The second one (24Kohm) connected to MP2886A's Pin 22 (VINSEN) are voltage dividers that "according to the datasheet" should not exceed 1.6v at the maximum input voltage "powering from the adapter"
what is the value of the second resistor in the divider ?
here's the MP2886A datasheet...
LINKHere , a similar board "with MP2884A" was fixed using 10K/1K divider (setting VINSEN to around 1.7v) which is not recommended according to the datasheet..
I would try 15K/1K
