my friend asus x542uq charging problem turns off when the charger is unplugged, it turns on when you plug in the charger, the battery charge rate seems 100% full thanks
_________________ asliyucegsm notebook repair and cars electronic repair
Mardekai
Заголовок сообщения: Re: asus x542uq (rev.2.0) charge problem battery
Добавлено: 23 июн 2023, 23:59
Зарегистрирован: 28 июл 2016, 23:01 Наличности на руках: 686.31 Сообщения: 1292 Откуда: Москва
try tightening that screw
Вложение:
harun
