываются в ROM, и UART интерфейс у этого контроллера есть Много поднятых ?
_________________ "Анархия -мать порядка " - вольная трактовка "Теории хаоса "
badcode
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 11 июн 2022, 20:49 |
volp писал(а): Ничего не поменялось Что пишет на fdisk -list и hdparm -I /dev/sda в студию BMA писал(а): Много поднятых ? Увы, ни одного. Есть на этом же контроллере WD Green М.2 на 120 Гб, но абсолютно рабочий. Использую, как большую флешку при надобности переноса больших файлов NTFS на другие компьютеры. Что же, мне его сломать что ли, для экспериментов? Не согласная я... :))) Работает он коряво, но работает. Кстати, есть у него одна особенность. На некоторых компах, если подключить его по SATA через переходник, тоже не хочет ничего записывать и форматировать. Читать - ради Бога, а писать - нет. А вот через USB переходник - на любом компе и оси все что хочешь. Потому и пользую, как большую флешку. Что за прикол - не выяснял, некогда. Типа глюк какой-то. ТС, а вы через USB пробывали подключиться?
volp
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 11 июн 2022, 21:55 |
Я засунул этот SSD на другой комп, теперь он /sda
fdisk
fdisk --list Диск /dev/nvme0n1: 238,49 GiB, 256060514304 байт, 500118192 секторов Disk model: KLLISRE 256GB Единицы: секторов по 1 * 512 = 512 байт Размер сектора (логический/физический): 512 байт / 512 байт Размер I/O (минимальный/оптимальный): 512 байт / 512 байт Тип метки диска: gpt Идентификатор диска: 24DAA82B-E8F6-4D9F-BFC1-0F7C9E16DD64
Устр-во начало Конец Секторы Размер Тип /dev/nvme0n1p1 2048 206847 204800 100M EFI /dev/nvme0n1p2 206848 109494271 109287424 52,1G Файловая система Linux /dev/nvme0n1p3 109494272 500117503 390623232 186,3G Файловая система Linux
Диск /dev/sdb: 111,81 GiB, 120034123776 байт, 234441648 секторов Disk model: KSQ120 Единицы: секторов по 1 * 512 = 512 байт Размер сектора (логический/физический): 512 байт / 512 байт Размер I/O (минимальный/оптимальный): 512 байт / 512 байт Тип метки диска: gpt Идентификатор диска: C6A193D1-ADDF-42A2-8B9D-7A11490D711C
Устр-во начало Конец Секторы Размер Тип /dev/sdb1 2048 234440703 234438656 111,8G Файловая система Linux
Fdisk его не видит.
lsblk
lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 111,8G 0 disk └─sda1 8:1 0 111,8G 0 part sdb 8:16 0 111,8G 0 disk └─sdb1 8:17 0 111,8G 0 part /mnt/c795b2a9-a9c7-46f5-9f4d-d8a83e61b284 nvme0n1 259:0 0 238,5G 0 disk ├─nvme0n1p1 259:1 0 100M 0 part /boot/efi ├─nvme0n1p2 259:2 0 52,1G 0 part / └─nvme0n1p3 259:3 0 186,3G 0 part /home
hdparm
hdparm -I /dev/sda
/dev/sda: HDIO_DRIVE_CMD(identify) failed: Input/output error -------------------------------------- hdparm -I /dev/sdb
/dev/sdb:
ATA device, with non-removable media Model Number: KSQ120 Serial Number: 979090692718 Firmware Revision: T181207 Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0 Standards: Supported: 9 8 7 6 5 Likely used: 9 Configuration: Logical max current cylinders 16383 16383 heads 16 16 sectors/track 63 63 -- CHS current addressable sectors: 16514064 LBA user addressable sectors: 234441648 LBA48 user addressable sectors: 234441648 Logical Sector size: 512 bytes Physical Sector size: 512 bytes Logical Sector-0 offset: 0 bytes device size with M = 1024*1024: 114473 MBytes device size with M = 1000*1000: 120034 MBytes (120 GB) cache/buffer size = unknown Form Factor: 2.5 inch Nominal Media Rotation Rate: Solid State Device Capabilities: LBA, IORDY(can be disabled) Queue depth: 32 Standby timer values: spec'd by Standard, no device specific minimum R/W multiple sector transfer: Max = 16 Current = 16 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 Cycle time: min=120ns recommended=120ns PIO: pio0 pio1 pio2 pio3 pio4 Cycle time: no flow control=120ns IORDY flow control=120ns Commands/features: Enabled Supported: * SMART feature set Security Mode feature set * Power Management feature set * Write cache * Look-ahead * NOP cmd * DOWNLOAD_MICROCODE * 48-bit Address feature set * Mandatory FLUSH_CACHE * FLUSH_CACHE_EXT * SMART error logging * General Purpose Logging feature set * WRITE_{DMA|MULTIPLE}_FUA_EXT * 64-bit World wide name * WRITE_UNCORRECTABLE_EXT command * {READ,WRITE}_DMA_EXT_GPL commands * Segmented DOWNLOAD_MICROCODE * Gen1 signaling speed (1.5Gb/s) * Gen2 signaling speed (3.0Gb/s) * Gen3 signaling speed (6.0Gb/s) * Native Command Queueing (NCQ) * Phy event counters * READ_LOG_DMA_EXT equivalent to READ_LOG_EXT * DMA Setup Auto-Activate optimization * Software settings preservation * SMART Command Transport (SCT) feature set * SCT Features Control (AC4) * SCT Data Tables (AC5) * Data Set Management TRIM supported (limit 8 blocks) * Deterministic read ZEROs after TRIM Security: Master password revision code = 65534 supported not enabled not locked frozen not expired: security count supported: enhanced erase 2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT. Logical Unit WWN Device Identifier: 50000000000009fc NAA : 5 IEEE OUI : 000000 Unique ID : 0000009fc Checksum: correct
Цитата: через USB пробывали подключиться? Да. пробовал - ничего нового . Да я все это перепробовал в позатом году, когда он накрылся , осталась только надежда на что-то с контроллером замудрить.
