XMAX писал(а):
Device manager have a sound card?
No..
I've started from the strange low resistance of CX20752-21z's pin 5... tested a couple of similar chips on other boards to find out the resistance is much much higher !
I've removed the HDD mini-board and the short was gone at R0720 on the mainboard, inspection of the (goddamn j4801) and found a short between pin 22(A_Z_BITCLK) & 24(GND)
Now 2 broken pins in j4701 and 2 shorted in j4801..
I've removed the stupid connectors and now I'm searching for similar ones, there's no way to order online for me...
any ideas where to dig for them ?
