Текущее время: 20 апр 2024, 08:12
Котеус
Заголовок сообщения: Re: k556u (asus) work slowly with mechanical hdd Добавлено: 31 июл 2019, 23:06 |
Зарегистрирован: 19 янв 2016, 10:24 Наличности на руках: 671.94
Сообщения: 597 Откуда: Eversong
(sorry for my bad english)
If the root of problem is pch - your work with ssd will be slowly too. Can you set up optibay instead of your DVD-RW drive, use mechanical HDD in optibay and SSD in HDD slot? With this, you can use big space of HDD with fast speed of SSD; and of cource you can test speed of your HDD under installed OS.