badcode
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 12 июн 2022, 00:21 |
volp писал(а): Fdisk его не видит. А что его видит? И куда и кому вы подаете команды?... Model Number: KSQ120 - это он?
volp
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 12 июн 2022, 23:55 |
badcodeЦитата: inxi -D Drives: Local Storage: total: 462.06 GiB used: 95.14 GiB (20.6%) ID-1: /dev/nvme0n1 model: KLLISRE 256GB size: 238.47 GiB ID-2: /dev/sda model: SDEZS25-120G-Z01 size: 111.80 GiB ID-3: /dev/sdb model: KSQ120 size: 111.79 GiB Мы продолжаем говорить о SDEZS25, как и выше. Ранее в другом компе он был /dev/sdb , теперь в этом он /dev/sda. Команды hdparm я привел на оба диска , на SDEZS25 hdparm ругается Цитата: hdparm -I /dev/sda
badcode
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 13 июн 2022, 16:54 |
Тогда разбирайтесь почему диск не монтируется. Попытайтесь примонтировать его вручную. И еще совет. Заниматься ремонтом дисков c SATA интерфейсом лучше на компьютерах, которые о mvme никогда не знали ни при своей жизни, ни после своей смерти. Это уже много раз рекомендовалось. Купите старую мать с легасу биосом. На нее Linux, DOS - и тогда за эксперименты. Только так можно быть уверенным, что устройство not enabled not locked not frozen Из под Windows trim, вроде бы как, может делать TxBENCH. Но опять же, нужно not enabled, not locked, not frozen BMA писал(а): Можешь пробовать форматировать в чем угодно . Файловая система и аппаратная залочка диска - что тут состыкуется и с чем ? Не спорю, вещи разные. Но трим аппаратная стандартизированная команда контроллеру "электрически" очистить ячейки памяти. Прошивка контроллера должна ее поддерживать, что бывает не всегда. И доступ нужен на низком уровне, что нужно обеспечить каким-то образом.
BMA
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 13 июн 2022, 17:43 |
badcode писал(а): Но трим аппаратная стандартизированная команда контроллеру "электрически" очистить ячейки памяти. Которая никогда не пройдёт при аппаратно залоченном на запись контроллере . В пустую время тратите , но , коль делать нечего ....
volp
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 13 июн 2022, 18:01 |
BMA писал(а): Которая никогда не пройдёт при аппаратно залоченном на запись контроллере А разлочить аппаратно контроллер возможно ?, и как называется контроллер ,я по фотке ничего найти не могу S811 PHPT64 - это оно ?
BMA
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 13 июн 2022, 18:38 |
volp писал(а): и как называется контроллер Как написано - так и называется , это не перемаркир , это чисто sandisk . Такого брахла уже коробка накопилась . Доноры : шимки , нанды , разъёмы итд . Даже платы одинаковые , хотя мои брахлоиды WD
BMA
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 13 июн 2022, 19:22 |
volp писал(а): теоритически в дальнейшем слить с нее инфу ? Теоретически-да , практически-нет . Инфа распределена по флешкам , по какому алгоритму этот мусор собирать в образ диска - в городке Milpitas знают , но не расскажут
badcode
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 14 июн 2022, 16:24 |
BMA писал(а): это не перемаркир , это чисто sandisk BMA, вы же знаете, как я вас уважаю?.. Но SanDisk ни при жизни, ни после покупки его WD никогда не производил собственных контроллеров. Это не их тема. Контроллер этот кто-то для них производит и разрешает маркировать собственным брендом. Одно время им даже Marvell разрешал это делать. Знать бы кто... JMicron? SMI? Хотя какая нафиг разница. Прошивки и инструментарий у SanDisk почти всегда самописные. А без них ROM МОD нам бесполезен. :)))
BMA
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 14 июн 2022, 21:05 |
badcode писал(а): Прошивки и инструментарий у SanDisk почти всегда самописные. И их нет , только бесполезные , в данном случае , апдейтилки .
volp
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 14 июн 2022, 21:50 |
badcode, BMAЧитаю и как в том анекдоте - " ничего не понятно но очень интересно " Наткнулся тут на тему http://vlab.su/viewtopic.php?f=49&t=100645 Тоже интересно очень . Есть хоть малейший смысл заморочиться и подключить плату к терминалу ?
BMA
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 14 июн 2022, 22:58 |
volpА в Вашем диске терминала нет . Там какой то JTAG . ---------- Добавлено спустя 1 минуту 14 секунд: ---------- volp писал(а): Читаю и как в том анекдоте - " ничего не понятно но очень интересно " Это мы умничаем .
badcode
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 15 июн 2022, 23:40 |
BMA писал(а): Там какой то JTAG Откуда знаете? Копались в этих дивайсах? И какие ноги процессора JTAG? Чего-то рисуют в анализатор?.. volp писал(а): Ну, да... развели тогда базар на несколько страниц. Делать нам было нечего. BMA писал(а): Это мы умничаем . Это точно...
BMA
Заголовок сообщения: Re: SSD Sandisk SDEZS25 не форматируется Добавлено: 17 июн 2022, 08:34 |
Это питатели . Вложение: IMG_20220617_072113.jpg Гребёнка контактов JTAGо подобное образование . Вложение: IMG_20220617_072217.jpg Ковырять пытался пару лет назад . Бросил . Диски бесперспективные . Самые дешёвые модели . Всё что получше идет уже на SM или Marvell .
