Вопрос о прошивке Kingston SA40037/120 https://vlab.su/viewtopic.php?f=296&t=136332 |
gevorg-x [ 09 авг 2023, 12:48 ] | |
Заголовок сообщения: | Вопрос о прошивке Kingston SA40037/120 |
Здравствуйте. Попал в руки SSD Kingston SA40037/120. На плате SM2259XT Flash ID v0.565a Drive: 0(ATA) OS: 6.2 build 9200 Model: SM2259AB-80-10000000 Fw : 20141211 Size : 0 MB [0.0 GB] Controller : SM2258AA in ROM Mode Bank00: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die Bank01: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die Bank02: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die Bank03: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die Bank04: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank05: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank08: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank09: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank10: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank11: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank12: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank13: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank14: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank15: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank16: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank17: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank18: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank19: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank20: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank21: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank22: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank23: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank24: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank25: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank26: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank27: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank28: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank29: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank30: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Bank31: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 - Какая прошивка будет работать для Intel 64L(B16A) TLC 256Gb/CE 256Gb/die ? |
jonpim [ 09 авг 2023, 13:07 ] | |
Заголовок сообщения: | Re: Вопрос о прошивке Kingston SA40037/120 |
не шьется ? https://www.usbdev.ru/files/smi/sm2259mptool/ или SM2258_B16A_FWQ0824C_MPQ1016A |
gevorg-x [ 09 авг 2023, 14:46 ] | |
jonpim писал(а): не шьется ? нет, Download MP Package FW. Нужно для 2259XT. Может есть инструкция как редактировать Flash.SET файл, что бы в списке флеш памяти отабражалась моя флешка? |
jonpim [ 09 авг 2023, 15:36 ] | |
gevorg-x писал(а): что бы в списке флеш памяти отабражалась моя флешка? бери файл Flash.SET из этого тула - https://www.usbdev.ru/files/smi/sm2259mptool/ gevorg-x писал(а): Нужно для 2259XT Нанды b16a для контроллера SM2258XT |
gevorg-x [ 09 авг 2023, 16:06 ] | |
jonpim писал(а): бери файл Flash.SET из этого тула Пробовал, Перекинул в 2259XT, ругается на data base |
jonpim [ 09 авг 2023, 16:57 ] | |
gevorg-x писал(а): нет Так какой процессор на плате ? Фото бы платы для ясности , чтобы 10 раз не переспрашивать . И мастерам в копилку ) |
BMA [ 09 авг 2023, 18:32 ] | |
Может 2259XT2G ? Для них B16A были . |
gevorg-x [ 10 авг 2023, 08:43 ] | |
jonpim писал(а): Так какой процессор на плате ? Фото бы платы для ясности , чтобы 10 раз не переспрашивать . И мастерам в копилку ) ---------- Добавлено спустя 24 минуты 50 секунд: ---------- BMA писал(а): Может 2259XT2G ? Для них B16A были . Да, знаю, но тоже не идет прошивка |
BMA [ 10 авг 2023, 11:38 ] | |
А этим не пробовали ? |
gevorg-x [ 10 авг 2023, 12:13 ] | |
BMA писал(а): А этим не пробовали ? Да, остается в режиме Download MP Package FW до бесконечности |
BMA [ 10 авг 2023, 12:22 ] | |
А USB-SATA переходник сменить ? |
gevorg-x [ 10 авг 2023, 12:23 ] | |
BMA писал(а): А USB-SATA переходник сменить ? пробовал и напрямую через Sata кабель. Результат тот же. |
BMA [ 10 авг 2023, 12:28 ] | |
По SATA я не смог прошить ни один диск с контроллером SMxxxx . |
jonpim [ 10 авг 2023, 12:29 ] | |
SM2259XT не поддерживает dram SM2259 используют с буфером dram . Нужно пробовать срастить с тулом для SM2258XT , b16a старая память . |
gevorg-x [ 10 авг 2023, 12:30 ] | |
BMA писал(а): По SATA я не смог прошить ни один диск с контроллером SMxxxx . у меня проблем не было с этим ---------- Добавлено спустя 24 секунды: ---------- jonpim писал(а): SM2259XT не поддерживает dram SM2259 используют с буфером dram . можно подробнее? |
jonpim [ 10 авг 2023, 12:35 ] | |
gevorg-x писал(а): можно подробнее? Так видно по настройкам этих тулов . |
gevorg-x [ 10 авг 2023, 12:42 ] | |
jonpim писал(а): Нужно пробовать срастить с тулом для SM2258XT , b16a старая память . С SM2258XT такая беда, пробовал несколько штук, на всех такая ошибка |
jonpim [ 10 авг 2023, 12:58 ] | |
gevorg-x писал(а): для Intel 64L(B16A) по поиску в гугл fh64b08ucn1 это ребрэндинг тошибы - https://www.techpowerup.com/ssd-specs/k ... 40-gb.d287 |
gevorg-x [ 10 авг 2023, 14:04 ] | |
Заголовок сообщения: | Re: Вопрос о прошивке Kingston SA40037/120 [РЕШЕНО] |
jonpim писал(а): по поиску в гугл fh64b08ucn1 это ребрэндинг тошибы да... и тут сказанно, что поставили 2258x и даже 2259xt как в моем случае. ---------- Добавлено спустя 2 часа 5 минут 50 секунд: ---------- УРААА!!!! получилось!!!! Без редактирования не обошлось. Значит что я сделал: Из SM2259_B16_MPT0506A_FWT0116C_RDTFIX взял параметры флешки из файла Flash.SET и скопировал в аналогичный файл но в SM2259XT B27A S0219A FWS0111A0 ; SM2259XT_B27A_PKGS0219A. На других верисях тоже получилось, но прошивка длилась больше 5 минут. А в SM2259XT B27A S0219A FWS0111A0 прошивка длится 35 секунд. Прилагаю готовый SM Tools. Не важно какой память из списка выбрать, будет работать для Intel 64L(B16A) TLC. |
