Текущее время: 02 июн 2024, 09:01
 Заголовок сообщения: g751jy (asus) keyboard short-problem
СообщениеДобавлено: 20 мар 2017, 12:06
hi guys, i got asus g751jy with strange problem, some of the functions of the keyboard are not working and some showing more letters, for instance when i press k letter it shows jfa/, number one and escape do not function...so at first i thought it was the keyboard mailfunction...but i tried to install everything from the begging, the drivers...then i realised that touchpad is not working normally if i connect the keyboard..it would make a strange sound and left pad will not work...when i removed the keyboard it works. Oh, and one more thing on usb keyboard everything is working fine. So, i tested the motherboard, and on keyboard connector i got continuity on 1 and 9 pin. I look at the boardview and pin 1 is a +5V_KBLED and pin 9 is a +5VS. So this two nets shouldnt be connected? right?! So i checked continuity between all in these two nets and they are connected off course.
As you can see the +5V_KBLED (attachment one) net is much smaller then +5VS net (attachment 2). But they have only one point which they could connect to each other. and that point is that resistor R3112, on one side it is +5VS and on the other +5V_KBLED. I think it is broken/not working? i checked continuity on it and it shows yes, but that doesnt mean 100% it is this resistor. And it shows 0.3 ohms while connected to the board. I attached also the resistor details.
So, can i safely assume that this resistor needs to be replaced? i am pretty noob in all of this so thank you all for the help.
Also, attached my working material with original photo of the motherboard and markings of nets.
Привет, ребята, у меня есть asus g751jy со странной проблемой, некоторые функции клавиатуры не работают, а некоторые показывают больше букв, например, когда я нажимаю букву k, она показывает jfa /, номер один и escape не работают ... так Сначала я думал, что это клавиатура mailfunction ... но я попытался установить все, начиная от попрошайничества, драйверов ... потом я понял, что сенсорная панель не работает нормально, если я подключаю клавиатуру .. это будет странный звук и Левая панель не будет работать ... когда я удалю клавиатуру, она работает. Да, и еще одна вещь на клавиатуре usb: все работает нормально. Итак, я протестировал материнскую плату, и на разъеме клавиатуры я получил непрерывность на 1 и 9 pin. Я смотрю на доску, и контакт 1 - это + 5V_KBLED, а pin 9 - +5VS. Так что эти две сети не должны быть подключены? правильно?! Таким образом, я проверил непрерывность между всеми этими двумя сетями, и они связаны конечно.
Как вы можете видеть, сеть + 5V_KBLED (привязка одна) намного меньше, чем + 5VS net (приложение 2). Но у них есть только один пункт, который они могли бы связать друг с другом. И этот момент заключается в том, что резистор R3112, с одной стороны, это + 5VS, а с другой + 5V_KBLED. Я думаю, что он сломан? Я проверил непрерывность на нем, и он показывает, да, но это не означает, 100% это резистор. При подключении к плате оно показывает 0,3 Ом. Я также прилагаю детали резистора.
Итак, могу ли я с уверенностью предположить, что этот резистор нужно заменить? Я довольно нуб во всем этом, так что спасибо всем за помощь.
Кроме того, прилагается мой рабочий материал с оригинальной фотографией материнской платы и маркировки сетей.
Posted after 2 hours 52 minutes 34 seconds:
Or in the end continuity there is ok, and it is false keyboard that is shorting other parts?
Или, в конце концов, это нормально, и это ложная клавиатура, которая закорачивает другие части?
 Заголовок сообщения: Re: g751jy (asus) keyboard short-problem
СообщениеДобавлено: 21 мар 2017, 15:44
Вероятно всех пугает текст проблемы и не возникает желания разбираться. Могу посоветовать вкратце описать, что было проделано для ее устранения (типа подкидывал другую клавиатуру) и так же мелкими порциями запросить помощи
СообщениеДобавлено: 25 мар 2017, 16:30
Я не услышал, что автор темы поставил рабочую клавиатуру, для начала.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus rog g751jy (asus rog g751jy) нет заряда батареи
Avraham
2986
27 июл 2020, 10:10
Avraham Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus G751JY (G751JY Rev. 2.0) корорткий импульс на AC_BAT_SYS примерно каждую секунду
user54321
2186
26 янв 2019, 22:53
user54321 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. G751JY (G751JY rev 2.0) не видит сетевой контроллер
Mehrunes
08 июл 2018, 04:00
Mehrunes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. g751jy (g751jy) нет изображения
SEmp
13 май 2020, 19:49
Panovich Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. G751JY (G751JY) Отключается блок питания
Panovich
2234
14 май 2020, 17:54
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 20
