asus (n551jk) charging https://vlab.su/viewtopic.php?f=40&t=105262 |
narges [ 26 июл 2020, 19:35 ] | |
Заголовок сообщения: | asus (n551jk) charging |
hi guys i have problem with asus n551jk it not power on with charger but it ok with battery so i have same problem before and with change ic charge and all mosfet it ok but in this case no answer is there any one can help me??? please Posted after 8 minutes 1 second: if i jump PQ8801 mosfet it will power on but cant charging... without jumping mosfet it not power on with charger |
Krydsvard [ 04 авг 2020, 21:56 ] | |
Заголовок сообщения: | Re: asus (n551jk) charging |
narges писал(а): if i jump PQ8801 mosfet it will power on but cant charging... without jumping mosfet it not power on with charger The problem pq8801 won`t open? What ic charger voltages acdrv-4, acdet-6, regn-16, vcc-20 pins? |
